Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
31 registered members (c502cid, carlprop, bbhero, Brad_C, Black_Thunder, 3 invisible), 787 guests, and 65 spiders.
Topics286,170
Posts4,903,522
Members67,572
Most Online2,967
Mar 10th, 2019
video ( filter cut open) #4557157
10/28/17 12:08 PM
10/28/17 12:08 PM
Western Ma.
rollinpete Offline OP
Western Ma.
Granted this is an airplane engine, but it's cool how he opens the pleats and you can see some [censored] hiding in there shocked
https://www.youtube.com/watch?v=mO1M_0u-owE
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: video ( filter cut open) [Re: rollinpete] #4557201
10/28/17 12:41 PM
10/28/17 12:41 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Nicely done video.
Notes:
1. This is an eCore that did well over the mandated oil and filter change interval. It took some effort to peal away the end caps.
2. There is trash in the pleats that need explanation. If it was the first change after major work then likely no problem. If this is a change that is well away from repairs , this engine might need attention.
3. He did not check pleat integrity before tearing up the element.
4. Nice trick with the plastic bag.
5. Really good example of an eCore being used in a maintenance managed environment. When run over proper intervals, no filter issues result. If the filter has an issue, the engine is likely at fault and needs further diagnosis and repair.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: video ( filter cut open) [Re: rollinpete] #4557312
10/28/17 02:24 PM
10/28/17 02:24 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
WEIRD - I have never seen anyone use an automotive oil filter (LEGALLY) on an aircraft engine
Re: video ( filter cut open) [Re: Linctex] #4557404
10/28/17 03:48 PM
10/28/17 03:48 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Probably a Spartan grad tex.
Re: video ( filter cut open) [Re: Linctex] #4557492
10/28/17 05:29 PM
10/28/17 05:29 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
The filter in the video has a thick can. The burst strength for aviation filters is on the order of 600 psi.
Re: video ( filter cut open) [Re: rollinpete] #4557498
10/28/17 05:37 PM
10/28/17 05:37 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
The Luber-Finer PH8A has 2978 applications listed. Most are old applications for small and large block gas engines, some car engines, and quite a few Diesel engines in industrial applications.
Re: video ( filter cut open) [Re: rollinpete] #4559116
10/30/17 09:40 AM
10/30/17 09:40 AM
USA
wowthisexists Offline
USA
Look how clean that oil is....LOL
Re: video ( filter cut open) [Re: rollinpete] #4559549
10/30/17 06:54 PM
10/30/17 06:54 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Since this was a demo/training, the A&P trainer may have purchased the PH8A for demonstration purposes only. Just a thought.
Re: video ( filter cut open) [Re: WellOiled] #4561754
11/02/17 01:01 AM
11/02/17 01:01 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The FAA doesn't give two [censored] about that....
if the oil filter is NOT listed on the Type Certificate, it is ILLEGAL to use.
That, and expect Luber Finer's legal dept to request his video be taken down.
I know I would if a video shows it's Ok to run an oil filter on an aviation application that it IS NOT "approved" for.
HUGE legal bills could ensue.
