GL5 MT1 in an Older Transmission
NY
Hello,
This may be one of the most clouded topics in regards to gear oil. In 2017, is a GL5 MT1 rated gear oil acceptable in a thirty year old brass synchro manual transmission?
GL5 gear oil is cheap nearly everywhere, GL4 gear oil is mainly from specialty brands and expensive.
I wanted to ask the pros here: GL5 MT1 = yellow metal safe?
Yes, a GL5 without MT1 = yellow metal safe. Period.
A GL5 with MT1 = more safe, if one must differentiates.
You are wrong.... GL5 solo is never yellow metal safe!
GL4+.... GL4/5...or GL5/MT-1 tends to be yellow metak safe...
Althouhg some yenks are saying that it is not so...in 21.st century
What a bold and hilarious claim!
Ever read about deactivated/buffered sulfur additives in modern day,that is , current GL5 gear oil formulations ??
Thank you for the link, did not realize this is currently being discussed.
Seems to be two camps here, which is why I came here in the first place. If only GL4 gear oil was cheap like GL5, and not becoming exclusive to specialty brands that want $20 a quart. I do not want to support such a price point for GEAR LUBE.
Yes but that "buffered sulphur" is in yellow metal safe formulations...
And labeled as... GL4+... GL4/5...or GL5/MT-1
And NEVER under GL5....solo/alone
Doesn't the GL-5 specification in and of itself have yellow metal protectants? My ECHO owner's manual says either is acceptable and it has brass synchronizers. I've used Mobil 1 gear oil for a long time and according to the container it is GL-5 only.
Hello,
You're missing a key point here as explained in the linked posts.
Sure GL-5 differential lubes are relatively cheap but they don't have the proper Anti-wear additive mix, nor do they have the friction modifiers that make for smooth synchro operation.
And GL-5 differential lubes have a higher viscosity than specially formulated (dedicated) MTF's, which may make shifting more of a chore in cold temps.
If your transmission requires a 75W90, then Amsoil MTG or Redline MT-90 would work a heckuvalot better in your tranny.
Still insists GL5 corrodes yellow metal synchronizers ?
Listen to Paul's video in post #1 here from 11.25 -15.20
Edit:spelling
Hello,
This is a good point.
What I gather from everything here is both GL4 and GL5 is safe for use, but GL4 is the fluid I should use in regards to its functionality with a manual gear box. I will do as follows: Put cheap GL5 gear oil in my Diffs and transfer case, but I will order up some Redline MT90 for the tranny, as it is something I have to feel all day long while driving. I really hate spending upwards of $20 a quart for either of these. But I guess it is only once in a while.
Thank you for all the clarification!
