Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
0W-16 Oil....... Really ??
by billt460
58 minutes 40 seconds ago
Looks like Valvoline is trying again.
by demarpaint
Today at 05:42 AM
Johnson 25/40 4 stroke marine oil.
by passgas55
Today at 05:00 AM
Oil Filter That Hasn't Been Changed In 3 Years
by BlueOvalFitter
Today at 02:44 AM
by dishdude
Today at 02:28 AM
Control Arm Bushings Bad?
by RoGuE
Today at 01:36 AM
Free Pizza, April 2, 2018....
by mattwithcats
Today at 12:15 AM
Low mileage seven year old tires
by Corollaman
Yesterday at 11:31 PM
Mobil 1 UOAs showing more wear?
by mbacfp
Yesterday at 10:35 PM
2011 Silverado work truck 6000 miles
by Corollaman
Yesterday at 10:25 PM
PP Practically Free at O'Reilly
by John_K
Yesterday at 10:22 PM
Toyota oil filter cartridge assembly
by pda1122
Yesterday at 10:14 PM
Carrying IWB 1911 vs Glock 19
by lukejo
Yesterday at 09:01 PM
Broken stuff this weekend - great service 'though.
by Shannow
Yesterday at 08:57 PM
Denso Air and Cabin Filters?
by maverickfhs
Yesterday at 08:41 PM
Sticky door latch 2nd generation Golf
by vavavroom
Yesterday at 08:35 PM
7$ for a quart of Conventional Oil
by Emanuel
Yesterday at 08:03 PM
Walmart Auto Service - Rant
by Warstud
Yesterday at 07:47 PM
Who has a GOOD particle counter?
by Linctex
Yesterday at 07:41 PM
Pretty impressed non ethanol fuel yard equipment
by ARB1977
Yesterday at 06:28 PM
glitch666, A76, 3one7, Lubrizol, bdunigan
64486 Registered Users
42 registered (billt460, ARB1977, AZjeff, Bjornviken, BobFout, BobsArmory, 4 invisible), 892 Guests and 121 Spiders online.
64486 Members
68 Forums
279988 Topics
#4557037 - 10/28/17 10:30 AM ABS Lite 1991 Chevy Caprice 5.0l Automatic
WyrTwister Offline
Loc: Texas
Put this car back in service , yesterday . Was mom & Dad's car , 46,000 + miles .
While I was driving , them ABS lite came on . What DIY checks / diagnosis should I do .
Thanks , :-)
God bless
#4557370 - 10/28/17 03:10 PM Re: ABS Lite 1991 Chevy Caprice 5.0l Automatic [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Used THE TURKEY BASTER to suck the old brake fluid out of the reservoir . Wiped the 2 compartments out . Had a little left in a container of DOT 3 & added that .
Had a full container od DOT3 - DOT 4 , finished filling the 2 compartments .
This 1991 model car , will the DOT 3 be OK ? How about the DOT 3 - DOT 4 ?
Went to the grocery store & also filled the car up with gas . ABS lite came on going to the store . Coming back , I do not think it came on again . Maybe changing out the fluid in the reservoir may have helped .
Thanks , :-)
God bless
#4557375 - 10/28/17 03:19 PM Re: ABS Lite 1991 Chevy Caprice 5.0l Automatic [Re: WyrTwister]
14Accent Offline
Loc: MN
That vintage will blink out ABS codes with a paper clip jumper in the ALDL (obd port). However, they don't have the ability to store codes. They're lost when the ignition is cycled. Google how to pull the codes and carry a paper clip with you, and next time the light comes on try and snag the code.
#4557395 - 10/28/17 03:41 PM Re: ABS Lite 1991 Chevy Caprice 5.0l Automatic [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Thanks , I will look into that . I have done something like that when I got a Check Engine Lite .
Only ABS problem it ever had was a ABS cable field mice chewed in tow , going to the RF wheel . Splicer / repaired the cable & it went away .
There is an ABS sensor on the LF wheel and at the differential .
Thanks , :-)
God bless
#4558711 - 10/29/17 07:49 PM Re: ABS Lite 1991 Chevy Caprice 5.0l Automatic [Re: WyrTwister]
WyrTwister Offline
Loc: Texas
Found some info on checking ABS codes . Seems the previous coded are lost when you turn off the ignition .
Ran several errands , at different times , today . Some times the ABS lite comes on , some times not .
God bless
Here is how to read GM ABS trouble codes on an OBD1 system. This applies to Chevrolet and GMC vehicles from the 1990s.
Put a jumper across the pins and then turn the ignition on.
The ABS light will flash the trouble codes 3 times each and then repeat them. Here is a list of the GM trouble codes, and what they mean.
Codes 12 and 14 aren't trouble codes, but may appear to indicate normal operation.
21 - right front speed sensor or circuit open.
22 - missing right front speed signal.
23 - erratic right front speed signal.
25 - left front speed sensor or circuit open.
26 - missing left front speed signal.
27 - erratic left front speed signal.
29 - simultaneous drop-out of front speed sensors.
35 - vehicle speed sensor or open circuit.
36 - missing vehicle speed sensor signal.
37 - erratic vehicle speed sensor signal.
38 - wheel speed error.
41 - 54 control valves
61 - 63 reset switches
65 - 66 open or shorted pump motor relay.
67 - open motor circuit or shorted BPMV output.
68 - locked motor or shorted motor circuit.
71 - 74 memory error.
81 - brake switch circuit shorted or open.
86 - shorted anti-lock indicator lamp.
87 - shorted brake warning lamp.
God bless
