Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
109 registered members (02z, 53' Stude, 240_Ed, 14 invisible), 2,360 guests, and 34 spiders.
Topics296,878
Posts4,960,735
Members66,987
Most Online2,688
Jan 19th, 2019
16" x 6.5" 5x100 Toyota wheels #4556982
10/28/17 08:46 AM
10/28/17 08:46 AM
Wa
Corollaman Offline OP
Wa
Are there any other makes that match this size besides Toyota? I'm looking for snow wheels.
Re: 16" x 6.5" 5x100 Toyota wheels [Re: Corollaman] #4557076
10/28/17 10:00 AM
10/28/17 10:00 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
You technically should know the hub bore diameter and wheel offset as well. Assuming it's for a Corolla, based on your username, this website, http://www.wheelsupport.com/toyota-bolt-patterns/ , shows that it's 54.1mm hub bore with a high offset, probably in the 35-40mm range.
https://www.wheel-size.com/size/toyota/corolla/
Take a look here for a cross reference http://www.roadkillcustoms.com/hot-rods-...0#axzz4wopHSFYW . Technically any hub bore that's larger than 54.1 will work (not sure if toyota wheels are hub centric), but your best bet is to find something with the same hub bore. I'd imagine that there are LOTS of used OEM wheels out there on CL.
Re: 16" x 6.5" 5x100 Toyota wheels [Re: Corollaman] #4557187
10/28/17 11:29 AM
10/28/17 11:29 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'd consider going down to a 15 inch wheel that used to come on the 2005 or so Corollas. Should be a bit cheaper for the wheels and the tires. Plus better performance most likely in the bad weather. Instead of the 205/55R16s you can get 195/65R15 tires. Which should be a lot cheaper. A tire place here has Hankook Kinergy GTs for $38 each.
Re: 16" x 6.5" 5x100 Toyota wheels [Re: Corollaman] #4557608
10/28/17 06:14 PM
10/28/17 06:14 PM
ME
eljefino Online content
eljefino  Online Content
ME
Subarus have the 5x100 pattern but a bigger center hole. I have not had issues going lugcentric. You'll also have luck with chevy cavaliers and PT cruisers. THere were LOTS of 16" rims on cavaliers back in the early 2000s. Remember these:
The list is huge and toyota has a tiny center bore. You should be all set.
I got subee rims for my wife's prius for $5 each off CL. approved
I agree with the 15" suggestion as well. If you dont' already have snows you should be able to get some 195/65/15 Champiro Ice pros for $109/4 this black friday from DTD.
