Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
104 registered members (2018matto, 4WD, 28oz, 1foxracing, 64bawagon, 01ws666, 10 invisible), 1,864 guests, and 36 spiders.
Topics294,973
Posts4,925,157
Members66,657
Most Online2,553
Oct 27th, 2018
GL5 MT1 in an Older Transmission #4556909
10/28/17 07:13 AM
10/28/17 07:13 AM
NY
redwolf4k Offline OP
NY
Hello,
This may be one of the most clouded topics in regards to gear oil. In 2017, is a GL5 MT1 rated gear oil acceptable in a thirty year old brass synchro manual transmission?
GL5 gear oil is cheap nearly everywhere, GL4 gear oil is mainly from specialty brands and expensive.
I wanted to ask the pros here: GL5 MT1 = yellow metal safe?
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4556918
10/28/17 07:26 AM
10/28/17 07:26 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4556972
10/28/17 08:36 AM
10/28/17 08:36 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Yes, a GL5 without MT1 = yellow metal safe. Period.
A GL5 with MT1 = more safe, if one must differentiates.
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4556991
10/28/17 08:52 AM
10/28/17 08:52 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
You are wrong.... GL5 solo is never yellow metal safe!
GL4+.... GL4/5...or GL5/MT-1 tends to be yellow metak safe...
Althouhg some yenks are saying that it is not so...in 21.st century
Re: GL5 MT1 in an Older Transmission [Re: Kamele0N] #4557068
10/28/17 09:52 AM
10/28/17 09:52 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
What a bold and hilarious claim!
Ever read about deactivated/buffered sulfur additives in modern day,that is , current GL5 gear oil formulations ??
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4557330
10/28/17 01:39 PM
10/28/17 01:39 PM
NY
NY
Thank you for the link, did not realize this is currently being discussed.
Seems to be two camps here, which is why I came here in the first place. If only GL4 gear oil was cheap like GL5, and not becoming exclusive to specialty brands that want $20 a quart. I do not want to support such a price point for GEAR LUBE.
Re: GL5 MT1 in an Older Transmission [Re: zeng] #4557406
10/28/17 02:52 PM
10/28/17 02:52 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Yes but that "buffered sulphur" is in yellow metal safe formulations...
And labeled as... GL4+... GL4/5...or GL5/MT-1
And NEVER under GL5....solo/alone
Re: GL5 MT1 in an Older Transmission [Re: Kamele0N] #4557433
10/28/17 03:25 PM
10/28/17 03:25 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Doesn't the GL-5 specification in and of itself have yellow metal protectants? My ECHO owner's manual says either is acceptable and it has brass synchronizers. I've used Mobil 1 gear oil for a long time and according to the container it is GL-5 only.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4557475
10/28/17 04:18 PM
10/28/17 04:18 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4557535
10/28/17 05:25 PM
10/28/17 05:25 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Hello,
You're missing a key point here as explained in the linked posts.
Sure GL-5 differential lubes are relatively cheap but they don't have the proper Anti-wear additive mix, nor do they have the friction modifiers that make for smooth synchro operation.
And GL-5 differential lubes have a higher viscosity than specially formulated (dedicated) MTF's, which may make shifting more of a chore in cold temps.
If your transmission requires a 75W90, then Amsoil MTG or Redline MT-90 would work a heckuvalot better in your tranny.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: GL5 MT1 in an Older Transmission [Re: Kamele0N] #4558091
10/29/17 07:02 AM
10/29/17 07:02 AM
Upper Midwest
Upper Midwest
1994 BMW 530i, 238K
Re: GL5 MT1 in an Older Transmission [Re: Kamele0N] #4558092
10/29/17 07:03 AM
10/29/17 07:03 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Still insists GL5 corrodes yellow metal synchronizers ?
Listen to Paul's video in post #1 here from 11.25 -15.20
Edit:spelling
Re: GL5 MT1 in an Older Transmission [Re: redwolf4k] #4558323
10/29/17 10:54 AM
10/29/17 10:54 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
OK...it seems that you are correct...
Re: GL5 MT1 in an Older Transmission [Re: MolaKule] #4558984
10/30/17 05:59 AM
10/30/17 05:59 AM
NY
NY
Hello,
This is a good point.
What I gather from everything here is both GL4 and GL5 is safe for use, but GL4 is the fluid I should use in regards to its functionality with a manual gear box. I will do as follows: Put cheap GL5 gear oil in my Diffs and transfer case, but I will order up some Redline MT90 for the tranny, as it is something I have to feel all day long while driving. I really hate spending upwards of $20 a quart for either of these. But I guess it is only once in a while.
Thank you for all the clarification!
