Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
22 registered members (4WD, biggusblockus, agh13tz, Astro14, Ablebody, 5 invisible), 740 guests, and 41 spiders.
Topics290,921
Posts4,852,538
Members66,055
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
New Hemi 5.7L, what oil would you use? #4556903
10/28/17 07:56 AM
10/28/17 07:56 AM
ct
pantygnome Offline OP
ct
Hello fellow BITOG-ers!
Picked up a RAM with the 5.7: Hemi a few weeks ago. Only has 450 miles on it right now but I started Googling around for recommended oils and fell onto the massive Synth Oil thread on ram forum, along with a thread here about "Hemi tick".
My engine is not ticking (at least not yet), and Id like to keep it that way. I plan on draining the factory fill around 1K miles because I didnt want to go through the winter on it (sometimes nasty up here in Connecticut)
Chrysler specs 5W-20 which Ive heard might be a little thin. I tend to agree, but starting a search for 5W-30 opens up an even larger can of confusion.
My daily drive isnt very long at all (3 miles each way, but I can go "the long way" and make it 6 miles each way) and 80-90% of the mileage on the truck would be city.
If it were YOUR Hemi, what oil would YOU use?
Thanks in advance.
-Chris
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556904
10/28/17 08:06 AM
10/28/17 08:06 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Whatever synthetic in the weights your owner's manual suggests. If it allows 0w20s I'd roll with a 0w20.
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556905
10/28/17 08:08 AM
10/28/17 08:08 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
SAE 5W-30 oil should cause no problem in your engine, but since the engine is under under warranty, I would recommend using what is recommended. A friend of mine recently purchased a new Charger with the 5.7 and he changed the oil using Mobil 1 5W-20. The car has been driven from Durango, Colorado to Los Angeles twice during the summer with 5W-20 in it with no noises or oil consumption.
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556913
10/28/17 08:17 AM
10/28/17 08:17 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Thanks in advance.
-Chris
Chrysler, the manufacturer of the vehicle specs 5W20 but you have "heard" it might be to thin. Whom are you hearing things from that knows more than Chrysler.
Use a quality 5W20 synthetic. Many on the shelves at Walmart.
2015 Ford F250 w/Powerstroke
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556915
10/28/17 08:24 AM
10/28/17 08:24 AM
Sauk Valley, IL
EricBeau Offline
EricBeau  Offline
Sauk Valley, IL
I believe Chrysler has been using Pennzoil as factory fill for a while now, at least on some of the performance motors. I'd use Pennzoil Platinum 5w-20 while under warranty but I'm no expert.
2001 Toyota Camry LE 4cyl.
Valvoline MaxLife 5W-30 blend and FRAM PH4967
2010 Honda Odyssey LX
Valvoline MaxLife 5W-20 blend and FRAM TG7317
Ford Service Advisor
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556968
10/28/17 09:30 AM
10/28/17 09:30 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Since the Hemi was originally specified for 5w30, that is what I would use. With your short trips/mostly city I agree with an inexpensive off the shelf oil since your intervals will be fairly short. Maybe even ST Synthetic which has shown good UOAs up to 5000 miles. Add a Fram Ultra to be changed every 10k.
Thick vs Thin test: 15k / 43k miles complete
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556969
10/28/17 09:33 AM
10/28/17 09:33 AM
ct
ct
Thanks guys.
Yes, the "heard" has been from other forums. Ive always thought of -20 as a means for a manufacturer to meet CAFE regulations, not really in the interest of making an engine go 200K miles. Chrysler specs 5W-20, but says 5W-30 can be used if 5W-20 is not available (define "not available" right? smile )
And yes, most if not all of the Pennzoils meet the Chrysler spec for the engine (and one of them is supposedly factory fill....not full synth, maybe the blend or just PYB). I can find PP in 5W-20 relatively easily, but PUP in 5W-20 seems to be some form of mummified unicorn.
The theory is that moly helps quiet/stop/prevent(?) the tick, so I was looking for any 5W-20 oil that had at least OK moly numbers. Oddly enough Castrol GTX Ultraclean seems to kinda fit the bill, but I was worried about cold weather performance and short-tripping a conventional oil. Pennzoil Gold is another possibility, but I havent seen very up to date analysis results on that yet.
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556981
10/28/17 09:45 AM
10/28/17 09:45 AM
Knoxville, TN
Big Smoke Offline
Big Smoke  Offline
Knoxville, TN
QSUD 5w-20. Meets Chrysler spec and is $20 for a 5qt jug at Wal-Mart. Add the $7 rebate to it. You can't go wrong.
2017 Dodge Charger Rallye
2015 Toyota Yaris 1.2L (Thailand)
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556983
10/28/17 09:46 AM
10/28/17 09:46 AM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
No where in the owners manual does it say 5-30 can be used in the hemi. I am using PUP 5-20. If I develop the hemi tick, I will switch to 5-30 redline oil as per oil thread you found. Keep in mind it does not carry the recommended certification.
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4556993
10/28/17 09:53 AM
10/28/17 09:53 AM
NY
demarpaint Offline
demarpaint  Offline
NY
My buddy has a 2016 with the 5.7 Hemi. He has been using PU 5W30 in his w/o issue. He ran 5W20 for about 10K miles and decided to go with 5W30 after doing his own research and speaking with a few techs he knows that advised him to make the change.
God Bless Our Troops
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4557005
10/28/17 10:04 AM
10/28/17 10:04 AM
Lynchburg, Va
JasonC Offline
JasonC  Offline
Lynchburg, Va
My 2014 Ram 5.7 Hemi has 32,500 on it and I've run QSUD since the first oil change at 6,000. I run it 8,000 and it never uses a drop.
2012 Buick Verano 2.4
2006 Ford Mustang GT Convertible
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4557020
10/28/17 10:20 AM
10/28/17 10:20 AM
The Old Dominion, USA
Tim_S Offline
Tim_S  Offline
The 5.7 hemi runs considerably smoother with a more viscous oil than the CAFE spec'd 5W-20. On my 2017 Ram I changed the FF to Amsoil SS 5W-30 with a dose of Lube Guard. Smooth and quiet. Now running Castrol (Euro) 0W-40 with Lube Guard; same. No issues at all with the MDS. In fact I turn the MDS off every time I start the truck (using the paddle shifters) and my highway mileage actually has improved by 1 to 2 mpg than with the MDS left operating. Doesn't make sense, but I'll take it.
Given your short trips, I'd try QSUD 5W-30. It a very good oil and has a decent amount of moly to boot, and I believe it carries the recommended Chrysler specification.
My Garage: 2017 Ram 1500, 5.7 ; 2009 Subaru Sti (significantly modified);2014 Toyota FJ Cruiser
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4557027
10/28/17 10:24 AM
10/28/17 10:24 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
If I were worried about warranty/API Cert: QSUD 5W-20 (or -30, if it was allowed).
If I'm not concerned about warranty/API Cert: My first choice would be Redline 5W-30.
Re: New Hemi 5.7L, what oil would you use? [Re: pantygnome] #4557033
10/28/17 10:29 AM
10/28/17 10:29 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
I would run a high viscosity 5w-20. Castrol Magnatec,PUP,redline. If you choose a 30 weight run a thin 30w like PP. .02
Re: New Hemi 5.7L, what oil would you use? [Re: JasonC] #4557062
10/28/17 10:48 AM
10/28/17 10:48 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
-20 or -30 grade?
Page 1 of 4 1 2 3 4
