Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
Rock oil carbon #4556768
10/27/17 11:25 PM
10/27/17 11:25 PM
UK
Cornershop Offline OP
UK
Gents
Can someone please review the specs of the Rock Carbon oil (0w40 and 10w50) and advise if street/road usable for 3k/annum, aircooled 911
http://www.rockoil.co.uk/cm/images/pdf/techdata/automotive/Carbon_Series.pdf
Similar in price to the Millers NT range
Thank you
Re: Rock oil carbon [Re: Cornershop] #4556774
10/27/17 11:28 PM
10/27/17 11:28 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Specs look good. NOACK is low. No 0W-20's. Seems like a good thing smile
Re: Rock oil carbon [Re: Cornershop] #4556840
10/28/17 03:44 AM
10/28/17 03:44 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Low Noack values (good), high HTHS values (good) and a decent TBN. Looks good.
I remember Rock-Oil from the 90's, as a high quality performance motorcycle oil. They had some great eye catching adverts in the motorcycle press too.
The one thing that is a minor point, the 0W40 is rated MB 229.5, which means it must pass ACEA A3/B4, which means it needs a TBN of 10 or more. Yet they give it's TBN as 8 which makes it A3/B3 and not technically MB 229.5. Either a typo, or "suitable for ..." rather than actually tested by MB. Wouldn't be hard to find out, as MB list all the oils they have tested and passed. Still you are only planning for 3k miles / 1 year and a TBN of 8 will be easily up for that.
I think it should be fine, and I would go thicker in an air cooled engine, so 10W50 sounds about right to me.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Rock oil carbon [Re: SR5] #4557014
10/28/17 10:14 AM
10/28/17 10:14 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, 3,000 miles on a TBN 8 oil is nothing stressful at all.
That's my hunch as well.... but it's just a hunch
Re: Rock oil carbon [Re: Linctex] #4559124
10/30/17 09:48 AM
10/30/17 09:48 AM
UK
UK
Thanks folks
The technical director has today confirmed zddp in the region of 1200ppm, with 'other additives protecting the valvetrain'
He also advised the recommended max OCI is 5000 miles / 12months in road use.
Certainly an option, although less widely available than Millers CFS/NT
Is there anything in its makeup that should sway me towards the Millers equivalent?
http://www.millersoils.co.uk/pdf/datasheets/CFS-10w50.pdf
Re: Rock oil carbon [Re: Cornershop] #4559886
10/31/17 07:10 AM
10/31/17 07:10 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Rock Oil I know and it has been around for decades.
Millers I don't know, but it uses the words "synergistic" and "nanotechnology" which always sounds a bit try-hard to me. It could be a good oil, I just don't know.
What is wrong with a few well known classics like M1 15W-50 or Castrol Edge 10W-60 ? They both have a solid reputation.
Same with Valvoline VR-1 available as 5W-50, 10W-60 and 20W-50 in Europe.
https://www.valvolineeurope.com/english/products/engine_oils/vr1_racing
Re: Rock oil carbon [Re: Cornershop] #4560161
10/31/17 11:54 AM
10/31/17 11:54 AM
UK
UK
M1 15w/50 is no more in the UK, and replaced with 15w/60 AFAIK; I don't believe a /60 is justified.
A 5w50 may well be an option after the run in completes.
Maybe I should just stick to the tried and tested, however I'm a sucker for new oil developments smile
Found this on the Rock oil site: http://www.rockoil.co.uk/cm/images/pdf/techdata/rock-oil-carbon-series-test-data.pdf
Re: Rock oil carbon [Re: Cornershop] #4560410
10/31/17 05:12 PM
10/31/17 05:12 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Interesting, it looks like RockOil measured their product against a "Nanotechnology" oil which didn't perform as well as all the buzz words suggest it would. I like hard testing with real numbers over buzz words. I suspect one of their test may have been the old one armed bandit wear scar test, which isn't that related to motor oil performance. Still given the choice of RockOil and Millers nanotechnology, my vote is for RockOil.
BTW you have an air cooled Porsche, correct ?
I believe Porsche have their own brand 20W-50 oil for that and there is a VOA (virgin oil analysis) for it floating around here somewhere. I'll try and dig it up. Makes me think the VR-1 20W50 would be a good choice. Those VR-1 oils are all A3/B4 rated with a high TBN and high ZDDP (zinc).
Re: Rock oil carbon [Re: Cornershop] #4560413
10/31/17 05:17 PM
10/31/17 05:17 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
