Originally Posted By: Linctex
Originally Posted By: Izb
99% at 30u is about 95-97% at 20u
Isn't that about the same as a Napa Gold / Wix?
People on here bash them because they "don't filter fine enough".
IMO, 95% @ 20 microns is still pretty decent filtering efficiency. I like using oil filters that are that or higher.
The "they don't filter fine enough" is probably referring to the WIX XP which is rated at 50% @ 20 microns.
OK, here's the rationale - - if the holes in the media are bigger (less efficiency) then NATURALLY it'll go for the higher miles, because it can't plug if it's still flowing.
I'll take the better efficiency of the Ultra
The part in red is mainly true for cellulose or cellulose blend media. But for full synthetic media the efficiency can be very high as well as the holding capacity (ie, mileage use recommendation) - ie, Ultra and others.
