MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
93 registered members (aquariuscsm, bfleeman, ArrestMeRedZ, BeerCan, aba4430, 9 invisible), 1,396 guests, and 37 spiders.
Topics295,053
Posts4,926,900
Members66,677
Most Online2,553
Oct 27th, 2018
Fighting leaks with alloy wheels #4556422
10/27/17 03:51 PM
10/27/17 03:51 PM
Northern Kentucky
901Memphis Offline OP
Northern Kentucky
I keep having pretty significant leaks on my Buick where the tires meet the alloy wheels. I'm dropping down to less than 20 psi in maybe a week. I get my tires rotated and balanced for free at tire discounters as part of the package I bought when I got them installed. About every other time I go for rotation I tell them and they will usually grind the inside of the wheels and it seems to help for a few months but always comes back. I have been wondering if there's anything else I can do. I don't think I will be able to get the tire shop to do anything differently so I just wanted to hear some ideas.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556430
10/27/17 04:03 PM
10/27/17 04:03 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
Fill them with inflate- a-flat, that should fill any gaps where the air is leaking out.,,,
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556435
10/27/17 04:09 PM
10/27/17 04:09 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Very strange grinding on wheels so they won't leak. I've had Mag wheels since the late 60's I've never had a set leak?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556441
10/27/17 04:17 PM
10/27/17 04:17 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
A good tire place will have a bead sealer. They brush it on where the bead goes and it fills in the gaps.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Fighting leaks with alloy wheels [Re: JohnnyJohnson] #4556449
10/27/17 04:27 PM
10/27/17 04:27 PM
Northern Kentucky
Northern Kentucky
I was told there's corrosion causing the problem because of salt/snow which is why they are grinding it. I haven't asked if they use a bead sealer yet.
The only thought I had was using slime,but wanted to hear opinions first.
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556454
10/27/17 04:34 PM
10/27/17 04:34 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
My 98 Sienna had the same issues. I would take it back to Costco they would reseal the bead and it would leak. Not down 10 psi in a week, but enough leaking in a two week span. Got different rims later on from Kijiji along with tires. Sold the van within a year.
Good luck trying to get it fixed.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Fighting leaks with alloy wheels [Re: JC1] #4556464
10/27/17 04:48 PM
10/27/17 04:48 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I would like to see this "grinding" process. ...a good stout polishing?
Also, A pal uses bead sealer (NAPA brand) on his twuck rims. The stuff dries hard.
I wonder how you clean it off when tire time comes.
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556468
10/27/17 04:54 PM
10/27/17 04:54 PM
ME
eljefino Offline
eljefino  Offline
ME
Either a wire wheel or aggressive scotchbrite pad/ sandpaper will polish the rim so it seals. I imagine the factory has a "top coat" that's more corrosion resistant.
You shouldn't need a "good" tire shop to get that bead sealer goo; crummy shops have it and I have a can in my garage. link. It brushes on and grinds off with the same technique used to remove rust. You can also very carefully remove it from the tire, too.
Re: Fighting leaks with alloy wheels [Re: JC1] #4556474
10/27/17 04:59 PM
10/27/17 04:59 PM
Wet side WA
Wet side WA
I'm surprised they haven't offered to sell him a new set yet!
2004 Corolla 126813
2006 Duramax 74478
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556484
10/27/17 05:10 PM
10/27/17 05:10 PM
pa
benjy Offline
benjy  Offline
pa
castings can have pinholes in them as my 64 vette reproduction knock offs did, i shellacked them + the leaks were gone!!
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556485
10/27/17 05:10 PM
10/27/17 05:10 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Never use "Slime". That stuff is designed to be used in an emergency and has been known to cause permanent damage to wheels and tires.
As for the Buick, I'd suggest finding a decent set of steel wheels and be done with it.
If they aren't visually appealing to you, there's many plastic hubcap options available.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556494
10/27/17 05:22 PM
10/27/17 05:22 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Find a real tire shop who will apply sealer … every once in a while I go to our Goodyear store to sort something DT blessed me with … it’s like moving from 7th grade to grad school …
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556502
10/27/17 05:26 PM
10/27/17 05:26 PM
iowa
Traction Offline
Traction  Offline
iowa
Bead leaks are my worst nightmare after dealing with thousands of them! I don't even know where to start on the issue. German car wheels never have this issue, among a few other others. But there are many more that are not even 3 years old that are so corroded from salt it would make your head spin. And it always starts on the never washed read bead seat, while the front bead is perfectly clean. The best permanent fix is to sand clean, and simply brush on epoxy primer, which would be one of many ideas I have. Believe it or not, but Nitrogen helps a lot! I've been filling tires with N2 for over 17 years now.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556531
10/27/17 05:53 PM
10/27/17 05:53 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Yes bead sealer. They brush it on around the rim. Looks like liquid rubber.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Fighting leaks with alloy wheels [Re: 901Memphis] #4556533
10/27/17 05:55 PM
10/27/17 05:55 PM
iowa
Traction Offline
Traction  Offline
iowa
Just to add, to clean up the beads on 4 16 inch wheels, it is over 33 feet of surface area to deal with.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
