CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
71 registered members (antik, alarmguy, 4WD, Amenhotep, Anthony, 2015_PSD, 8 invisible), 861 guests, and 30 spiders.
Topics287,675
Posts4,932,071
Members67,838
Most Online2,967
Mar 10th, 2019
1000 miles on oil #4556216
10/27/17 11:59 AM
10/27/17 11:59 AM
Minnesota
2010Civic Offline OP
Minnesota
I will be putting my car into storage soon. I have always changed the oil and filter right before putting it away. Well this time around the snow is already here and I only have 1000 miles on my synthetic oil and Honda filter. I'm considering not changing it as it is still quite new. The car is driven primarily to work and back (21 miles each way) so it isn't short tripped.
What do you think?
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: 1000 miles on oil [Re: 2010Civic] #4556217
10/27/17 12:00 PM
10/27/17 12:00 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
1000 miles isn't very many miles to deplete the ph.
2015 F150 2.7
2018 F350 6.2
Re: 1000 miles on oil [Re: 2010Civic] #4556227
10/27/17 12:11 PM
10/27/17 12:11 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Leave the oil in there. 1000 miles is nothing for a synthetic.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 1000 miles on oil [Re: 2010Civic] #4556232
10/27/17 12:14 PM
10/27/17 12:14 PM
Imperial Valley, California
Jeffs2006EvoIX Offline
Yeah leave it in there, it will be fine. As many have suggested before on other posts, might be wise to put some fuel additive in the tank. The oil though should be fine, dont waste your money.
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: 1000 miles on oil [Re: 2010Civic] #4556238
10/27/17 12:20 PM
10/27/17 12:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Are you storing the car to save it from the salt ?
Re: 1000 miles on oil [Re: 2010Civic] #4556253
10/27/17 12:34 PM
10/27/17 12:34 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
You want clean oil to sit in the bottom of the oil pan?
Leave it alone
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 1000 miles on oil [Re: Merkava_4] #4556264
10/27/17 12:42 PM
10/27/17 12:42 PM
Minnesota
Minnesota
Yes, Minnesota loves to salt! That junk destroys cars.
I'll leave the oil in there.
2010 Honda Civic LX
59,992 miles
Re: 1000 miles on oil [Re: 2010Civic] #4556280
10/27/17 12:58 PM
10/27/17 12:58 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
Don't forget to put a battery tender on you battery. Nothing kills a battery faster than a full discharge.
Re: 1000 miles on oil [Re: 2010Civic] #4556331
10/27/17 02:33 PM
10/27/17 02:33 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
How do you know when it's safe to bring the car out of storage and start driving the car again ?
Can you visually see when there's no more salt on the roads ?
Re: 1000 miles on oil [Re: Merkava_4] #4556340
10/27/17 02:44 PM
10/27/17 02:44 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
Yes you can see the whitish salt stains on dry roads. A couple good spring rains will clean all the salt from the roads
Re: 1000 miles on oil [Re: 2010Civic] #4556347
10/27/17 02:50 PM
10/27/17 02:50 PM
Ontario, Canada
AdamZ Offline
AdamZ  Offline
Ontario, Canada
I do the same thing with 2 of my cars. They will just rot into the ground if you drive in the winter here.
I always leave the oil and change it in the spring, if warranted by mileage. Otherwise I just run it.
94 Nissan Pathfinder 493k km R.I.P.
95 Nissan Pathfinder 200k km
02 Nissan Xterra SC 170k km
04 VW Golf 2.0 245k km
Re: 1000 miles on oil [Re: 2010Civic] #4556366
10/27/17 03:06 PM
10/27/17 03:06 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
You probably have 80-90% of the original TBN still in that oil. It will be fine. Change it again at the beginning of next summer...or even next Sept/October.
If it gives you peace of mind, change it after the next set of rains washes the roads clear of sand/salt. Then a final drive(s) before parking it.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: 1000 miles on oil [Re: 2010Civic] #4556368
10/27/17 03:08 PM
10/27/17 03:08 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
well, my brother is about to put his 2015 Chally back into storage for the 2nd winter in a row,(just moved back here to the salt belt in mid '16) and it still has the FF in it. (less than 2500mi on the odometer.)
he keeps waffling back and forth on just selling it....
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: 1000 miles on oil [Re: 2010Civic] #4556421
10/27/17 04:51 PM
10/27/17 04:51 PM
Minnesota
Minnesota
This is the 4th winter I've put it in storage so I have a pretty long checklist of things that I do.
Yeah, salt will make the roads white so it is very easy to see if it's on there or not. I usually wait for a couple good rainfalls before I take it out.
Last winter I had about 2200 miles on the oil and I went ahead and changed it but at only 1000 the oil still looks new.
2010 Honda Civic LX
59,992 miles
Re: 1000 miles on oil [Re: 2010Civic] #4556514
10/27/17 06:37 PM
10/27/17 06:37 PM
so if you store your car for the winter, what do you drive in the winter then?
Just Curious.
Jeff
