Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
90 registered members (4WD, 2008wrx, 10ecfarmer, 08z06, 1nighttrain, 8 invisible), 1,858 guests, and 38 spiders.
Topics290,888
Posts4,851,918
Members66,047
Most Online3,590
Jan 24th, 2017
Piston Soak for reducing oil consumption #4555680
10/26/17 09:46 PM
10/26/17 09:46 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Hi everyone, I have a 285k miles 01 Corolla with a 7AFE engine that is consuming oil. At the 250k miles the engine has overhauled with new piston & rings, bearings, gasket and seals but the block wasnīt bored in a machine shop because it looked in good shape, it didnīt had any ridge in the top part of the cylinders. At 273k miles the engine overheated because of a faulty radiator cap, it bent the cylinder head and whe had to send it to a machine shop so it would be flat, we changed all the gasket of the cylinder head including the valve stem seals.
The engine has always used 20w50 oil and it consumed 0.8 qts every 1k miles, then I began to read in this forum that thick motor oil isnīt always the best so I decided to give HDEO 15w40 a try and now the engine is consuming 1.1 qts every 1k miles. Iīm planning to do 1 more oil change using an HDEO 15w40 to see if the extra detergents help clean the engine (which isnīt very dirty by the way, but cleaner is always better) and then I want to try the old 20w50 again to see if it lowers the oil consumption.
What I wanted to know is if you think that a piston soak could help me to reduce the oil consumption rate? What I think is that the new rings have only 2-3 years and 35k miles, my guess is that they arenīt stuck, I think that the real problem is that they lost flexibility in the last overheat which happened at 273k miles. Would a piston soak help me?
The valve seals have only 12k miles and I dont see any signs of worn valve seals, the PCV valve was checked in less than 3k miles ago and it wasnīt blocked and it sounded like it should when I shaked it, I could even blow with my mouth and it let the airflow go to one side and it caused a restriction sucking (just like it should, because it is like a check valve). I also cleaned it.
What products would you recommend to do a piston soak? Iīm in Venezuela so the products that you might use arenīt avaible here, what I have in mind to use is:
- Injector Cleaner
- Kerosene
- Diesel
- Carburetor Cleaner
- Acetone
- ATF
- Engine Flush for oil
I recently took the spark plugs out to see the piston tops and they look very shiny, they have just little pieces of carbon in them, I think is because they are only 35k miles old.
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555683
10/26/17 09:49 PM
10/26/17 09:49 PM
Emanuel Offline OP
Emanuel  Offline OP
Do you think that a water treatment thru the throttle body could help with oil consumption?
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555685
10/26/17 09:53 PM
10/26/17 09:53 PM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
Any Berryman B-12 Chemtool available? That would do it. Otherwise, a combination of acetone and carburetor cleaner would do it too--IF the rings are sticking or stuck.
2018 MB AMG GLC43 3.0L Coupe - Castrol 0W-40/Purflux
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 15W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555688
10/26/17 09:55 PM
10/26/17 09:55 PM
Emanuel Offline OP
Emanuel  Offline OP
Could my PCV Valve be worn even if its sealing the air flow from the intake manifold to the crankcase but it is letting the air flow pass from the crankcase to the intake manifold? Itīs also making a clicking noise when I shake it. Can it be worn even this conditions?
Itīs a metalic one, but I must have a lot of thousands of miles.
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555707
10/26/17 10:11 PM
10/26/17 10:11 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
You say it was not bored in a machine shop, because it looked good. Does that mean a machine shop checked it, or it looked good and you did not take it in?
If the bores are not round anymore, or the hone finish is not correct for the ring type( cast, moly etc) that could be the problem. Its possible that the overheat scored the cylinders as well.
If i was going to do a piston soak, I use a strong solvent like Berryman b-12. I'd want some oil in there too. The solvents could wash all the oil off the rings and cylinder causing wear.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555709
10/26/17 10:13 PM
10/26/17 10:13 PM
Georgia
AVB Offline
AVB  Offline
Georgia
If the problem isn't the pcv valve then my guess is going to be the block not the rings.
Re: Piston Soak for reducing oil consumption [Re: 2015_PSD] #4555710
10/26/17 10:16 PM
10/26/17 10:16 PM
Emanuel Offline OP
Emanuel  Offline OP
Thanks for your answer.
No, it isnīt but I will try to find an equivalent product.
Do you think is safe for the block and piston to use that?
How can I know if they are sticking or stuck?
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555713
10/26/17 10:19 PM
10/26/17 10:19 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
Berrymans is a mix of 80-90% acetone and 10% toluene, maybe you can get those and make a mix.
Re: Piston Soak for reducing oil consumption [Re: spasm3] #4555715
10/26/17 10:21 PM
10/26/17 10:21 PM
Emanuel Offline OP
Emanuel  Offline OP
I think that not round cylinders can be the real problem, I donīt think the overheat scored the cylinders.[/quote]
Couldnīt I add motor oil after the treatment? Or should I add oil with the treatment?
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555717
10/26/17 10:23 PM
10/26/17 10:23 PM
Emanuel Offline OP
Emanuel  Offline OP
Couldnīt I add motor oil after the treatment? Or should I add oil with the treatment? [/quote]
I mean adding oil to the cylinders after the solvent dries up
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555719
10/26/17 10:24 PM
10/26/17 10:24 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
If you are going to spin the engine over some with the solvent in there, add it after the solvent but before spinning the pistons up and down.
If you are not going to spin the engine with the solvent. Add the solvent, let it sit then add oil before putting the plugs back in and firing it up.
Re: Piston Soak for reducing oil consumption [Re: spasm3] #4555779
10/26/17 11:20 PM
10/26/17 11:20 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Berryman B-12 Chemtool is just acetone, toluene, and maybe a little lacquer thinner
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555783
10/26/17 11:23 PM
10/26/17 11:23 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I wouldn't think a recently overhauled engine would need a piston soak.What is the compression like? Just keep on top of the oil loss. I learned to carry a few qts in the trunk. I would start using 20w50 oil and check the stick frequently. Thats how it used to be. Fill it up and check the oil.
Thick oil is better grin2
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4555874
10/27/17 05:13 AM
10/27/17 05:13 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
The engine is worn , what is the engines compression?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Piston Soak for reducing oil consumption [Re: Emanuel] #4556040
10/27/17 09:07 AM
10/27/17 09:07 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Stuck rings doesn't sound especially likely in this case.
If I thought I had stuck rings, I'd do a soak with DOT3 brake fluid, then I'd follow that up with a water treatment. Alternate that a few times and then change the oil (probably for the thicker stuff.)
My cars starting to run on a bit after switching off, so I'll do a water treatment fairly soon. Probably won't do a brake fluid soak because I don't especially suspect stuck rings and I don't want to change the oil yet.
