Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
83 registered members (4WD, 69GTX, 28oz, Anduril, 240_Ed, 11 invisible), 1,925 guests, and 41 spiders.
Topics295,019
Posts4,926,198
Members66,666
Most Online2,553
Oct 27th, 2018
vehicle ramp or jack stand + jack #4555271
10/26/17 02:49 PM
10/26/17 02:49 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
looking to make it easier for me to change fluids. my truck is a 2007 escalade ext so weighs about 5800 lbs.† thinking about buying two ramps to make it easier to change oil and such. Can choose between
Spectre Pro Ramp: 2 ramps are good for 6000 lbs : $44
or the Rhino Ramps: 2 ramps are good for 8000 lbs I believe $80
I feel like ramps are easier then a jack and jack stand. What do you guys think? and what is the safest. I'm only gonna be doing front diff and oil changes, nothing else aha. So I feel like a ramp is easiest.
Spectre ramp seems like it will get the job done, what do you guys recommend? don't really think I need to spend more for the rhino ramps
a jack stand and 3 ton jack kit is probably gonna be around $120 +
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555278
10/26/17 02:55 PM
10/26/17 02:55 PM
California
Kool1 Offline
Kool1  Offline
California
Personally I would buy a jack and stands. Sometimes you may want the wheels off to rotate the tires, do a brake job, etc.
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555292
10/26/17 03:03 PM
10/26/17 03:03 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Unijack
Re: vehicle ramp or jack stand + jack [Re: Kool1] #4555302
10/26/17 03:10 PM
10/26/17 03:10 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
thanks for the reply! but I literally will never touch anything else tbh ahah. ill never do anything wheel related. just fluids.
what do u think in my case
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555312
10/26/17 03:23 PM
10/26/17 03:23 PM
Perris, CA
Anduril Online content
Anduril  Online Content
Perris, CA
I have both. If it's just a fluid change or something where the wheels don't have to come off, I use the ramps because they're much easier. If a wheel has to come off, then I use a jack. If it's getting my car level to check the transmission fluid level after an ATF change, while still being high enough off the ground to access the stupidly-designed "check plug," it's the front wheels on ramps and the back on jack stands.
Since I do all the work on our three cars, one of these might be in my future.
EDIT: I would not use 6k rated ramps for a 5,800 lb vehicle. The ones I have (plastic "Rhino" ramps) are rated for 12,000 lbs and I just looked and they're available for $40. I, too, doubted if the plastic would hold up over time, but I've had them for 10+ years now.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555315
10/26/17 03:32 PM
10/26/17 03:32 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
I have the same ones, last forever and are great for oil change's...If you shop around you may find them cheaper...
https://www.amazon.com/Nicky-Nice-Solid-Steel-Auto/dp/B00Q1F20BU
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive185k miles
Last Change;
50/50 QSUD, QSHM. 5w30
Fram XG8A, Fram CA8141
Currently under the influence of oil shocked2
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555330
10/26/17 03:46 PM
10/26/17 03:46 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
I believe the rating on the ramps is 6000 pounds per ramp, which would mean for a 6000 pound vehicle it would only be about 1500 pounds ( assuming a 50-50 front to rear weight ratio LOL )
In any case, if it is just fluids then save yourself some trouble and $$ and get the ramps. I have had both, and the ramps make it so much simpler.
Thick vs Thin test: 15k / 43k miles complete
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555333
10/26/17 03:48 PM
10/26/17 03:48 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'd suggest getting the 12,000 or 16,000lb rhino ramps for your vehicle as well. I'd be pretty confident that the 6000lb ramps would probably work, considering it'll never be taking the full weight of the car, but, at least in the US, the 12,000lb and 16,000lb Rhino Ramps are commonly available for pretty cheap, in the $40 range (USD).
Also, I believe the higher weight rated ramps are wider, which might make it easier to get a vehicle with large tires centered.
Re: vehicle ramp or jack stand + jack [Re: EdwardC] #4555334
10/26/17 03:50 PM
10/26/17 03:50 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
My edit time ran out; agree with this though, I got my Rhinos for about $40 each and they are 10,000 pounds if I remember correctly.
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555355
10/26/17 04:10 PM
10/26/17 04:10 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555358
10/26/17 04:15 PM
10/26/17 04:15 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Good deal but look to be sold out frown
Pete.
Last Change;
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555360
10/26/17 04:18 PM
10/26/17 04:18 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Hey gang, be careful about how the ramps are weight rated. From this site:http://allgaragefloors.com/5-best-car-ramps/
"When reviewing weight ratings or load carrying capacity of car ramps, itís important to understand what they actually mean. As an example, car ramps with a GVW weight rating (Rhino) and car ramps with a single axle weight rating (Spectre) mean two different things.
A GVW (gross vehicle weight) rating does not mean that the ramps will hold all that weight. It means that the ramps are designed to lift and hold up one half of a vehicle that weighs up to that much. In other words, a 12,000 pound GVW rating means the ramps will hold up to 6,000 pounds for the pair.
A single axle weight rating for car ramps means just what is says. As an example, a 3,000 pound single axle rating means that the ramp pair will hold up to 3,000 pounds safely.
Always keep in mind weight bias for vehicles as well. If you are lifting the front of a 3,500 pound front wheel drive car, you can almost guarantee that the front of the vehicle actually weighs more than the back."
The weight capacity of the Rhino Ramps is kind muddled if you ask me. One half of the GVW, but the front weighs more than the back. Hmmmm...
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555373
10/26/17 04:37 PM
10/26/17 04:37 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
I use both and sometimes two jacks and jack stand load sharing
You can make good ramps from 2x10ís but should glue and screw from standard wood and keep stored inside
(Treated lumber does not glue as well) Ö
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: vehicle ramp or jack stand + jack [Re: 4WD] #4555490
10/26/17 05:51 PM
10/26/17 05:51 PM
ME
eljefino Offline
eljefino  Offline
ME
^^ THis. Ramps are great because you're not nicking the paint on your undercarriage or putting mini-dents in its "pressure points". And the truck sits how it normally sits. But I would go heavier dutier for that truck such as the example lumber.
Re: vehicle ramp or jack stand + jack [Re: apollo18] #4555507
10/26/17 06:00 PM
10/26/17 06:00 PM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Both jack, stands and ramp. They are nice tools to have
2015 Ford F150 2.7
2018 Ford F350 6.2
