Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
112 registered members (2009Edge, ArrestMeRedZ, ARB1977, 69GTX, 28oz, aquariuscsm, 12 invisible), 2,019 guests, and 38 spiders.
Topics295,028
Posts4,926,354
Members66,669
Most Online2,553
Oct 27th, 2018
RP Thermyl-Glyde 150 #4555136
10/26/17 12:02 PM
10/26/17 12:02 PM
Monroe,CT
Bambam Offline OP
Bambam  Offline OP
Monroe,CT
OIL ANALYSIS REPORT
WEAR ABNORMAL
CONTAMINATION SEVERE
FLUID CONDITION ABNORMAL
Machine Id
FST 2 (S/N )
Component
WESTECH 105 Gearbox
Fluid
ROYAL PURPLE THERMYL-GLYDE 150 (10 GAL)
Report Id: [WUSCAR] 04310091
Test UOM Method Limit/Abn Current History1 History2
Sample Number RP181674 --- ---
Sample Date 06 Sep 2017 --- ---
Machine Age hrs 8800 --- ---
Oil Age hrs 8800 --- ---
Filter Age hrs 0 --- ---
Oil Changed Not Changd --- ---
Filter Changed N/A --- ---
Sample Status SEVERE --- ---
Iron ppm ASTM D5185 >200 252 --- ---
Chromium ppm ASTM D5185 >15 2.0 --- ---
Manganese ppm ASTM D5185 1.5 --- ---
Nickel ppm ASTM D5185 >15 0.5 --- ---
Titanium ppm ASTM D5185 0.0 --- ---
Silver ppm ASTM D5185 0.3 --- ---
Aluminum ppm ASTM D5185 >25 2.9 --- ---
Lead ppm ASTM D5185 >100 0.0 --- ---
Copper ppm ASTM D5185 >200 4.1 --- ---
Tin ppm ASTM D5185 >25 0.0 --- ---
Vanadium ppm ASTM D5185 0.0 --- ---
White Metal scalar Visual NONE LIGHT --- ---
Babbitt scalar Visual NONE NONE --- ---
Silicon ppm ASTM D5185 >50 7.8 --- ---
Potassium ppm ASTM D5185 >20 6.0 --- ---
Water % ASTM D6304 >0.2 1.37 --- ---
ppm Water ppm ASTM D6304 >2000 13700 --- ---
Silt scalar Visual NONE NONE --- ---
Debris scalar Visual NONE NONE --- ---
Sand/Dirt scalar Visual NONE NONE --- ---
Appearance scalar Visual NORML MILKY --- ---
Odor scalar Visual NORML NORML --- ---
Emulsified Water scalar Visual >0.2 1.0% --- ---
Sodium ppm ASTM D5185 2.9 --- ---
Boron ppm ASTM D5185 9.0 --- ---
Barium ppm ASTM D5185 2.5 --- ---
Molybdenum ppm ASTM D5185 0.0 --- ---
Magnesium ppm ASTM D5185 0.8 --- ---
Calcium ppm ASTM D5185 12 --- ---
Phosphorus ppm ASTM D5185 108 --- ---
Zinc ppm ASTM D5185 1034 --- ---
Sulfur ppm ASTM D5185 9303 --- ---
Acid Number (AN) mg KOH/g ASTM D974 1.5 0.545 --- ---
Visc @ 40C cSt ASTM D445 150 646.0 --- ---
RECOMMENDATION
We advise that you check for the source of water entry. We
recommend that you drain the oil from the component if this has not
already been done. We recommend an early resample to monitor this
condition. Please note that there was too much water present in the oil
to perform an accurate viscosity test.
WEAR
Gear wear is indicated.
CONTAMINATION
There is a high concentration of water present in the oil.
FLUID CONDITION
The oil is no longer serviceable due to the presence of contaminants.
Page 1 of 2
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo XLE 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
Re: RP Thermyl-Glyde 150 [Re: Bambam] #4555145
10/26/17 12:10 PM
10/26/17 12:10 PM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
That is about 18oz or more water.
Which would explain high iron.
What operating conditions..
The real takeaway here is the water in the oil needs corrected.
Re: RP Thermyl-Glyde 150 [Re: Bambam] #4559093
10/30/17 08:11 AM
10/30/17 08:11 AM
Monroe,CT
Bambam Offline OP
Bambam  Offline OP
Monroe,CT
Slow moving gearbox over a large tank of water, sun beats on it all day, water cools it from underneath. We typically pull 3 to 5 gallons of condensate out per week in the summer, 1 to 2 during cooler months. It's the evil of this set-up, not sure there is a fix??
Re: RP Thermyl-Glyde 150 [Re: Bambam] #4559813
10/31/17 04:29 AM
10/31/17 04:29 AM
Monroe,CT
Bambam Offline OP
Bambam  Offline OP
Monroe,CT
Viscosity is at 646, which is way out of range for a 150 !
