Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
92 registered members (BamaE92, ARCOgraphite, billt460, Bailes1992, andyd, 14 invisible), 1,750 guests, and 67 spiders.
Topics286,446
Posts4,908,449
Members67,626
Most Online2,967
Mar 10th, 2019
bi pod for DELTON AR15 ECHO 316 #4555068
10/26/17 11:58 AM
10/26/17 11:58 AM
NEPA
shrooms Offline OP
shrooms  Offline OP
NEPA
Hello, everyone!
What bi pod and adapter would you recommend for this baby?
https://www.cdnnsports.com/delton-ar15-echo-316-556-nato.html#.WfISG-PKs3U
2002 Mazda MPV. PUP 5W20, Fram XG2, Dex VI
2001 Honda Civic HX. M1 EP 5W20, Fram XG3717
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4555127
10/26/17 12:56 PM
10/26/17 12:56 PM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
Your best bet would be to swap out the stock forend for a 4 rail design. Like this one from Midwest Industries, that will replace a standard Delta Ring forend. They are well made, easy to install, and don't move around or rattle. From there you can attach the mount and bipod of your choice. There are literally dozens. They come in Carbine, Mid Length, and Rifle length, (20").
http://www.jgsales.com/midwest-industrie...15-p-57853.html
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4555843
10/27/17 02:24 AM
10/27/17 02:24 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Cheap route is the Harris HB5 adapter for the factory plastic handguards on M4 rifles. Or you could use a Magpul handguard, which has MLOK attachment points, in which case you could use any one of the hundreds of MLOK bipod adapters.
http://www.harrisbipods.com/HB5.html
Magpul handguard with MLOK adapter by IWC
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4556057
10/27/17 09:24 AM
10/27/17 09:24 AM
NEPA
shrooms Offline OP
shrooms  Offline OP
NEPA
Great!
Ok, a bi pod with notches or not?
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4556072
10/27/17 09:38 AM
10/27/17 09:38 AM
Glendale, Arizona
Glendale, Arizona
Originally Posted By: shrooms
Great!
"Notches"??
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4556074
10/27/17 09:40 AM
10/27/17 09:40 AM
Glendale, Arizona
Glendale, Arizona
I would say those add on studs, when placed on a plastic forend are OK for a sling.... But not for a bipod. They're just not rigid enough. And they can become loose too easily.
Re: bi pod for DELTON AR15 ECHO 316 [Re: billt460] #4556128
10/27/17 10:27 AM
10/27/17 10:27 AM
NEPA
shrooms Offline OP
shrooms  Offline OP
NEPA
Ok, I didn't explain myself well. Sorry.
This is what I meant. Bi pods with LEG notches and those without. The ones with leg notches have 1 inch increments. Without, the legs travel smoothly to your desired length. Was wondering what most were prefer.
Re: bi pod for DELTON AR15 ECHO 316 [Re: billt460] #4556172
10/27/17 11:04 AM
10/27/17 11:04 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I disagree. How rigid does a bipod and stud need to be on a .223 rifle? Those studs are more than adequate for bipod use.
Re: bi pod for DELTON AR15 ECHO 316 [Re: bubbatime] #4557548
10/28/17 06:32 PM
10/28/17 06:32 PM
Glendale, Arizona
Glendale, Arizona
It's not the caliber. That has nothing to do with it. It's the fact shooters apply a lot of front to back lateral motion to a bipod, as they tuck the weapon into the shoulder, setting up the shot and acquiring the sights on target. Depending on the make of the bipod, this pushing and pulling applies a lot of leverage, that transfers the load from the bipod legs, to the small stud attached to the forend with just a tiny screw. I've seen nice Walnut stocks split along the point where the stud is screwed in from this. (Those cheap plastic forends don't offer any better support). Having a 4 rail metal forend, with an Aluminum Picitinny rail type clamp, (most are at least 1" long), or else a bipod that clamps directly to the rail itself, like this one does, gives the whole set up far more rigidity and strength.
https://www.amazon.com/dp/B06Y2ZZV61/ref=dp_sp_detail?psc=1
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4558517
10/29/17 04:10 PM
10/29/17 04:10 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I would agree that a free floated aluminum rail, with a heavy duty mount and heavy duty bipod, would certainly be more stable and heavy duty. BUT, a person with a $399 AR15 rifle is not going to add a $350 Geissele rail, A $280 Atlas bipod, and a $85 Larue bipod adapter to have the most sturdiest, best built bipod for his first National Match rifle shooting competition at Camp Perry. My advice was tailored to the apparent (assumed) budget of the op. The bipod mounts I recommended are acceptable for those on a budget and are not going to snap off or break at the range when he takes his gun to the range once/twice per year.
Re: bi pod for DELTON AR15 ECHO 316 [Re: bubbatime] #4558608
10/29/17 05:57 PM
10/29/17 05:57 PM
Glendale, Arizona
Glendale, Arizona
.....BUT, a person with a $399 AR15 rifle is not going to add a $350 Geissele rail, A $280 Atlas bipod, and a $85 Larue bipod adapter to have the most sturdiest, best built bipod for his first National Match rifle shooting competition at Camp Perry.
You don't have to spend anywhere near that much for a rigid setup. You can get a good quality Atlas bipod clone for $42.99, like this one. Atlas are horrifically overpriced.
A good machined Aluminum 2 piece, drop in 4 rail forend can be had for $55.00, like this one. You don't even need an adapter because that bipod will bolt right up to it. You're all dialed in for just under $100.00.
https://www.cheaperthandirt.com/product/...pe=&from=fn
Re: bi pod for DELTON AR15 ECHO 316 [Re: billt460] #4558761
10/29/17 08:39 PM
10/29/17 08:39 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Great!
"Notches"??
Bill, that cracked me up. laugh
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: bi pod for DELTON AR15 ECHO 316 [Re: shrooms] #4561191
11/01/17 12:28 PM
11/01/17 12:28 PM
NEPA
shrooms Offline OP
shrooms  Offline OP
NEPA
