Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
37 registered (10WSmuckers, dilberto88, boulderdentist, ArrestMeRedZ, 4WD, clinebarger, 3 invisible), 906 Guests and 28 Spiders online.
65299 Members
67 Forums
285815 Topics
#4554855 - 10/26/17 06:32 AM Rplacing DRL on Tahoe/Suburban/Silverado/GMC
Indydriver Offline
Loc: Indiana
I have a 2007 Tahoe. I bought the replacement bulbs (#3157) and took to UTube to find a how-to. Apparently, you have to open the wheel well cover to loosen a screw that will allow the headlight assembly to move forward a few inches. Then, you have to remove the headlight bracket screws up top plus the top row of fasteners across the radiator shroud in order to allow the whole thing to pitch forward so you can get your hand in behind it to get to the bulbs.
Sound right? Any easier ways in?
2017 Mazda CX3 1000 FF
2014 Camaro 2SS/RS LS3 Vert 13,000 M1
2012 Sienna 75,000 M1
2011 Accord VCMV6 75,000 M1
2007 Tahoe 130,000 M1 HM
#4554928 - 10/26/17 08:39 AM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
64bawagon Offline
Loc: Michigan
What an epic step backwards GM made on the 07 NBS on this repair. The lights on my 2005 are super easy to remove and replace.
05 Duramax Chevy(SOLD), 64 Chevy wagon, 10 Jeep Wrangler, 17 Equinox (rental), 18 Silverado 1/2 ton
#4555012 - 10/26/17 10:41 AM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
03cvpi Offline
Loc: Minneapolis
All the manufacturers are doing it. Just had to put headlamp bulbs in a newer impala, you need to remove the entire front bumper skirt to access the headlamp assemblies. Give me glass sealed beams any day, some of the newer projection lamp housings have almost no side illumination. Can't see the deer until it's right in front of you.
#4555164 - 10/26/17 01:24 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: 03cvpi]
opus1 Offline
Loc: Chicago Area
Originally Posted By: 03cvpi
All the manufacturers are doing it. Just had to put headlamp bulbs in a newer impala, you need to remove the entire front bumper skirt to access the headlamp assemblies. ...
Same with my Cobalt.
Hyundai, at least on my model, made it very easy to change. Remove some screws, unplug the harness and the whole assembly comes out. Screw off a cap protecting the bulb, change it and reverse the process. Now why they went with the more expensive and rarer H11B bulb vs the H11...
Current Fleet:
2010 Hyundai Sonata GLS
2009 Chevy Cobalt SS Sedan (yes,the turbo)
2002 Dodge Dakota SXT Club Cab
1994 Ford Ranger XLT (RIP, Dad)
#4555797 - 10/26/17 11:50 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
901Memphis Offline
Loc: Northern Kentucky
Better make sure the new bulb works before you button everything back up haha
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4556390 - 10/27/17 03:34 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
Indydriver Offline
Loc: Indiana
Well, I got it replaced. I had to go back and watch the vids on a couple of points. Turns out I didnít need to disturb the wheel well cover because that lower flange of the headlight assembly was broken off by a prior intruder so the bolt was holding nothing. Knowing this will save me an hour next time. So you end up removing the 8 bolts on top-2 holding the head light assembly and six across the radiator shroud. This allows you to pop the end of the bumper cover off and everything is loose enough to wiggle the entire assembly out for easy access to the bulbs. I could probably do this repair in 30 minutes next time.
#4558855 - 10/29/17 10:22 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
NYEngineer Offline
Loc: NY, NY
Someone did that to my brother's 07 Tahoe
I do my Suburban by removing the screw on the bottom front of the wheelwell and pop two of those plastic push fasteners, then I reach in with a socket on a long extension to get the bottom bolt
#4562247 - 11/02/17 04:50 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
yugrus Offline
Loc: ON, Canada
Yeah, that's a pain, but you don't have to remove the whole wheel well liner, as mentioned above. I used LEDs for DRL, hope they will last forever. And replaced H11 with H9. Now I can actually see something at night...
'14 Chevrolet Tahoe
'15 Mazda CX-5
#4562956 - 11/03/17 12:05 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
Smokescreen Offline
Loc: Alberta, Canada
Yeah...any light that was a pain to get to would get the LED replacement.
09 Corolla 1.8L-370Kkms(231Kmi)-PP,Denso
05 LeSabre 3.8L-210Kkms(131Kmi)-Sopus,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-Sopus,Wix
All with mpg > EPA
#4603870 - 12/14/17 08:26 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: Indydriver]
another Todd Offline
Loc: Lakeside CA
I have an 02 Yukon, on mine I just pull out two large pins and the whole assembly comes out. It was the same on my 00 Silverado. I can't imagine an 07 could be that much different. Literally takes seconds.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
#4614252 - 12/25/17 09:41 PM Re: Rplacing DRL on Tahoe/Suburban/Silverado/GMC [Re: another Todd]
ryster Offline
Loc: Southeastern, PA
The 07 is totally different than the set-up in the 02.
GM loves to make running changes to stuff like this. They did the the same with the Equinox. 2010-2014 had an access panel in the wheel well to get to the headlights. In 2015 they eliminated it, requiring partially removing the wheel well liner to get to the bulbs.
2015 Chevrolet Equinox LT AWD
3.6L V6
