CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
62 registered members (4WD, antik, 87sammy, Anthony, 2015_PSD, A1O, 8 invisible), 774 guests, and 26 spiders.
Topics287,674
Posts4,932,037
Members67,838
Most Online2,967
Mar 10th, 2019
Transfer case and slip yoke #4554817
10/26/17 05:17 AM
10/26/17 05:17 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
So my 2011 F150 has continued to provide the joys of slip bump (despite its the 145in WB with one piece driveshaft which doesn't suffer from that problem). Lubricating the slip yoke splines fixes the problem 100% for a few thousand miles AT BEST. Even going with a moly paste did not fix the problem for longer than that. I'm at the point where its time to consider parts replacements. Basically two options I'm exploring.
1. Raptor transmission mount. Not directly related to the slip yoke, but its supposed to be a more rigid bushing and reduce dirveline vibration and pinion angle changes.
2. Slip yoke and/or transfer case output shaft replacement
I'd like to explore the second option a little. The slip yoke would be as easy as replacing the u-joint, basically. I would think replacements would be easy to find at drivetrain shops. What about the transfer case output shaft? Transfer case would be fairly easy to drop out but is it a big deal to open it up to replace this shaft? I'm really stumped on how these splines are INTENDED to be lubricated from the manufacture, as service info and diagrams have been difficult for me to find. Does anybody have much knowledge on transfer cases? I don't mind doing a little work, but I don't want to waste my time tearing stuff apart and replacing parts that won't help.
FYI, yes I've tried the Ford recommended lubrication (the blue teflon lube, XG-8 I think). It lasts a few thousand miles. So does the white teflon grease they sell with the kit. So does a heavy moly paste. So does a heavy moly paste cut with synthetic ATF. Like I said, I want to explore FIX options now.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Transfer case and slip yoke [Re: buck91] #4554851
10/26/17 06:24 AM
10/26/17 06:24 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
If you don't get good responses here I would try asking your questions at ford-trucks.com. Nothing wrong woth this site, just that you will find a lot more experience with your year F150 at a site specializing in Ford trucks.
Re: Transfer case and slip yoke [Re: buck91] #4554872
10/26/17 06:57 AM
10/26/17 06:57 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Yeah, I actually did double post already 😃
2011 F150 4x4 5.0L
Re: Transfer case and slip yoke [Re: buck91] #4554923
10/26/17 08:30 AM
10/26/17 08:30 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I read that trucks with leaf springs suffer from "Axle Wrap" which binds the yoke splines when accelerating or decelerating, certain conditions, etc. Installing a leaf spring clamp is worth a try before you tear things apart.
If you have leaf springs that is...
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 109k Unk
Re: Transfer case and slip yoke [Re: buck91] #4554944
10/26/17 09:06 AM
10/26/17 09:06 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I had that problem with my Cherokee. The only thing that worked was anti seize compound. Grease didn't seem to do it.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Transfer case and slip yoke [Re: Miller88] #4554947
10/26/17 09:10 AM
10/26/17 09:10 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
+1
Same with mine.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Transfer case and slip yoke [Re: buck91] #4555962
10/27/17 07:25 AM
10/27/17 07:25 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
And, contrary to what a lot of people say, it doesn't wear out the slip joint in the driveshaft or the tailshaft. I eventually converted the transfer case to a fixed yoke, but never managed to wear out anything.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
