How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
Landngroove, DanielH, Cpcz9382, PPWarrior, Robwashere4oil
66698 Registered Users
92 registered members (53' Stude, amblerman, 65f100, 240_Ed, 69GTX, 15 invisible), 2,016 guests, and 39 spiders.
Topics295,157
Posts4,928,848
Members66,698
Most Online2,553
Oct 27th, 2018
Vicosity is 17.4 and SAE rate is 10W-40? #4554753
10/25/17 11:21 PM
10/25/17 11:21 PM
Vietnam
Duy Offline OP
Duy  Offline OP
Vietnam
Hi,
My motorcycle oil Wolver Four Stroke Racing has viscosity grade (100oC) stated at 17,4 cSt. Should it be label as W50 instead of W40. It is a German manufacturer so I don't think they did wrong labeling. Could you guys help to comment ?
http://en.wolverlab.de/catalog/kfz-schmi...cing-4t_28.html
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: Duy] #4554773
10/26/17 12:52 AM
10/26/17 12:52 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Looks like the top end of 40, which is what the link you showed indicates.
https://bobistheoilguy.com/viscosity-charts/
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: Duy] #4554780
10/26/17 01:25 AM
10/26/17 01:25 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
According to the SAE J300 the Xw-40 is <16.3 cSt. If this oil is 17.4 cSt then it would be a Xw-50.
Someone make a mistake someplace with this product or label.
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: Duy] #4554782
10/26/17 01:29 AM
10/26/17 01:29 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Duy,
You are absolutely 100% correct. As its KV100 is > 16.3, this oil is a 10W50, not a 10W40. It seems even the Germans make mistakes these days (did someone say Dieselgate?).
I personally wouldn't use this oil in a motorcycle application as it will contain a very large amount of shearable VII. I would also question whether you need a 10W oil in a hot country like Vietnam. If I were you, I might look for a decent 15W40 oil.
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: ZeeOSix] #4554788
10/26/17 02:36 AM
10/26/17 02:36 AM
Vietnam
Duy Offline OP
Duy  Offline OP
Vietnam
Dear Zoe,
Thank you for your comment. It does make sense, given that the manufacturer trying to make one universal oil for all application.
Thank your very much for enlighten me
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: SonofJoe] #4554789
10/26/17 02:40 AM
10/26/17 02:40 AM
Vietnam
Duy Offline OP
Duy  Offline OP
Vietnam
Dear Sonof, Dear FowVay
Thank you very much for your comment. I'm so confused about the accuracy of the German these day. Given the above comment that it is still in the top end of 40 I would assume it is still somewhat accurate.
I would like to ask more about the 10W. I know that it would be a a waste to use 10W in a our country, but does cause any harm, or can it be any good to use low W, for example, better lubricant pumping at start or better heat transfer ???
Thank you very much for your input
Re: Vicosity is 17.4 and SAE rate is 10W-40? [Re: Duy] #4557942
10/28/17 11:08 PM
10/28/17 11:08 PM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
What motorcycle are you riding? I ride a 2012 Kawasaki ZX-14R (ZZR1400) and the 'normal' oil recommendation is for a 10W-40. Where I live it can be +90F (>32C) during riding season and I'm often stuck in Atlanta traffic. I choose to use 15W-50 BelRay ester oil in my machine because of the heat.
Read your manual and adjust your viscosity grade to your riding temperatures. Use the oil that carries the correct rating (JASO MA/MA1/MA2, etc) and you should be OK.
As for the German oil in question - if their label is false then I'd also question what else on their data sheet is false. I would choose another reputable brand of engine oil.
