BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
57 registered (BeerCan, antik, 4WD, aquariuscsm, Bighorn2500, BigCahuna, 5 invisible), 1044 Guests and 41 Spiders online.
65258 Members
67 Forums
285505 Topics
#4554541 - 10/25/17 07:59 PM 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI
Too3zln Offline
Loc: NEBRASKA
Blackstone lab report for my 2011 Chevy 2500hd 6.6 LML Duramax with 96960 Miles. Oil used was Chevron Delo 15w40 for approximately 14,380 miles, with a Mobil 1-303 oil filter. This is my second report on this vehicle/engine. Oil was changed with Rotella t4 15w40 at time of sample. Iím not worried about slightly elevated potassium but would like to hear from you guys. I will test this sample again next spring when I change the oil filter mid-oci.
2015 Subaru Legacy 19,000 miles
2011 Chevy 2500HD Duramax 98,000 miles
2004 F-150 FX4 5.4 ticker 232,000 miles
#4554645 - 10/25/17 09:47 PM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
JohnnyJohnson Offline
Loc: Wet side WA
These Duramax UOA are scaring the bejesus out of me all their iron number are out of sight!
2004 Toyota Corolla 121525
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4554661 - 10/25/17 10:22 PM 2011 Chevy 2500hd LML Duramax 14,380 mile oci
Too3zln Offline
Loc: NEBRASKA
(duplicate post edited; removed)
dnewton3
Edited by dnewton3 (10/26/17 06:30 AM)
Edit Reason: remove dup post
#4554665 - 10/25/17 10:26 PM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
Too3zln Offline
Loc: NEBRASKA
Mods, I also posted this where it should only have been; in the UOA section, please delete if necessary. Thanks
NOTE- two duplicate threads were started; merged files for one conversation (Mod dnewton3)
Edited by dnewton3 (10/26/17 06:28 AM)
Edit Reason: merged threads
#4554671 - 10/25/17 10:34 PM Re: 2011 Chevy 2500hd LML Duramax 14,380 mile oci [Re: Too3zln]
Loc: Wet side WA
I thought I might try Chevron Delo in my Duramax but not after seeing those iron numbers. Why is it the UOA's I've seen for Chevy diesels show such bad iron readings?
2006 Duramax 74016
#4554680 - 10/25/17 10:43 PM Re: 2011 Chevy 2500hd LML Duramax 14,380 mile oci [Re: JohnnyJohnson]
Too3zln Offline
Loc: NEBRASKA
Until diesels hit the 200,000 mark, i personally do not consider them to have broken in yet. These levels are of no concern to me.
#4554822 - 10/26/17 05:36 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
dnewton3 Offline
Loc: Indianapolis, IN
Overall decent report.
- Fe is not an issue; it tracks with heavy use and miles. Mine was similar level with HARD towing use this past time. This is what happens when a diesel truck is used like a diesel truck, and not a commuting ride. I would presume that the slight uptick in Fe and Al are simply indicators you're loading the engine like it was designed to be used?
- The insolubles are not out of control by any means; they suggest at limit of .6, but when you look at that value and the slightly elevated vis, you're starting to get some oxidation escalation. Not at all harmful at this level; just an explanation as to the effect you're seeing.
- Regarding the K, not sure what to tell you. Need to look into what coolant you're using and see what it's elemental add's are.
GM does not publish condemnation limits, but other major diesel makers and services (DD, Cummins, Chevron, etc) limit Fe between 100-150ppm.
JJ - you need to re-calibrate your scared-o-meter. See page 11:
http://www.calrecycle.ca.gov/Publications/Documents/UsedOil/2008020.pdf
Edited by dnewton3 (10/26/17 06:29 AM)
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
#4554830 - 10/26/17 05:50 AM Re: 2011 Chevy 2500hd LML Duramax 14,380 mile oci [Re: Too3zln]
Bambam Offline
Loc: Monroe,CT
It's a Duramax, the easiest thing on oil known to man !
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
#4555033 - 10/26/17 11:09 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: dnewton3]
Too3zln Offline
Loc: NEBRASKA
I definitely loaded the engine harder the last half of the oci, but not from towing. Going from 90% highway driving while commuting, to driving mostly stop and go city driving, with many of them being short trips not getting up to temp. I drove very spirited, with a few too many full throttle runs. Iím enjoying the tuner I have for the truck.
#4608879 - 12/19/17 11:00 PM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
BlakeB Offline
Loc: Southeast
Any idea how many hours are on this OCI? How many hours/miles total on the truck? We have a 2016 lml, following the OLM I'm going about 7,500 miles and roughly 500 hours between OCI's. I'm using ck-4 delo 400 15w40, I usually have to add about 2 quarts between oil changes.
Edited by BlakeB (12/19/17 11:00 PM)
#4623330 - 01/04/18 04:02 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: BlakeB]
Too3zln Offline
Loc: NEBRASKA
It shows the mileage just shy of 97,000 on the lab report. As far as hours on the OCI, I have no idea. I will look on total hours for the truck in a few hours.
#4623399 - 01/04/18 06:42 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
Too3zln Offline
Loc: NEBRASKA
98268 Miles/2937.8 hours currently on the truck.
#4623696 - 01/04/18 11:07 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: Too3zln]
dnewton3 Offline
pretty typical for your truck; average 33 mph. That's very common; rang is probably 30-40mph as an overall macro range.
my Dmax has 52k miles with 1400+ hours.
Edited by dnewton3 (01/04/18 11:09 AM)
#4624309 - 01/04/18 09:32 PM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: JohnnyJohnson]
loneryder Offline
Loc: WV
You guys are worried about an iron reading of 38 on 14k miles?? My MB v6 diesel had 60ppm iron on 9500 miles running Mobil 1 5-40esp. Testers didn't even flag it. I didn't like it so I've reduced my oci.
#4624519 - 01/05/18 06:04 AM Re: 2011 Chevrolet 2500HD 6.6l Duramax 14,380 OCI [Re: loneryder]
dnewton3 Offline
The most important thing is to understand how any equipment performs in a sense of "normal" wear.
Cutting the OCI down may or may not reduce the wear rate. Never confuse a magnitude of particulate ppm with the rateat which it's generated.
I'm not saying you did anything wrong. But unless you've got substantial, repeatable proof that anything improved in terms of wear rates, you may not have done anything "right" either.
