Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
105 registered members (2018matto, 28oz, 1foxracing, 64bawagon, 01ws666, 2009Edge, 10 invisible), 1,826 guests, and 42 spiders.
Topics294,973
Posts4,925,157
Members66,657
Most Online2,553
Oct 27th, 2018
Storing Ethanol Free Gasoline #4554374
10/25/17 04:12 PM
10/25/17 04:12 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
Every November I buy 15 gallons of ethanol free gas and store it in Eagle Safety Cans with PRI G stabilizer. I keep the gas all winter in case I need to run my generator. I use the gas for mowing in the spring and summer and buy more in November. Given that Eagle cans are air tight and the gas is ethanol free, do I even need stabilizer?
Thanks in advance for any advice.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554375
10/25/17 04:13 PM
10/25/17 04:13 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Yes, It will still help.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554383
10/25/17 04:29 PM
10/25/17 04:29 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Assuming you buy it when it's fresh, premium gas doesn't oxidize as fast as 87 octane.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554430
10/25/17 05:08 PM
10/25/17 05:08 PM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Stabilizer is a scam.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554451
10/25/17 05:24 PM
10/25/17 05:24 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I think PRI-G over hypes their products.
Blue StaBil is a great stabilizer and has a good amount of fuel cleaner.
The stabilizer is cheap enough per gallon of gas. I use stabilized E0 gas year round in OPE.
2015 Ford F250 w/Powerstroke
Re: Storing Ethanol Free Gasoline [Re: Donald] #4554505
10/25/17 06:23 PM
10/25/17 06:23 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Source?
2x on blue Sta-Bil and E0 gas year round in all my OPE
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554536
10/25/17 06:53 PM
10/25/17 06:53 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
I make my own ethanol-free gasoline as needed, a half gallon at a time.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554547
10/25/17 07:03 PM
10/25/17 07:03 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I do the same thing Oldtom. Same cans and all.
Those eagle cans can really hold vapor pressure! I think the mostly airtight environment helps the gas to stay stable.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554727
10/25/17 10:57 PM
10/25/17 10:57 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Probably not. Winter cold is easy on gas.
All through the 60's and 70's we had no ethanol gas, and all our OPE never had any carb gumming issues EVER.
My local E-0 smells just like Avgas. AvGas NEVER goes bad.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4554857
10/26/17 05:35 AM
10/26/17 05:35 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4555300
10/26/17 03:09 PM
10/26/17 03:09 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Here in the north I don't use stabilizers for any fuel. I leave up to 20 gallons of E-10 fuel in plastic fuel containers unheated from October to May. Never had a problem with the fuel in the spring. Still smells fresh and burns just fine in my equipment. Pretty sure the cold temps help preserve it.
I'd probably think/do different in constant warm temperatures.
In the OP's situation I wouldn't bother adding anything to the fuel.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4609751
12/20/17 10:03 PM
12/20/17 10:03 PM
Indiana
Indy2door Offline
Indy2door  Offline
Indiana
Ethanol is what makes [censored] gasoline usable.
Re: Storing Ethanol Free Gasoline [Re: CT8] #4609753
12/20/17 10:04 PM
12/20/17 10:04 PM
Indiana
Indy2door Offline
Indy2door  Offline
Indiana
So is ethanol free gas.
Re: Storing Ethanol Free Gasoline [Re: Oldtom] #4625557
01/06/18 06:20 AM
01/06/18 06:20 AM
Sweden
lars11 Offline
lars11  Offline
Sweden
Sure you had gummed up carbs in 60-70s. Maybe less, but the stability has little to do with ethanol but more to do with cracked gasoline vs distilled gasoline. Gasoline oxidize and cracked fuel oxidize quicker/more. Ethanol does not itself oxidize in gas or leave ant residue or form laquer.
What it may do is absorb water over time and separate which may be cortosive (the water) which may harm say alumium parts. It will also solve some residue and the dirt may cause problems until clean.
I am almost certain that stabilizers were used as far back as ww2, so it is not because of ethanol specifically.
So, to protect fuel you would add stabil to reduce -oxidization- then you would store it in an air tight can to avoid moisture to foul the fuel. This works for gas and E fuel.
So remember, you need to adress TWO processes to conserve fuel, not just one.
