Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
99 registered members (alarmguy, Ag76, 2006dodge2500, 97prizm, aquariuscsm, 13 invisible), 1,836 guests, and 54 spiders.
Topics286,387
Posts4,907,368
Members67,614
Most Online2,967
Mar 10th, 2019
Should O2 sensors be replaced at the same time? #4554326
10/25/17 04:13 PM
10/25/17 04:13 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
Such as both upstream or both downstream? I would think one new one and an old "sluggish" one might not be good.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554328
10/25/17 04:14 PM
10/25/17 04:14 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Don't the downstream ones just monitor emissions?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554332
10/25/17 04:19 PM
10/25/17 04:19 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Dont bother with the down stream ones
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554337
10/25/17 04:23 PM
10/25/17 04:23 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
The downstream ones usually only monitor emissions to make sure the catalytic converter is functioning. In that case its only purpose is to determine whether to set the MIL on or not.
The upstream sensor is the one that determines whether the engine is producing the right emissions and so that's where the control occurs that affects performance and mileage.
Once the emissions are out of the engine and the first/upstream cat determines how to control the engine, the only thing left for the second/downstream sensor to do is determine whether the cat did its job on the emissions. I assume the system was designed this way since there's no point in using both sensors to control the engine. What's the engine supposed to do differently if the cat isn't working and the second sensor doesn't like the ratio? Alter the engine to accommodate a bad cat? Nope. If the emissions from the engine itself were bad, that's something it should handle, if the emissions from engine are fine but past the cat is bad, that's nothing that the engine is responsible for, the cat failed to do its job not the engine. The only thing it can do in that case is just make the MIL light up so you can have the cat (or defective downstream sensor) fixed.
So its only purpose on most if not all vehicles is to say whether the cat is good or bad and therefore turn the MIL on or off. If you're not seeing a MIL I wouldn't bother with the downstream sensor as that's all it would do so changing it won't improve your engine performance or gas mileage or anything.
2015 Civic LX Coupe
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554347
10/25/17 04:37 PM
10/25/17 04:37 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
But should both upstreams be done together to have a correct balance?
** This being on cars at or over 100,000 miles on the sensors.
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554367
10/25/17 05:07 PM
10/25/17 05:07 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Yes. If you have two upstream sensors do them both at the same time. I suppose in theory you could just do one at the same time, but if you're going to be doing them, you mind as well do them both. It's correct about what someone else said about downstream vs upstream. I changed my upstream ones at around 140-150k, never touched the downstream ones and got rid of the car with the original downstream ones with over 200k on it.
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554435
10/25/17 06:11 PM
10/25/17 06:11 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Depends on what you are trying to accomplish. Changing the rear wont change fuel trim. But on a v6 changing both fronts for fuel trim would be a good idea.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554464
10/25/17 06:37 PM
10/25/17 06:37 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Y E S
Re: Should O2 sensors be replaced at the same time? [Re: ZZman] #4554743
10/26/17 12:15 AM
10/26/17 12:15 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Yah,change both on a V6. Cat condition hasn't direct effect on the engine except that a sick engine will kill a cat. My firsy '88 BMW passed emissions at 335K miles on its original cat.
Thick oil is better grin2
Re: Should O2 sensors be replaced at the same time? [Re: andyd] #4554774
10/26/17 01:54 AM
10/26/17 01:54 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
You mean both upstream ones right? As mentioned earlier, it's the upstream ones that are in the stream of things and wear out. The engine uses them to adjust the fuel mixture. The downstream ones are after the cat so if everything is working right, they don't get much abuse and can last much longer. They're not switching much and they're there mostly to tell you when the cats are bad.
Re: Should O2 sensors be replaced at the same time? [Re: Wolf359] #4554985
10/26/17 10:06 AM
10/26/17 10:06 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
And if things go south on the cat, like a P0420 or P0430 efficiency code, you can block the sensor off from the exhaust entirely, its there for an electrical connection only.
