Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
86 registered members (53' Stude, 92saturnsl2, 2013ecof150, Ablebody, 28oz, 5 invisible), 1,706 guests, and 50 spiders.
Topics290,723
Posts4,849,053
Members66,021
Most Online3,590
Jan 24th, 2017
Water in oil analysis #4554255
10/25/17 02:49 PM
10/25/17 02:49 PM
WV
loneryder Offline OP
WV
Got my results back from ALS Tribology and the only thing questionable was .12% water. It's a Ford E350 RV with the V-10. It's been sitting so I ran it at idle to warm it up. I thought it got up to operating temp. There is no antifreeze reported. Do you think the water could be from just idling it to warm it up? I don't know where else it could come from. They could not test the viscosity due to the water present???
Also as an FYI, when you send samples in to them in Atlanta, put it in an envelope instead of just mailing the canister. They have a problem with the post office holding the canisters for weeks at a time before delivering them. Lady told me they seem to receive samples in envelopes in a timely manner.
Re: Water in oil analysis [Re: loneryder] #4554258
10/25/17 02:52 PM
10/25/17 02:52 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Water condensation could be there just from it sitting for a while. And just bringing it up to operating temp may not be enough to burn it off. You'd probably have to run it longer to get rid of all the moisture.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
Re: Water in oil analysis [Re: loneryder] #4554402
10/25/17 05:46 PM
10/25/17 05:46 PM
VA
thastinger Offline
thastinger  Offline
VA
Well, since water evaps at 212, you would likely have to warm the oil up beyond that temp and keep it there for a bit in order to burn it off.
Re: Water in oil analysis [Re: loneryder] #4554416
10/25/17 05:56 PM
10/25/17 05:56 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
There's always water in UOA. Most UOA's don't use FTIR or KF, so they don't detect it, that's all. But it's still there.
Re: Water in oil analysis [Re: loneryder] #4554453
10/25/17 06:25 PM
10/25/17 06:25 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
As long as there is no traces of coolant as called out by the Lab I would think it's a combination of it sitting and the oil not reaching full operating temperature so it could burn off the moisture.
I always take my samples after I return from driving around doing shopping/errands etc. so I know the oil got hot enough to give me a good reading.
Hope that helps.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Water in oil analysis [Re: loneryder] #4554462
10/25/17 06:36 PM
10/25/17 06:36 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Getting the oil to operating temp is not going to burn off any condensation water.
2015 Ford F250 w/Powerstroke
Re: Water in oil analysis [Re: loneryder] #4554501
10/25/17 07:20 PM
10/25/17 07:20 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
Also, and Mr. Cedrone can vouch for this or at least he knows who could, what is being detected as "water" in those tests is not always "water".
Re: Water in oil analysis [Re: loneryder] #4554545
10/25/17 08:03 PM
10/25/17 08:03 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Trace amounts of moisture in engine oil will most certainly evaporate off over some run time at normal operating temps and be processed by the PCV system. That's one of the reasons the PCV system is there. The closer to the boiling point of water the faster this would happen, but it will occur at less temperature.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Water in oil analysis [Re: loneryder] #4554554
10/25/17 08:08 PM
10/25/17 08:08 PM
The Motor City
Kestas Online content
Kestas  Online Content
The Motor City
We use Karl Fischer at work to determine water content in grease. Anything up to 0.5% is considered normal for new grease. I suspect the same may be attributed to motor oil. Your 0.12% may be as low as you can expect it.
Re: Water in oil analysis [Re: loneryder] #4554644
10/25/17 09:46 PM
10/25/17 09:46 PM
WV
WV
Thanks guys. There was zero antifreeze in it. I just didn't run it long enough. Why would such little water prevent them from testing viscosity??
Re: Water in oil analysis [Re: loneryder] #4554958
10/26/17 09:34 AM
10/26/17 09:34 AM
Great Lakes
Great Lakes
That's puzzling to me.
Re: Water in oil analysis [Re: loneryder] #4555409
10/26/17 06:12 PM
10/26/17 06:12 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
you can actually use the "water" content to determine the fueling conditions.
Re: Water in oil analysis [Re: loneryder] #4555593
10/26/17 08:33 PM
10/26/17 08:33 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
They declined vis test on one of my samples for water too. Seems to be the way they operate. No explanation though.
Re: Water in oil analysis [Re: DoubleWasp] #4555835
10/27/17 01:43 AM
10/27/17 01:43 AM
Chicago
danielLD Offline
danielLD  Offline
Chicago
I've had many times when lab techs wouldn't run a sample through PC because it was too dark, etc. Some labs, the lab tech is responsible for operation and will get dinged for not stopping a sample that could break the machine.
Unless your a multimillion dollar client, they're not going to stop run time if they think your sample will give trouble.
Re: Water in oil analysis [Re: loneryder] #4556845
10/28/17 04:46 AM
10/28/17 04:46 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
Makes sense.
