- Joined
- Jul 2, 2007
- Messages
- 5,294
Plumber call made, waiting for arrival.
Technically not the actual heater, a Rheem 50 gallon gas fired. Either the pressure regulator on the incoming supply, or the Watts PL-5 expansion tank. Hot water has been slowly reducing over past few weeks, and this morning down to a dribble and when opening the garden tub's hot side (no spigot screen) a bunch of black flakes come out with the water looking a lot like could be parts of either the pressure reg valve or the bladder in the expansion tank... varies from small specks up to 1/2" flakes.
Both the expansion tank and the pressure reg valve are three yrs old, heater is 12 yrs. Municipal water, typically somewhat hard w/ moderate scale build-up.
Pressure relief valve is also leaking water onto garage floor.
Guess this is going to co$t ...
