New washer pump leaking fluid
by llmercll
34 minutes 12 seconds ago
Fuel dilution and CCS/MRV viscosity
by doyall
41 minutes 7 seconds ago
Door Hinges
by Scrum67
52 minutes 22 seconds ago
PBS, TV channels in different countries
by onetwoothreee
Today at 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
Today at 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
Today at 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
Today at 10:33 AM
Windows 10 Update, version 1803
by Sayjac
Today at 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
Today at 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
Today at 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
Today at 09:34 AM
Anger on BITOG
by Gebo
Today at 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
Today at 08:45 AM
Surprising oil filter service interval.
by jakewells
Today at 08:12 AM
World Population
by CourierDriver
Today at 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
Today at 07:35 AM
Meguiars
by dslofti
Today at 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
Today at 05:59 AM
Omnia - the band
by Shannow
Today at 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
Today at 12:54 AM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
95 registered (Alex_V, 4WD, andyd, ArrestMeRedZ, 11 invisible), 1647 Guests and 52 Spiders online.
65299 Members
67 Forums
285849 Topics
Page 1 of 2 1 2 >
#4553990 - 10/25/17 10:15 AM 6 month old 3 ton jack leaking?
LeakySeals Offline
Loc: Hudson, NH
Does this look like the jack started leaking, or maybe something spilled on it? Its 3 ton rated. The heaviest lift was the rear of the 06 Escalade at the diff. Both wheels off ground. Long enough to get stands in place. Then take the stress off the jack. I was always careful to remove load with stands.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4553999 - 10/25/17 10:19 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
CT8 Offline
Loc: Idaho
Warranty?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4554002 - 10/25/17 10:20 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
I can't find receipt.
#4554003 - 10/25/17 10:20 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
DuckRyder Offline
Loc: Atlanta
What are we looking at in that picture?
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
#4554008 - 10/25/17 10:22 AM Re: 6 month old 3 ton jack leaking? [Re: DuckRyder]
LeakySeals Offline
Loc: Hudson, NH
The concrete floor under the jack is wet. The jack itself looks good on top. So its not obvious if or where its leaking. Hoping someone can tell because its this area of the jack. vs somewhere else.
#4554036 - 10/25/17 10:43 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
I have a thirty five year old 2 ton that uses a similar hydraulic unit, and the ONLY time I have ever had a leak is when I refilled the reservoir with too much oil. My unit has a rubber plug in the fill hole and too high of an oil level will cause leakage until the level goes down. The leakage is caused by a rapid return of oil to the reservoir when the jack is suddenly released. With this hydraulic unit, there is only two areas prone to leakage. One is the small piston actuated by the handle and the other is the ram oil seal. I have never seen even seepage at the plugs and the release valve. Clean the hydraulic unit up with brake cleaner, mineral spirits et.al. and then remove some oil from reservoir and run the jack through up down and watch the fill hole for leakage. The manual for my jack shows the oil level as 3/16" below the fill hole but that level is too high for my jack.
Edited by HosteenJorje (10/25/17 10:47 AM)
Edit Reason: Added Oil Level
#4554050 - 10/25/17 10:55 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
WyrTwister Offline
Loc: Texas
I have a floor jack that has been leaking for at least 10 years . If you can not find the receipt , just live with it , adding hydraulic jack oil , as needed . That is what I do .
Best of luck , :-)
Wyr
God bless
#4554051 - 10/25/17 10:55 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
DuckRyder Offline
Loc: Atlanta
I have a 3.5 ton Craftsman professional, it is quite similar although the frame is a bit longer. The hydraulic unit looks quite similar.
Agree with HosteenJorje, inspect the plugs on top of the unit, the ram and the plunger. The spots on your concrete are not where I would expect to see them if the unit was leaking.
Edited by DuckRyder (10/25/17 10:56 AM)
Robert
  • 1972 Ford F100
#4554058 - 10/25/17 11:01 AM Re: 6 month old 3 ton jack leaking? [Re: Yah-Tah-Hey]
LeakySeals Offline
Loc: Hudson, NH
Its quite possible I let it down too fast, one complaint is how it gets "stuck" when I try to release it. I greased the pole ( shocked2 ) and the gears which has helped letting the truck down more smoothly.
So if I pop off that orange plug, I can measure oil level?
If I have to replace what should I use?
How often should i change the oil?
#4554063 - 10/25/17 11:09 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
JohnnyJohnson Offline
Loc: Wet side WA
Sears is very good about support their brand I've had them take thing back without a receipt.
2004 Toyota Corolla 121758
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4554087 - 10/25/17 11:31 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
ZebRuaj Offline
Loc: MN
You can find hydraulic jack oil at Walmart, and I assume most auto parts and hardware stores.
I just drained and fllled my HF jack this spring after noticing it wasn't quite as springy as usual. Lubed the zerk fitting too.
~Shade tree mechanic for friends and family.
#4554090 - 10/25/17 11:33 AM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
Yah-Tah-Hey Offline
I assume you are talking about the handle when you mention "pole?" I use a #2 lithium grease at the journal. The gears don't really require lubrication. One thing I have found over the years, if you use oil at any of the pivots and on the wheels,you will most likely see oil on the floor. Again, clean the underside of the jack carefully, remove a little oil (maybe an ounce or two), and then run the jack up and down. Look for leakage at the fill hole plug. The release valve does have some resistance to rotation but nothing excessive. Perhaps you haven't got enough miles on your jack to wear things in a bit. Take care of it and that jack will outlast you. My old Craftsman is going to be working satisfactorily when I have gone up the stack. I haven't found a worthy candidate to inherit my jack. No one I know knows or cares squat about wrenching. They don't even have a wrench and couldn't figure out how to use an adjustable jaw (Crescent) wrench banana . But they have many, many electronic gizmos. banana
#4554142 - 10/25/17 12:33 PM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
Yes the handle base that you can see in the pic. Removed handle, lubed the area that fits in. Works great now. maybe too good that first time. lol. I used suspension grease, no reason other than the gun was out.
#4554147 - 10/25/17 12:39 PM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
jeepman3071 Offline
Loc: Storrs, Connecticut
I had the same jack. It leaked after 8 months or so. Brought back to Sears. Got another one as a replacement. That one leaked after 6 months and even when full of fluid it stopped going up. The Sears in my area closed and the closest one is now fairly far away.
I replaced it with a non-Sears jack.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4554311 - 10/25/17 03:53 PM Re: 6 month old 3 ton jack leaking? [Re: LeakySeals]
dlundblad Online   happy
Loc: Indiana
The web seems to like these, but I've seen nothing but bad. A friend literally bought one for loading and unloading his rough mower's tongue from standing on a block of wood to the hitch of his tractor. Leaked not even a year later.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
Page 1 of 2 1 2 >
