Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
82 registered (853okg, 28oz, 2015_PSD, 2009Edge, 9050lx, 330indy, 9 invisible), 1472 Guests and 33 Spiders online.
65276 Members
67 Forums
285641 Topics
Page 1 of 2 1 2 >
#4553463 - 10/24/17 07:29 PM Spark Plug fit are the new plugs too long?
handyman Offline
Loc: TX
I got some new spark plugs for my 2001 Saturn L100. They are Bosch Double Iridium 9617. Autozone, Orilly and Rock Auto says they will fix. I pull one of the old plugs and it is quite a bit shorter than the new plug. Do I have anything to worry about?????
2011 Prius III 111k
2006 Senna LE 160k
2001 Saturn L100 200k
1993 Corolla LE 200k
#4553467 - 10/24/17 07:32 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
JohnnyJohnson Offline
Loc: Wet side WA
That would have made for a rough start up.
2004 Toyota Corolla 121668
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4553469 - 10/24/17 07:33 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
mk378 Offline
Loc: USA
Those are totally wrong. For one thing the new one is a taper seal and the originals are gasket seal. Not even close to being right. Do not attempt to install them.
Now it is possible that the ones you removed are wrong for the engine, though I doubt that gasket seal plugs will fit at all in a taper hole.
Edited by mk378 (10/24/17 07:36 PM)
#4553470 - 10/24/17 07:34 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
doitmyself Offline
Loc: MI
Don't use the new one. Maybe worse than the length difference, the new plug has a tapered seat while your old plug has a flat gasketed seat.
#4553478 - 10/24/17 07:39 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
Dave9 Offline
Loc: Cincinnati, USA
Do you have a 2.2L 4 cyl or 3.0L V6? The original plugs with the flat seat and 19mm reach look right for the 3.0L while the tapered seat with 25mm reach (including the Bosch part # you listed) are for the 2.2L.
This is the correct Bosch Iridium for the 3.0L:
BOSCH 4512
http://www.rockauto.com/en/moreinfo.php?pk=1053685&cc=1374948&jsn=394
Edited by Dave9 (10/24/17 07:44 PM)
#4553480 - 10/24/17 07:41 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
barkingspider Offline
Loc: socal
Do not use the new ones. Get the same ones u pulled out or cross reference the part no of the old plugs
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4553483 - 10/24/17 07:46 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
71Chevyguy Offline
Loc: Martinsburg West Virginia
L100 should be 4 cylinder only, so that would have to be the 2.2 Ecotec.
15 Chevy Sonic RS M1 Dexos1 / Delco filter
99 VW Beetle TDI M1TDT / Mann filter
98 Buick LeSabre PHM + G oil / Bosch filter
85 Skylark 2.5
71 Nova 250
#4553485 - 10/24/17 07:49 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
Chris142 Offline
Loc: Deplorable in apple valley, ca
As everyone else said. Wrong plugs! Taper vs gasket.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4553489 - 10/24/17 07:54 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
Rand Offline
Loc: NE,Ohio
If I'm not missing something...
according to rockauto
3.0 has the gasket type.
2.2 has the taper seat plug
The bosch 4512 for the 3.0
and the bosch 4514 for the 2.2
Is it possible someone previously installed the wrong plugs?
2017 Jeep Cherokee Trailhawk V6
#4553493 - 10/24/17 07:56 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
handyman Offline
Loc: TX
It is a four cylinder.
2011 Prius III 111k
2006 Senna LE 160k
#4553505 - 10/24/17 08:04 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
handyman Offline
Loc: TX
Now, I'm wondering if I had the wrong plugs in there in the first place?? but they have been there for 75,000 miles???
2011 Prius III 111k
2006 Senna LE 160k
#4553510 - 10/24/17 08:10 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
redbone3 Offline
Loc: Reno, NV
If the new plugs are correct, be sure to use a thread chaser before installing the new longer ones. It's got to have some buildup on the threads.
2014 Passat Wolfsburg, 1995 Miata.
#4553512 - 10/24/17 08:11 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
mattwithcats Offline
Loc: Virginia
Old plugs were wrong...
I would use NGK, one heat range colder...
NGK 6509, LTR6IX-11
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4553555 - 10/24/17 08:51 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
slacktide_bitog Online   content
Loc: USA
Use NGK instead smile
NGK #5581
or
ACDelco 41-988
The ACDelco iridium is made by NGK, a reboxed Laser Iridium.
The correct plugs for your car look like the new ones you got at Autozone, the longer thread. So it means the old ones were the wrong size smile
#4553570 - 10/24/17 09:02 PM Re: Spark Plug fit are the new plugs too long? [Re: handyman]
mk378 Offline
Loc: USA
Also if you do try them, before trying to start, turn the engine by hand to be sure they don't crash.
Page 1 of 2 1 2 >
