Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
105 registered members (2018matto, 28oz, 1foxracing, 64bawagon, 01ws666, 2009Edge, 10 invisible), 1,826 guests, and 42 spiders.
Topics294,973
Posts4,925,157
Members66,657
Most Online2,553
Oct 27th, 2018
Bad luck with Chinese carburetors lately. #4553219
10/24/17 02:43 PM
10/24/17 02:43 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
While I usually have great luck with inexpensive mail-order import replacement carbs for OPE, man has my 18.5hp Briggs 31P777 series engine proven to be challenging in this area! I had some issues earlier this year which warranted replacing the original ~2007 OEM carb on this engine. The first replacement eBay carb came with a misaligned choke, that I was able to fix short term, but iteventually broke all together. The second eBay replacement was fine aside from the electrical connector to the fuel shut-off solenoid not allowing the wire from the tractor to lock in properly, plus a very slight fuel weep from the solenoid somewhere. Today the mower wasn't acting right and I discovered sparks from both ends of the throttle shaft and the little fine wire return spring on the throttle was glowing like a light bulb filament! WTH!! If you pull the fuel shut off solenoid wire the sparking stops (but obviously kills the engine). Killing the ignition also stops the short. I'm assuming the solenoid although doing it's job, has an 'electrical leak' going on? Never ran into this one before. Luckily I've got 2 other solenoids from the other 2 carbs to try to swap to.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553285
10/24/17 03:34 PM
10/24/17 03:34 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Buy Kehin (Japan) or similar established brands. They don't cost that much more than Chinese knock-offs. I think B&S OEM is Nikki (Japan), but check to make sure.
All solenoids and relays are prone to failure.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553373
10/24/17 05:00 PM
10/24/17 05:00 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
I hear you, but you can buy 5-6 Chinese carbs vs one OEM Nikki carb, that you're REAL lucky to find by mail order for $100. Honestly, comparing them side by side, even disassembled, they look and feel identical. This doesn't mean the same I know and have obviously just experienced. Still worth a try IMO for a mower I can live without.
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553494
10/24/17 06:57 PM
10/24/17 06:57 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I buy alot of carbs and although they are cheap they alot of times are not direct replacement. Still getting a chainsaw carb for $6.00 shipped versus $40 for a factory one or $13.50 for a Chinese Honda carb is a good deal. The Honda carbs are very lightweight and cheap. A better option is rebuilding the old carb but if it's broke, it's broke and not worth the cost of factory.
Can't rebuild a walbro for what you can but a new Chinese one for shipped.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553626
10/24/17 08:48 PM
10/24/17 08:48 PM
USA
mk378 Offline
mk378  Offline
USA
Sounds like a fault in the solenoid. The carb is not solidly grounded to the engine (since it's a plastic intake manifold) so if the carb body becomes live, the electricity will find some path like the throttle linkage.
So yes swap out the solenoid should be OK.
Re: Bad luck with Chinese carburetors lately. [Re: mk378] #4553665
10/24/17 09:14 PM
10/24/17 09:14 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
^ Thank you!
My thoughts as well. Like you say, the carb is insulated from the engine, as is the choke linkage, given the choke shaft and linkage attachment point is plastic. The only metal on metal is the throttle linkage to the engine/chassis. The ridiculously thin wire return spring that is sort of wrapped around the throttle linkage gives enough resistance that it was glowing! I'm glad I caught it and it didn't burn away or worse. Tomorrow I'll swap carb solenoids and post back.
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553842
10/25/17 06:04 AM
10/25/17 06:04 AM
Texas
wag123 Offline
wag123  Offline
Texas
Just run a separate ground wire to the carb body.
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4553928
10/25/17 08:00 AM
10/25/17 08:00 AM
USA
mk378 Offline
mk378  Offline
USA
The solenoid should have two wires, one power and one ground. If the plug is wired backwards so the ground actually gets powered, that would cause this problem.
Re: Bad luck with Chinese carburetors lately. [Re: JTK] #4554246
10/25/17 01:41 PM
10/25/17 01:41 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Swapped out the fuel shutoff solenoid and the problem went away. The old one was always damp with gas, so I'm assuming it had some type of internal leakage through the coil area. While I was at it, I added a plastic fuel shut off I picked up at my local Napa. Should have done that years ago.
