Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
102 registered members (aquariuscsm, 928, Ag76, Alfred_B, Aero540T, Altima2, 12 invisible), 2,095 guests, and 58 spiders.
Topics286,236
Posts4,904,891
Members67,582
Most Online2,967
Mar 10th, 2019
Wix 51036XP 4100 miles #4553192
10/24/17 03:13 PM
10/24/17 03:13 PM
Vermont
John_VT Offline OP
John_VT  Offline OP
Vermont
Off my suburban. Started getting some lifter tick on cold starts a while back. I've changed the oil about 3 times in the past 5600 miles. The first made it 500 before the tick came back the second made it 1000. This one was 4100 but I drained and added a quart at 1000 and 2000 miles. With 200k on the clock I'm ok with a tick or two but she would sometimes tick for minutes eek
14 crosstrek 5 spd.Milesyn sxr 0-20
98 k1500 suburban 5.7L.Milesyn sb 5-30
03 Pontiac Montana. St 5-30
01 mojave,86 trx350,2-110cc atv's
Re: Wix 51036XP 4100 miles [Re: John_VT] #4553196
10/24/17 03:22 PM
10/24/17 03:22 PM
Alberta
BigJakeChevy Offline
Alberta
Could the engine be in need of a rocker arm lash adjustment?
2007 Silverado Classic 1500 Crewcab 5.3L 470,000KM
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w110
Re: Wix 51036XP 4100 miles [Re: John_VT] #4553213
10/24/17 03:39 PM
10/24/17 03:39 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Filter looks like it did job well. Thanks for c&p sir:)
Re: Wix 51036XP 4100 miles [Re: 53' Stude] #4553907
10/25/17 08:36 AM
10/25/17 08:36 AM
Vermont
John_VT Offline OP
John_VT  Offline OP
Vermont
I don't think so truck is normally quiet and smooth.
Yes that's what I think too.
Re: Wix 51036XP 4100 miles [Re: John_VT] #4554163
10/25/17 12:57 PM
10/25/17 12:57 PM
Tennessee
FlyingVan Offline
FlyingVan  Offline
Tennessee
If it ticks for minutes after start up you have other things going on besides a leaking ADBV in the oil filter.
2015 Mercedes Sprinter, 2.1 4cyl diesel, 42k
2011 Volkswagen Jetta Sportwagen TDI, 100k
2004 Dodge Sprinter 2.7 5cyl diesel,779k
Except for chainsaws and lawnmowers, no sparkplugs needed in my stable.
Re: Wix 51036XP 4100 miles [Re: John_VT] #4554181
10/25/17 01:13 PM
10/25/17 01:13 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
What kind of oil and weight were you using to do all these changes? At your OIC what did you put back in?
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Wix 51036XP 4100 miles [Re: FlyingVan] #4554194
10/25/17 01:28 PM
10/25/17 01:28 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
+1 ... with 200K miles, could be a few hydraulic lifters are leaking down if it sits for awhile.
Re: Wix 51036XP 4100 miles [Re: ZeeOSix] #4554275
10/25/17 03:10 PM
10/25/17 03:10 PM
Vermont
John_VT Offline OP
John_VT  Offline OP
Vermont
I should also say that I bought the truck with iirc 165ish k. With unknown history
That is what I think is happening but why? I feel like ive seen some idk what sludge? Come out when during oil changes. Makes me think that a lil crud is not letting a lifter or two seal.
As to what was used for oil. Don't think less of me but most of all the previous OC were just a speedy lube whistle I do all other maintenance. So this spring the trans went and I had just redone the fuel system about a month earlier tank, lines ,fill neck,sending unit,rear brake line. And few months before that I did all new brakes cut out some rust new patch panels some paint clear coat
Gold doesn't quite match o well. So after getting a new trans in when we started it was the first time it "ticked" it was due for an oil change so I went to speedy lube. So the 500 oci was speedy lube 5w30 conventional. The 1000 mile was castrol edge 5/30hm with a fram ultra . The 4100 started with castrol edge 10/30hm accidentally grabbed it not a big deal and the wix xp. But I did drain a quart like I mentioned and added 5/30 edge or miles sb 5/30. I put in for this oci was mostly edge 5/30 and some miles sb 5/30
Re: Wix 51036XP 4100 miles [Re: John_VT] #4554781
10/26/17 02:26 AM
10/26/17 02:26 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Might want to try the Seafoam treatment in the oil like this guy did who claims it cured his noisy lifters.
Re: Wix 51036XP 4100 miles [Re: John_VT] #4555101
10/26/17 12:36 PM
10/26/17 12:36 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
What's the cat's name?
Re: Wix 51036XP 4100 miles [Re: John_VT] #4555123
10/26/17 12:53 PM
10/26/17 12:53 PM
Vermont
John_VT Offline OP
John_VT  Offline OP
Vermont
Cat ?
Re: Wix 51036XP 4100 miles [Re: Yah-Tah-Hey] #4555143
10/26/17 01:08 PM
10/26/17 01:08 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
DENSO LOL
Re: Wix 51036XP 4100 miles [Re: ZeeOSix] #4555282
10/26/17 03:59 PM
10/26/17 03:59 PM
California
jj51702 Offline
jj51702  Offline
California
DENSO LOL
Lol
Re: Wix 51036XP 4100 miles [Re: John_VT] #4555587
10/26/17 08:26 PM
10/26/17 08:26 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Check the exhaust manifolds. They like to break off bolts and crack. The ticking sounds just like valve train issues.
I get a mild knock on mine when I start it up after sitting a while but nothing to worry about. The small block chevies are always kinda noisy in one way or another.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Wix 51036XP 4100 miles [Re: ZeeOSix] #4555800
10/26/17 11:53 PM
10/26/17 11:53 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Now that was funny.
Instead of, "here kitty, kitty, kitty".
It is " here DENSO, DENSO, DENSO".
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
