4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
65 registered members (allgm59, 97prizm, ad_infinitum, 7 invisible), 1,347 guests, and 59 spiders.
Topics286,042
Posts4,901,393
Members67,551
Most Online2,967
Mar 10th, 2019
5W30 or 10w30 winter oil for a '01 Suburban 1500 ? #4552980
10/24/17 11:59 AM
10/24/17 11:59 AM
OKLAHOMA
GMguy84 Offline OP
GMguy84  Offline OP
OKLAHOMA
Yikes, I just noticed I posted in the Diesel forum by accident lol blush
For a '01 Suburban 1500 5.3
So my next OCI is around December. I just put Pennzoil HM 10W30 last month and had a MB-1 SYN filter already on since June. I drive around 2000-miles a month( it's my work truck) and I live in Oklahoma, So in winter it's not cold ALL the time like Chicago/New York, But it CAN get [email protected]!&# cold at times in winter !!!!
Truck will have around 246K miles around nect OCI and it does have the "FABULOUS" vortec "piston slap option" smirk
Curious if 5W-30 is okay with that type of mileage for winter use or not ?? Just wanted to make sure, Cause a few days ago, I picked up 5 QT jug of Atwoods harvest king Semi-Syn 5W-30 for $7 after tax on sale !!! laugh
I do add 1QT of hy-per lube/Lucas oil treatment on ALL my oil changes throughout year, but have been told on BOBISG that oil supplements are a BIG no no ???
Dave
05 Silverado Z71 5.3 Mobil 1 EP 10W30/FUG XG3675
01 Suburban 5.3 Mobil 1 AP 5W30/FUG XG3675
1982 TRANS AM (KITT) Mobil S5K 10W40/M1-302A
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4552995
10/24/17 12:11 PM
10/24/17 12:11 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
The Lucas stuff is very thick; not really good at all for colder weather.
5w or 10w-30 will be fine. Why not just run a 5w-30 High mileage all year? That is the best option.
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553027
10/24/17 12:42 PM
10/24/17 12:42 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
NEVER use Lucas thickener. Just use thicker oil in the first place. 5w-30 is fine. It's a 30 weight oil. Like Drew said, you can use a 5w-30 HM year round, or even a 0w-40. Save 10w-30 for the summer if you prefer it.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553043
10/24/17 01:02 PM
10/24/17 01:02 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
My 5.3 with 175k has had pretty loud piston slap below 40F in the past. Changed to BC 0w30 about 2 years ago and haven't heard it since. Not sure if it was luck, thicker oil or Castrol magic. I may never know as I have another 3-4 years of that oil in the stash.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553108
10/24/17 02:01 PM
10/24/17 02:01 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
5W or 10w, then thicken it up with motor honey? The question I will ask is how cold does it get where you are going to start the car?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553122
10/24/17 02:10 PM
10/24/17 02:10 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You don't need 5W-30 unless you go below zero Fahrenheit.
At least that's what Mobil and Pennzoil tells me.
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553128
10/24/17 02:14 PM
10/24/17 02:14 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Why would you need to thicken it up? Certainly, why would you thicken it up with a questionable additive that does nothing but dilute the add pack? It's an LS-based motor, which have been proven over millions of miles on 30W oils, and piston slap is obviously not detrimental to the life of these engines.
Stick with the 5W30 unless you have reason to believe the engine needs a heavier oil (piston slap may be quieted by this but the issue is inherent in the design), and for goodness sake DON'T USE LUCAS! smile
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553201
10/24/17 03:27 PM
10/24/17 03:27 PM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
Both 5W-30 and 10W-30 are recommended by GM for use in your engine. Unless you are looking at very cold temperatures, 10-30 is an acceptable alternate for the 5-30. Forget an oil additive as most of the time, they are a waste of money. Use an oil from one of the major suppliers and you're good to go.
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: CT8] #4553250
10/24/17 04:11 PM
10/24/17 04:11 PM
OKLAHOMA
GMguy84 Offline OP
GMguy84  Offline OP
OKLAHOMA
I'm in Oklahoma for now, But I do visit Chicago at times and plan on visiting this holiday winter season and we all know it can get FREAKIN cold in chi-town lol
But back in Oklahoma during a BAD winter, I have seen as cold as 10/20 below zero !!! It's rare but has and can happen !!!
Dave
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: SubieRubyRoo] #4553264
10/24/17 04:16 PM
10/24/17 04:16 PM
OKLAHOMA
GMguy84 Offline OP
GMguy84  Offline OP
OKLAHOMA
Years ago, I was recommended Lucas to "thicken it up" due to the piston slap issue ??? But for the first time since I bought the truck I'm gonna run it 100% oil nothing "Extra" and see what it does lol !
Dave
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553272
10/24/17 04:23 PM
10/24/17 04:23 PM
Texas
Tdog02 Online content
Tdog02  Online Content
Texas
Oklahoma? 10w-30 pick the brand or run supertech... never worry about it.
09 Venza 2.7 104k 5w-30 Magnatec
16 F150 2.7TT 52k 5w-30 Magnatec
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553290
10/24/17 04:40 PM
10/24/17 04:40 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
5w30 and lose the Lucas
Iím in Phoenix and have 0w30 in two cars! laugh
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553301
10/24/17 04:50 PM
10/24/17 04:50 PM
OKLAHOMA
GMguy84 Offline OP
GMguy84  Offline OP
OKLAHOMA
So I'm gonna try 5w-30 for my next winter OCI in December, I got 6 QTS of Harvest King (Citgo) 5W-30 Semi syn for $8.75 total after tax !!! And running a M1 Filter for now. Next year going with a Fram XG3675 filters @ $4 each !!! cool
I want peace of mind incase it does get below 0 in Oklahoma and if I do drive up to Chicago this winter !!!
If I like the way my rig runs with 5W-30 then gonna switch to HK FULL syn at $13 for a 5 QT jug
Dave
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553430
10/24/17 06:57 PM
10/24/17 06:57 PM
pa
benjy Offline
benjy  Offline
pa
the closer the viscosity spread the better generally, + if your not using oil 10-30 is good but a 10-40 or a 15-40 diesel could be a good choice + quiet things a bit + change your filter with the oil!!! highway miles are easier + longer changes with a better oil is surely an option.
Re: 5W30 or 10w30 winter oil for a '01 Suburban 1500 ? [Re: GMguy84] #4553453
10/24/17 07:21 PM
10/24/17 07:21 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
Dave
+3 Lose the Lucas (snake) oil. Can't believe people still buy this stuff. Here's what it really does: https://youtu.be/wLnpHWwu9xM
Whatever
