Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
111 registered members (1978elcamino, Alfred_B, ABerns, Agnosto, 2015_PSD, 17 invisible), 2,431 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Oil Confusion - Older 73-87 Chevy 454 Engines #4552859
10/24/17 10:18 AM
10/24/17 10:18 AM
Pennsylvania
83K30 Offline OP
83K30  Offline OP
Pennsylvania
I am so confused I don't know what to do anymore. I have spent hours and hours pouring over research, forums and documentation. I have several 80's Chevy full size trucks with 454 big block engines. They are all original and haven't been changed to modern roller cams. The more I read about new engine oils the more I am concerned about what to use. These trucks do not have catalytic converters, they never did from the factory as they were exempt since they are 9900 gvw 1 ton trucks. I have been running Rotella T5 10w/30 in them since they all sit a lot and don't get run for weeks or months at a time. I want to stay around a 10/30 weight as that seems to give me good oil pressure and no oil consumption. I am not sure if synthetic is doing these engines any favors, I don't have any leaks. I also have been reading the Rotella T5 still has the ZDDP I need but again unsure about that. Other folks say to use VR1 racing oil and still others say just regular Valvoline 10/30 or even 5/30 is just fine. I am so confused and want to make sure I am giving these engines the longest life possible. A big block rebuild costs about 4-5k nowadays and I hate pulling engines. Any suggestions?
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552860
10/24/17 10:20 AM
10/24/17 10:20 AM
justin , tx
87sammy Offline
87sammy  Offline
justin , tx
I have a 77 GMC Jimmy with a 400 small block. I Run Mobil 1 high mileage 10w 30 with a Fram Ultra filter and change it out once a year.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552870
10/24/17 10:24 AM
10/24/17 10:24 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Don't get too worried about oil, it really isn't THAT big of a deal.
Rotella T5 10w30 sounds fine to me, keep on with that.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552872
10/24/17 10:26 AM
10/24/17 10:26 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
If what you're doing is working, don't change it. Since your BBC's are well-broken-in and have the stock mild camshafts without radical lift, high lift rate, or 600 lb valve springs, you'd really be just fine with a modern passenger car oil with around 800 PPM of ZDDP. There's really no need for 1500 PPM ZDDP levels from racing oils unless you're breaking in a new cam/lifter set, or have a much more radical flat-tappet cam than a factory 80s BBC. Rotella's formulation has been changing to keep up with new regulations, but as far as I know, the 5w40 T6 still has around 1000 PPM of ZDDP. They removed the "official" gasoline engine ratings from it, but since there's no magical set of ingredients that gas engines just have to have which diesels don't, don't worry about it. They removed the gas engine approvals because to meet more modern gas engine approvals, it would *lower* some additive levels compared to what they can use with a diesel-only set of approvals. I personally am continuing to use RT6 5w40 in my 60's Chrysler 440 big-blocks, which have slightly more aggressive cams than your 80s BBCs use.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552875
10/24/17 10:28 AM
10/24/17 10:28 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The BBC doesn't need a syn oil.The differences between syn oil and conventional base stocks these days are somewhat minimal. Compare the additive packages. Syn is a good idea for below freezing starts.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552891
10/24/17 10:47 AM
10/24/17 10:47 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
As stated above, the OEM cams, lifters and valve springs will all live long and happy lives with 800 PPM of ZDDP, once broken in. For you, that happened long ago. Plenty of oil out there with that.
Rotella T5 is a fine choice. Don't worry about HDEO w/o gas engine API rating. They did not change the formula that much, if any. They just dropped the rating because of API current requirements.
I would not run a straight synthetic oil in these older engines. No need to, and there is the chance of drain-off if they sit for long periods. That means there is maybe less film (not no film) on cold start. These engines like a nice thick residual oil film to keep wear to a minimum until pumped and sling oil get going. Your current oil is fine for that smile
I've built a fair share of BBC's and they love good old dino oil. The thing is to change it when needed and run a decent filter. Since these are 9,000 GVW trucks, you have lots of room. I'd run the longer 2 qt filter for a bit more capacity. Any NAPA store can cross reference the filter.
You're in Penn, so it gets cold there. The bigger filter will have more media area. So when it's pumping cold thick'ish oil, it will have an easier time w/o the internal by-pass opening, and that's a good thing.
I'd do Napa Gold filters and once a year changes and be happy smile
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4552893
10/24/17 10:50 AM
10/24/17 10:50 AM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
I think you are totally fine with what you are doing. I run 10w-40 in my older motors but really almost anything is fine and will work for you. Don't lose sleep over it Brother.
16 Ford F150 2.7 Ecoboost 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison Dually 4x4
00 Blazer 4.3 4x4
97/98 Honda Civics
84 Chev K30 454EFI/T400/NP205 Dually 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4553011
10/24/17 12:21 PM
10/24/17 12:21 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I've owned an '85 C3500, 454/TH400 with 4.10 gears, for 10 years and 50,000 miles (77K to its current 128K) and use Schaeffer's 7000 10w30, a dual-rated, SN syn blend. If your BBC's have close to stock cams in them have no fear of "low" ZDDP - your syn blend Rotella 10/30 is a good choice.
If anything, questions about "what oil" will get more variety of answers with these old engines than any new 0w20-spec Pilot or Chevy 5.3. My opinion, regarding pre-port-injected Chevy V8's and inline 6's, is that 5w30 is only for fresh, tight engines that don't see extensive truck-type use. 10w30 or '40 is good unless it's run long enough, or is of a type (conventional) that's going to shear down - hence why I use Schaeffer's that never shows any oil pressure drop even up to last year's 6,400 mile OCI. 5w40 sets about the same as 10/30, and 15w40 isn't necessary unless you're working it real hard most of the time, particularly in a warmer climate, or the engine has some wear that needs a little thicker oil to keep it quiet and oil pressure up. Anything thicker than 15w40 is only appropriate for stuff like racing engines, with the appropriate knowledge to know what to use and why, or as a last resort to get a few more miles out of an engine that's, basically, completely worn out.
The "10w30 is too thin" crowd, I think, is largely those that haven't moved past the days when all but the finest oils sheared substantially in even these engines that aren't overly hard on oil. Today's oil chemistry is light years ahead of what our engines survived hundreds of thousands of miles on back in their day and the viscosity of a 10w30 HDMO will take thousands of miles longer to shear down to the same point that a 1980's 10/30 would have in 3K. Synthetic, "low" zinc, 30 or 40 weight - have no fear.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4553022
10/24/17 12:35 PM
10/24/17 12:35 PM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
Relax! Your Rotella T5 10w/30 is perfect. It is a duel rated oil and is a better quality oil then the best oil that was available when those engines were new. The fact that they don't leak and don't use oil is a real plus these days. They will out live the chassis which will out live you. grin2
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4553103
10/24/17 01:59 PM
10/24/17 01:59 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Chevron Supreme 20W-50. In some applications, thicker lubricates better.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4553202
10/24/17 03:28 PM
10/24/17 03:28 PM
Pennsylvania
83K30 Offline OP
83K30  Offline OP
Pennsylvania
Thanks for all of the feedback, I feel good about my choice of Rotella T5 10/30. I like the synthetic blend for fast lubrication that synthetic offers on cold starts and also the long service life I can get out of it. I only change the oil once a year because of the low miles, about 1000 or less, I put on per year.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: Alex_V] #4553211
10/24/17 03:38 PM
10/24/17 03:38 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
It's not about shear, it's about BBCs being sort of unhappy engines with sustained high rpm. In the marine industry, the idea of loading up a 30 weight into a BBC is almost hilarious. The amount of metal they shed in a short period of time is actually kind of astonishing.
Universal average for 50 hour OCI is about 50-70 ppm depending on the lab. We've gotten that down to the 20's on 100+ hour OCI's using Schaeffer and VR1 20w50.
Best UOA we got using a sub-50 oil was using RT6, delivering high 40s on iron over a 100 hour OCI.
Volvo Penta had the bright idea to use SAE 30 synthetix diesel oil in big blocks (much stouter than any passenger 10-30), and had engine failures inside of the 2-year warranty period. They then modified the spec to 15-40 diesel oil. We have seen a lot of VP 7.4 and 8.1 engines with awful compression 300-400 hours into service with documentation of regular service intervals on VP SAE 30.
Mind you, all of the above concerns roller cam BBCS with broomstick truck cams.
Point is, if you're giving a BBC average duty, a 30 is fine. Millions of trucks did it for tons of miles. If you're beating on a BBC and want it to last, go thicker or you might pay the price.
Where shear is concerned, these engines will eat all but the best oils for breakfast under sustained high rpm.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4553520
10/24/17 08:17 PM
10/24/17 08:17 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
If you want more zinc go with a 40 grade, they are allowed more. I'd run a 10 or 15-40. You're not running the oil much between changes so really almost any oil will do the job. I'd consider a 2 year oci unless you start driving them more.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: 83K30] #4554172
10/25/17 01:07 PM
10/25/17 01:07 PM
NM
rdc0000 Offline
rdc0000  Offline
NM
I called shell regarding ZDDP and the rotella there was only one that had the recommend rating for a replacement of the quaker state defy I was using. It was 15w 40 and I did not want to run that. After reading this thread, I will look for a T5 10W30. I think a call to shell and one of their technicians will answer your questions regarding rotella.
Re: Oil Confusion - Older 73-87 Chevy 454 Engines [Re: rdc0000] #4554494
10/25/17 07:09 PM
10/25/17 07:09 PM
NM
rdc0000 Offline
rdc0000  Offline
NM
I called shell and was emailed the following with a technical document. The document did not state ZDDP content.
"Shell Rotella T5 10W-30 Motor Oil has 1200 ppm of zinc."
What do you think?
