White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,375
Members66,982
Most Online2,688
Jan 19th, 2019
Garage Door opener lighting? #4552419
10/23/17 07:31 PM
10/23/17 07:31 PM
Dallas, Texas
SuperDave456 Offline OP
Dallas, Texas
So I recently repaired the motherboard to our garage door opener.
And in the process the cheap plastic covered crumbled in the process.
I taped it back together, spray painted it, and got it back up. (Incredibly cheap plastic in a hot garage in Tx)
Today I came home and it had fallen off taking the lighting on the garage door opener with it.
It's not a huge deal, I have 2 banks of 4 T5 bulbs out there on a switch, but it's an inconvenience.
It's good to have some light to come home to.
Currently I have a pair of 14ga wires hanging from a zip tie on the opener with 2 bulbs attached to the wires.
The parts of the fractured plastic case they attached to was easy to separate from them.
However, The bulbs on a wire are a little too trailer trash for me, and possibly dangerous given enough time.
It's not much juice, 2 bulbs in a fixture that had "Max 60 watt bulbs" on it.
So I could do more than the 2 compact florescent bulbs, possibly a fixture with LED bulbs.
At this point I'm looking for ideas.
Thank you,
Re: Garage Door opener lighting? [Re: SuperDave456] #4552434
10/23/17 07:57 PM
10/23/17 07:57 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
Not LEDs as they're supposed to interfere with the radio signal. Why not just hook wires up to a second hand store ceiling fixture?
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Garage Door opener lighting? [Re: SuperDave456] #4552436
10/23/17 07:58 PM
10/23/17 07:58 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Id install an LED flood light fixture like this
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Garage Door opener lighting? [Re: pkunk] #4552442
10/23/17 08:08 PM
10/23/17 08:08 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I think you mean Compact Fluorescents and that was first generation spiral type bulbs because the power supplies operate on high voltages.
'18 Dodge Grand Caravan GT - 17k KM - AMSOIL SS 0w30
'06 Hyundai Santa Fe - 535k KM (Dead) - AMSOIL SS 0w30
Re: Garage Door opener lighting? [Re: SuperDave456] #4552451
10/23/17 08:16 PM
10/23/17 08:16 PM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Any LED light fixture should work. We have 2 openers, last year I put regular cheap Lowes LED screw in light bulbs, work perfect, no issues.
If I am reading your post correctly, the bulb socket is shot. It would seem to be any LED strip light should work. The actual wattage will be on the fixture, your choices with LED is endless.
Most all will be less then 60 watt draw. Im talking draw, not "equivalent" A 60 watt equal in LED will be around 8 actual watts. Just check the label and keep it to 60 or lower, actual wattage of the fixture.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Garage Door opener lighting? [Re: SuperDave456] #4552458
10/23/17 08:21 PM
10/23/17 08:21 PM
CA
raytseng Offline
raytseng  Offline
CA
any led would be good.
cfl would not be good. even the best need time for the ballast to warm up so is not suited for the short term nature.
Re: Garage Door opener lighting? [Re: SuperDave456] #4552582
10/24/17 04:32 AM
10/24/17 04:32 AM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
Before you make any permanent arraignments with LED lights, I'd try them first. I have an old garage door opener and when I tried to install an LED light, it didn't work. Something with the LED didn't play well with the garage door circuitry, perhaps it didn't offer enough load. I had to install a standard incandescent lamp for it to work.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
Re: Garage Door opener lighting? [Re: SuperDave456] #4552635
10/24/17 06:03 AM
10/24/17 06:03 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Thank you,
You will be very happy with a cheap 4 foot LED shop light, wired in to the garage door opener. Costco has a nice one that will work perfectly. I think they consume less than 40W each.
My garage opener has a separate button to control the light. I'm considering adding 2 "shop lights" to the circuit, one on either side of the opener.
Re: Garage Door opener lighting? [Re: SuperDave456] #4552649
10/24/17 06:21 AM
10/24/17 06:21 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
The relatively quick on/off cycles of garage door opener lights will substantially shorten the lifespan of any type of fluorescent bulb, especially CFLs. Have you attempted to order a replacement cover online? The bulbs that have worked best for me are 130V incandescent bulbs. They have thicker filaments by nature - being made for 130V and last for close to ten years. I have separate garage lighting for working out there. My door opener lighting is just the two 130V 60W bulbs which is more than enough for entry and exit from the garage.
Re: Garage Door opener lighting? [Re: SuperDave456] #4552757
10/24/17 07:48 AM
10/24/17 07:48 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I forgot to mention that I've tried LED bulbs in my GDO and they flickered and/or failed prematurely. I don't think that the GDO feeds a full 120V to the bulbs. My opener is a commercial grade Liftmaster so it's a pretty good one.
Re: Garage Door opener lighting? [Re: DBMaster] #4552811
10/24/17 08:36 AM
10/24/17 08:36 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I have been using CFLs in my openers for years and they work fine in fact outlasting heavy duty incandescent bulbs . That being said like anything some last seemingly forever some quit working quicker that expected.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Garage Door opener lighting? [Re: SuperDave456] #4552852
10/24/17 09:11 AM
10/24/17 09:11 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I read this about CFL bulbs a long time ago - that if their on time is less than fifteen minutes on a regular basis they fail prematurely. I experienced that when using them for bathroom lighting. But, maybe not all are subject to that. They definitely don't reach full brightness for about thirty seconds and for that reason alone I never considered them for GDO lighting. I suppose if you went with a higher lumen bulb than the normal 60W incandescent it might not matter.
Re: Garage Door opener lighting? [Re: SuperDave456] #4552880
10/24/17 09:35 AM
10/24/17 09:35 AM
Chatham, Ontario, Canada
cb450sc Offline
cb450sc  Offline
My garage door opener would not work when I put LED lights in it. The door would open from the switch on the wall but would not open from an incoming car. I put the CFL's back in and it is fine.
Re: Garage Door opener lighting? [Re: cb450sc] #4553019
10/24/17 11:29 AM
10/24/17 11:29 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
The circuit boards on some LED bulbs interfere with the radio signal.
Not all. Probably depends on both the opener and the bulb.
You may have better luck with a different bulb, or not...
network down, IP packets delivered via UPS -BOFH
Re: Garage Door opener lighting? [Re: SuperDave456] #4553118
10/24/17 01:06 PM
10/24/17 01:06 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
LEDS not working in garage door openers is a well-known problem. That's why Genie came out with an LED specifically made for garage door openers: http://www.geniecompany.com/garage-door-openers/accessories/led-light-bulb.aspx
I've never actually tried it and don't know how well it works though.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX - totaled
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
