Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
89 registered members (Ablebody, ABomb369, ad244, 2013ecof150, 28oz, 2010Civic, 9 invisible), 1,646 guests, and 52 spiders.
Topics290,666
Posts4,847,899
Members66,011
Most Online3,590
Jan 24th, 2017
Marine diesel 4,000 hour service interval #4552371
10/23/17 07:40 PM
10/23/17 07:40 PM
Georgia
DeepFriar Offline OP
Georgia
Cummins has an interesting set of addon devices that they say enable 4,000 hour service intervals on some of their marine, and I suppose other, diesel engines. They are:
-Centinel which is an integrally plumbed oil system that burns a potion of the in-service lube oil and replaces it with new incrementally over time.
-Prelube with QuikEvac which stores oil under pressure while running and prelubes on restart (ala Accusump). As the name suggests it also quickly removes the sump contents (presumably at the 4,000 hour point, I'm guessing).
-Eliminator which has a 20 micron full flow stainless steel non-replaceable filter allied withva centrifugal separator to remove the rest. Thus, no throwaway filters.I
All three are used in combination to reach the aforementioned 4,000 hour interval "when used with an approved oil sampling program".
https://cumminsengines.com/marine-eliminator
And then look down on the right side of the page for the other accessories.
Re: Marine diesel 4,000 hour service interval [Re: DeepFriar] #4552390
10/23/17 08:12 PM
10/23/17 08:12 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
My FIL and I were just discussing OCIs. He mentioned many boat captains are on a 7 day change cycle which is around 100 hours. That's the 500ish shp diesels on sport fishing boats. Running 40 or15w-40.
4000 hours is a long time. Like roughly a full year of 12hr days.
Re: Marine diesel 4,000 hour service interval [Re: DeepFriar] #4552408
10/23/17 08:23 PM
10/23/17 08:23 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
At roughly the same as 24000 miles at 60mph that seems very reasonable, especially with bypass filtration and TBN replenishment. Long haul truckers go as far, or farther, on OCIs.
Thick vs Thin test: 15k / 43k miles complete
Re: Marine diesel 4,000 hour service interval [Re: Kuato] #4552447
10/23/17 09:13 PM
10/23/17 09:13 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
more like 240k?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Marine diesel 4,000 hour service interval [Re: DeepFriar] #4552489
10/23/17 10:05 PM
10/23/17 10:05 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I assume they must just have a large remote engine oil reservoir and the system adds and removes oil automatically. Not a bad idea compared to weekly changes with a normal sized sump. Plus they burn just mix the old oil in with the fuel, which makes a lot of sense.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: Marine diesel 4,000 hour service interval [Re: Chris142] #4552606
10/24/17 06:24 AM
10/24/17 06:24 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
more like 240k?
Math FAIL.
Thanks for the correction, disregard my previous post....
Re: Marine diesel 4,000 hour service interval [Re: JHZR2] #4553255
10/24/17 04:13 PM
10/24/17 04:13 PM
Georgia
Georgia
Wow, that really is often. I wonder if that's supported/indicated by analysis or is simply "good practice" as defined by the small business/entrepreneurial boat captains who would be out the $200-300K for a repower? It's easy to see that those boats are run hard and with a lot of gear changing. So I further wonder if those 100 hour intervals are for the transmissions (TwinDisc, ZF, others)? Also, while I have no experience with them, aren't the
sportfishers usually very high powered? Very.
Re: Marine diesel 4,000 hour service interval [Re: DeepFriar] #4554594
10/25/17 08:48 PM
10/25/17 08:48 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Our typical small boat (under 65 feet) diesel engine program when I worked for NOAA was OCI at 500 hours with UOA. Since I serviced the boats in my group, or oversaw the service, we did 250 hours. That was mostly CAT 3208T at 240 to 315 HP spinning 2,850 all day every day for 8 hours. They were not rated for 2,850 continuous, but pushing Hamilton Jets drives means you need RPM, so that's what they ran.
10,000 hour inspections for OH. Most went 15,000 hours before an in-frame OH.
The Detroits OTOH, got the full 500 hour intervals and seemed to run until the Sahara would freeze. Of course they changed oil into the bilge underway and required diapers, so not a fair comparo laugh
If I had a big enough boat with twin Cummins and enough room, I'd run the program (and accessories) as stated, but I'd be sampling at every 1,000 hours ... That kind of filtration and in-time replenishment is a good system. You just need to stay on top of it in case something goes off the rails ...
Re: Marine diesel 4,000 hour service interval [Re: BrocLuno] #4555559
10/26/17 07:49 PM
10/26/17 07:49 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
VT 903 Cummins?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
