Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
HVAC help #4552234
10/23/17 05:42 PM
10/23/17 05:42 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
I have an old Rheem furnace that I need to know the amount of gas pressure it needs to read at the pressure tap
"Rheem Imperial Glass Lined" circa 1971
the Model number is 3404-125JD
Serial number CN3D2B3 F3674 1632
125,000 BTU input
100,000 BUT output
thanks
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: HVAC help [Re: Brybo86] #4552261
10/23/17 06:08 PM
10/23/17 06:08 PM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
its blurred in your picture but its in the lower left hand corner of the plate...... "WC that is inches of Water Column. there are conversion tables to turn that into psi
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Mobil1 0W-40
Re: HVAC help [Re: Brybo86] #4552269
10/23/17 06:11 PM
10/23/17 06:11 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
You can punch in your Water Column here and it will convert it to PSI for you.
https://www.google.com/search?client=ope...-8&oe=UTF-8
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: HVAC help [Re: Brybo86] #4552291
10/23/17 06:25 PM
10/23/17 06:25 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
the EXT static pressure is just the air pressure created inside by the blower running
I need to know the manifold gas pressure im thinking it should be about 3.5" WC pressure
but i cannot find it listed anywhere on the unit
01 Kymco People 50
95 Yamaha Jog
Re: HVAC help [Re: Brybo86] #4552352
10/23/17 07:13 PM
10/23/17 07:13 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Time for new furnace. 1971 is OLD
2015 Ford F250 w/Powerstroke
Re: HVAC help [Re: Brybo86] #4552356
10/23/17 07:17 PM
10/23/17 07:17 PM
Florida
FSully1 Offline
FSully1  Offline
Florida
Old but........build date was 36th week of 1974 in Fort Smith, Arkansas
Re: HVAC help [Re: Brybo86] #4552396
10/23/17 08:16 PM
10/23/17 08:16 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The condensing and modulating gas furnaces will be significantly more efficient.
Re: HVAC help [Re: Brybo86] #4552502
10/23/17 10:46 PM
10/23/17 10:46 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Hey we are at 3.5"WC
01 Kymco People 50
95 Yamaha Jog
Re: HVAC help [Re: Brybo86] #4552616
10/24/17 06:40 AM
10/24/17 06:40 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
3.5" wc is about right if you're on NG. (Propane would be around 11.5" wc or so).
Make sure you're measuring that wc when ALL devices are in operation. Your gas system needs to be sized and regulator set such that is can supply the pressure (3.5" wc) when not only it is running, but also all other gas appliances simultaneously. You may need to make altitude corrections if above 3000 feet (that's a generic answer for all; it won't be an issue in the Windy City).
BTW - your homemade manometer is nice. That's exactly how I did it when setting my propane regulator. No one needs an expensive tool when homemade gives you the correct answer!
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: HVAC help [Re: Brybo86] #4552931
10/24/17 11:24 AM
10/24/17 11:24 AM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Thanks for your reply dnewton!
01 Kymco People 50
95 Yamaha Jog
Re: HVAC help [Re: Brybo86] #4552937
10/24/17 11:30 AM
10/24/17 11:30 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
A a child of the 1980's (just barely though), they must has had a sale on green/yellow pigments in the 1970's because everything was this colour it seems. LOL
Re: HVAC help [Re: Brybo86] #4552989
10/24/17 12:04 PM
10/24/17 12:04 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Isn't gas pressure to homes regulated at about 1 psig or less?
Re: HVAC help [Re: Brybo86] #4553146
10/24/17 02:28 PM
10/24/17 02:28 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
1971 ?!?!?!
I sure hope you have MULTIPLE working CO detectors in this dwelling
(and that they're not older than a few years old; they do 'wear out' and old ones (pre 2009) give NO WARNING at all . . .)
Re: HVAC help [Re: Brybo86] #4553344
10/24/17 05:29 PM
10/24/17 05:29 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
I have a couple brand new carbon monoxide detectors all testing well.
Where would this supposed Carbon monoxide come from?
I have inspected heat exchanger already, no cracks.
Also think about this,
the air in the actual heat exchanger is under much lower pressure than the air outside the heat exchanger that is being compressed by the blower.
With a crack or even a hole, the air is going to be pushed INT0 the heat exchanger which would cause the flame to look different or wavy. If really bad the flame would be pushed out of the front of the furnace where the gas and air enter.
01 Kymco People 50
95 Yamaha Jog
