Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
23 registered members (dlundblad, Char Baby, 53' Stude, ARB1977, earlyre, D0nat, 1 invisible), 813 guests, and 32 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
Mahle vs Purolator in M276 Mercedes Engines #4551975
10/23/17 12:00 PM
10/23/17 12:00 PM
San Diego
FlyPenFly Offline OP
San Diego
Currently have this installed:
https://www.amazon.com/Mahle-OX814DECO-Oil-Filter/dp/B00I2JH7U2/
I was surprised how dainty and small these were. I think these also aren't exactly the same as Mercedes OEM either now. Considering using one of these:
https://www.amazon.com/Purolator-PBL38165-PurolatorBOSS-Premium-Filter/dp/B06XQL3RG1/
They are far bigger and feels much more solidly constructed and substantial.
Thoughts on switching over?
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2007 Suzuki Grand Vitara 2.7L V6
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4551978
10/23/17 12:05 PM
10/23/17 12:05 PM
GA
drtyler Offline
drtyler  Offline
GA
Why not run it and just use the Puro next time? It may not be exactly the same as the original filter, but I'm sure it's built fine. Every Mahle filter I've ever used has held up well (primarily BMW's).
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4551997
10/23/17 12:32 PM
10/23/17 12:32 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Why am I getting this funky URL rather than the Amazon URL like show on the screen?
http://rd.connexity.net/rd?mid=184056&cat_id=22000200&atom=10681&prod_id=&oid=7272553197&pos=1&b_id=18&bid_type=4&bamt=45e4b920dcffc474&cobrand=1&ppr=df41d6c974344d6f&af_assettype_id=12&af_creative_id=2973&af_id=26865&af_placement_id=1566445&dv=903ef2dc443ab2e9e20fdb86c0ef9f26&af_campaign_id=j94ioq2r7h00xkod02m9y&t=http%3A%2F%2Fwww.amazon.com%2Fdp%2FB06XQL3RG1%2Fref%3Dasc_df_B06XQL3RG15210525%3Fsmid%3DATVPDKIKX0DER%26tag%3Dshopzilla0d-20%26ascsubtag%3Dshopzilla_rev_121-20%3B15087834109228474253210090301008005%26linkCode%3Ddf0%26creative%3D395093%26creativeASIN%3DB06XQL3RG1&br=14970947005651589313309990099003372&roi_cookie=15087833679169460572610070301008005%7C184056%7E15087833349538474133010090301008005%7
The seems to be happening a lot lately and it just hangs.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4552000
10/23/17 12:36 PM
10/23/17 12:36 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
wow, expensive filter's...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive185k miles
Last Change;
50/50 QSUD, QSHM. 5w30
Fram XG8A, Fram CA8141
Currently under the influence of oil shocked2
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: JohnnyJohnson] #4552079
10/23/17 02:00 PM
10/23/17 02:00 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Malware? If I click the links in the first post it goes right to Amazon for me.
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4552081
10/23/17 02:02 PM
10/23/17 02:02 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Mercedes used the Mahle style filter, I would stick with that, although that Mann would most likely work just as well. Also Purflux makes these for Mercedes and they are much more inexpensive if you buy from them.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: JohnnyJohnson] #4552185
10/23/17 04:01 PM
10/23/17 04:01 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Off topic, but you have a browser hijacker.
"Indicator of Compromise - Hostname: pxl.connexity.net. A hostname is an indicator of compromise commonly used as a target for communicating with malware, ..."
Various musings: http://hangfire.net
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4552346
10/23/17 06:09 PM
10/23/17 06:09 PM
USA
slacktide_bitog Offline
USA
That Mahle seems to be a reboxed Purflux with the intentionally-wavy "chevron" pleats for more media surface area.
Purolator is Mann now, and the Boss uses the same fleece media and plastic mesh as some Mercedes OEM filters that Mann supplies. And for those OE-fleece applications, Mann puts that OE fleece filter in the 6-sided Boss Box.
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4552518
10/23/17 10:20 PM
10/23/17 10:20 PM
San Diego
San Diego
Okay so I can definitely confirm that the Mahle filters are not wavy but just straight pleats unlike the photos.
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4553315
10/24/17 03:59 PM
10/24/17 03:59 PM
USA
USA
Do you have a pic of one? smile
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4555056
10/26/17 10:49 AM
10/26/17 10:49 AM
San Diego
San Diego
The Mahle looks just like this:
Here's a Mann Filter I'm also considering:
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4555058
10/26/17 10:50 AM
10/26/17 10:50 AM
San Diego
San Diego
In fact, I'm thinking the Mann filter although not OEM might be the best bet here? Or maybe the Purolator BOSS?
The Mahle is seriously dainty.
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4555322
10/26/17 03:38 PM
10/26/17 03:38 PM
USA
USA
My first choice would be the Purflux L394, with Mann also being a good choice. The Boss is a reboxed Mann, so that is good too if the price is competitive.
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4555522
10/26/17 06:17 PM
10/26/17 06:17 PM
San Diego
San Diego
Ah well the Purflux L394 costs the same as the Mann filter on eBay, around $12. Is the Purflux a better choice?
Re: Mahle vs Purolator in M276 Mercedes Engines [Re: FlyPenFly] #4555596
10/26/17 07:36 PM
10/26/17 07:36 PM
USA
USA
For the same price, I'd try the Purflux. It has more media due to the special pleating (they can cram in more media in the same size cartridge). There's an eBay listing with them 2 for $20
I also saw some Purfluxes in Mercedes boxes. Purflux might have been the OE supplier, or maybe they switched to or from Purflux.
But either way, both should serve you well smile
