My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned - I let someone else change my oil
by 901Memphis. 12/15/18 01:57 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
46 registered members (Aero540T, Artem, anndel, Anduril, another Todd, 5 invisible), 1,490 guests, and 41 spiders.
Topics295,133
Posts4,928,308
Members66,691
Most Online2,553
Oct 27th, 2018
Fresh Motor, What Oil? #4551961
10/23/17 11:46 AM
10/23/17 11:46 AM
Louisiana
Zack_Grill Offline OP
Louisiana
I'm new to the forums, so I hope I followed the rules.
I have a 93 Toyota MR2 Turbo.
I need advice on break in oil, how long to run it, and what oil to switch to once that is done. Filter advice would be awesome as well!
Motor is currently on a stand and being put together by myself...
Engine builder and machine shop installed Wiseco pistons, Eagle rods, King bearings all into a 5sfe block out of a 98 Camry. I'm using a 3sgte cylinder head. Cylinder head has BC racing 264 cams, 1zz shimless buckets, and ATS valve springs. Rev limit will be increased a solid 1,000rpm for a redline of about 8,500. It's using a 5sfe oil cooler, and oil pump; oil filter relocation (-10AN lines) is being put together as we speak to clear the exhaust. The block is capable of holding about 700whp(rods being the limitation), turbo (BorgWarner S252 journal bearing) and fuel system are only good for about 450hp which is were I plan on keeping it. Oh, and it will be running on corn.
The car is going to be street driven, some drag racing, little to no road racing or autox. Solid even mix of highway and city miles. Probably less than 5000 miles a year. Trap speed will be an estimated 120-130 mph, so it will see some speed at the strip.
I know the factory oil was Eneos 5w30 - here are the specs on it, but I doubt that matters now.
I'm a pretty big T6 fan, which I use in my truck and my GLHS, but I didn't think it would be a fitting application for the fresh motor.
So what is the best break in oil to use?
How long do run the break in oil?
What oil do switch to once that is done?
Knowledge talks, wisdom listens
1993 Toyota MR2 Turbo - 5SGTE - 2.2L
1986 Shelby GHLS - Turbo II - 2.2L #219
1993 Toyota Pickup - 22RE - 2.4L
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4551968
10/23/17 11:53 AM
10/23/17 11:53 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Joe Gibbs 5W-30
They also have a few other grades.
"Zed's dead baby, Zed's dead."
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4551971
10/23/17 11:55 AM
10/23/17 11:55 AM
San Diego
FlyPenFly Offline
FlyPenFly  Offline
San Diego
If it were me, I'd probably use Redline 10w40 or Castol 0w40.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2007 Suzuki Grand Vitara 2.7L V6
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552005
10/23/17 12:42 PM
10/23/17 12:42 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
ask the engine builder for their recommendation.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Fresh Motor, What Oil? [Re: Bgallagher] #4552040
10/23/17 01:26 PM
10/23/17 01:26 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
That would be too easy because why trust a guy that builds engines and sees what does and doesn't work. Heck lets ask People who don't know the difference between a clearance and the tolerances.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552073
10/23/17 01:57 PM
10/23/17 01:57 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
There are many, many opinions on oils and break-in oils. If your engine has solid or sliding lifters then conventional wisdom is to use a higher ZDDP oil for break-in and thereafter. But according to one guys testing, he says this is bogus. It's more about the oil's film strength. If you have time to read some and read fairly fast, then check out his longstanding blog here. If you want to see his ratings based on his test results, then scroll down the very long page to the numbered ratings. He tends to update some oils as formulations change.
The reality is that there are now additives in some oils that are more effective and better overall than ZDDP ever was. There are high quality oils such as the German-made Fuchs GT-1 that contain no ZDDP yet have excellent wear control. There are a few high quality aftermarket oil additives that safely boost the anti-wear and anti-friction of almost any standalone forumlation, without reducing the overall effectiveness of the rest of the oil's additive package.
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552077
10/23/17 01:59 PM
10/23/17 01:59 PM
Toronto, Canada
LaszloToth Offline
LaszloToth  Offline
Toronto, Canada
Builders usually provide a break-in procedure when they release a rebuilt engine. Since you're doing it yourself, you're reaching out for advice.
My built engine came with instructions for a 20 min oil change followed by a 100 km oil change and then a 1000 km oil change. They say used conventional oil for the initial 2 oil changes and after that move to a synthetic oil for the standard oil change interval. I heard conventional is better for ring seating and it's cheaper as well.
Here's a link example:
MAP's proper engine break-in procedure
After that my engine assembler suggested xW-40 oil because of the forged pistons.
White '11 STi
Buckle up. The new Subaru WRX STi is here.
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552082
10/23/17 02:03 PM
10/23/17 02:03 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
I am going this weekend to the Charlotte NC Dirt Track to check out a new product that has dramatically improved the durability of many race engines for break-in and during the whole season, along with multiplying the typical oil life of the race engines by many times. The guys that have been using this additive for the last several years are all using/testing in their tow vehicles and personal vehicles as well with great results. That's all I can say for now. I have yet to try the product.
Re: Fresh Motor, What Oil? [Re: CT8] #4552101
10/23/17 02:27 PM
10/23/17 02:27 PM
Louisiana
Louisiana
God forbid you want a second opinion, right? /s
Engine builder has yet to get back with me after a couple days, so I went the collective route. Motor is far from done, so it's not like I'm starting it tomorrow.
Re: Fresh Motor, What Oil? [Re: CT8] #4552165
10/23/17 03:41 PM
10/23/17 03:41 PM
out there
spasm3 Offline
spasm3  Offline
out there
Who are you talking about? Perhaps there are some people here who have built engines. I agree with asking the builder, but no reason to bite the hand of someone asking a question.
OP, I would want a high zinc oil, and i would want to know what the main and rod bearing clearances are.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Fresh Motor, What Oil? [Re: LaszloToth] #4552258
10/23/17 05:04 PM
10/23/17 05:04 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
This ^
My personal regimen differs slightly from the above, but it's close enough. Use either, or one similar.
First change after it's been properly run up on the stand. 20 minutes? Close enough.
Second change after 50 engine hours / 500 mi / 750 kM. Switch to synthetic at this point.
With your motor, xxW-40 or xxW-50.
Because lots of top end race parts and turbo, plus your indicated desire to run to 8500 (which is a lot of stress on the rods. Do your math for piston speed and buy a pill for that RPM for fuel cut / rev limiter). REMEMBER: if you do something stupid with a manual transmission and a downshift, the rev limiter won't help you; it will spin to 10,000 rpm with no fuel and a bad downshift, and the rods will suffer that day.
Next change at 2,000 mi / 3000 kM.
Determine OCI with the help of the 2k/3k Blackstone report, but if you are going to see track duty, you probably are going to be changing often by street car standards.
Good luck.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Fresh Motor, What Oil? [Re: bmwtechguy] #4552282
10/23/17 05:18 PM
10/23/17 05:18 PM
Johnny2Bad Offline
Johnny2Bad  Offline
He's using a cam with "shimless buckets" (which I've never heard of, but perhaps he means 'shim under bucket'; in any case directly acting on the valves; no lifters involved).
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552302
10/23/17 05:33 PM
10/23/17 05:33 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
8,500 RPMs is 1,000 more than stock?
My Camry has the same engine and doesn’t rev over 5,600 RPMs
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552349
10/23/17 06:10 PM
10/23/17 06:10 PM
Louisiana
Louisiana
Sadly, I don't know them. Engine builder might remember, but I highly doubt it. He's a busy guy, so I'll ask, but I doubt I'll get a response any time soon. There where some numbers sharpied on all the piston tops (3.441) but I'm not even going to lie and say I know what that means.
No they are shimless. Solid individual buckets. Each one is a set size, not shim under bucket. Look at the 1zzfe engine for more details.
This ^
Good luck.
Thanks for the detail. It is running MSPNP, so rev limit I believe is handled. It uses both spark and fuel cut set for both Rev limit and launch control. Launch control is currently off of a clutch switch, which may be changing in the future. I'm a granny shifter, and not competitive, so hopefully the only miss shifts will be trying to get it in reverse lol. Thanks for the mileage suggestions.
Can't say I know what the piston speed would be, but I'll look into it.
The 5SFE rev's really low because it is single cam. The 3SGTE head I'm using is dual cam with a rev limit of about 7,000 RPM. Considering the cam profile, I should be able to squeeze a little more useable power band out of it, but the last 500 rpm will probably only be for track duty depending on wheel size and gearing of the run so I don't have an extra shift. I highly doubt it will make any extra power past 8Krpm, but some shimless bucket motors rev to 9Krpm, so it's not out of the realm of possibility.
Side note, incase you didn't know, the 96-98 5SFE blocks and cranks out of Camry's are extremely strong. 1000+hp strong. Sadly, I've already cracked one 3SGTE block, thus the Frankenstein motor.
Re: Fresh Motor, What Oil? [Re: Zack_Grill] #4552361
10/23/17 06:24 PM
10/23/17 06:24 PM
Louisiana
Louisiana
Here's a picture of the motor for those few that might be interested.
