Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
28 registered members (dlundblad, 53' Stude, Char Baby, ARB1977, D0nat, biron, 1 invisible), 829 guests, and 33 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
Quick question radiator d&f w/ pressurized tank. #4551925
10/23/17 11:07 AM
10/23/17 11:07 AM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
Hey bitog.
First time working on a system with a pressurized tank (no radiator cap), in this case 09 Equinox. Though not my preferred procedure, 'this time' I'm just wanting to do a single radiator d&f.
So the question is, is draining and filling through the tank the same as if it had a radiator cap? In other words, the tank will drain with the radiator, and fill the radiator after it's empty. Am I missing anything? Don't want mess with upper rad hose removal for fill as it's obstructed by battery and compartment.
As an aside, tried using the petcock with quarter turn counter clockwise with tank cap off, nothing. Don't want to mess with it more as research indicates it's easily broken (~$24+ to replace). So before I pull the lower radiator hose want know if sebsequent fill process with be seamless. Also I'm hoping cap off tank procedure will work to bleed system as the one bleeder valve looks really flimsy and some research indicates it's easily broken too.
Re: Quick question radiator d&f w/ pressurized tank. [Re: Sayjac] #4551958
10/23/17 11:46 AM
10/23/17 11:46 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
If it's anything like most newer GMs, it will be a royal PITA! Everytime I do any cooling system work on my parents Impala, I have to buy a new drainplug, and it's darn near impossible to get the air out without a vacuum filling system.
I'd pull the lower hose if it's accessible; if not, buy a new drainplug before you do it. Also, buy a Lisle Spill free funnel to hook onto the overflow tank to get air out, as you'll likely have to have the cap off and wait till the thermostat opens to purge the big air pockets, and it'll blow up everywhere without the Lisle funnel.
Re: Quick question radiator d&f w/ pressurized tank. [Re: Sayjac] #4551969
10/23/17 11:53 AM
10/23/17 11:53 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Re: Quick question radiator d&f w/ pressurized tank. [Re: Drew99GT] #4551974
10/23/17 12:00 PM
10/23/17 12:00 PM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
Thanks Drew. Pulled the lower rad hose, poured out and tank just about empty empty. Too bad petcock didn't work, would have been less messy but that's ok. Really the Dex didn't look too bad so single d&f may be appropriate. Now just hope fill goes as smoothly. Going to measure how much came out so have an idea what should go back.
Got to get back to it as replacing tstat and coolant temp sensor while I'm at it. We'll see how it goes with the refill and burp.
Edit. Your link looks for newer generation, 09 and some of that generation Equinox threads indicate fill through tank will work. Fingers crossed.
Re: Quick question radiator d&f w/ pressurized tank. [Re: Sayjac] #4552022
10/23/17 01:07 PM
10/23/17 01:07 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
If you have any trouble purging air, remember the Lisle funnel! I'm telling you, that thing has been a life saver for me on stubborn hard to bleed cooling systems like the Impala. Just don't fill the system too much so there's room for expansion in the funnel.
Re: Quick question radiator d&f w/ pressurized tank. [Re: Drew99GT] #4552035
10/23/17 01:22 PM
10/23/17 01:22 PM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
Got it, thanks. Notice a couple parts stores have it in stock. Tstat and sensor done, headed to get some Dex now.
