New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
97 registered members (alphadog, AdditiveOCD, ammolab, 2015_PSD, 53' Stude, 2009Edge, 11 invisible), 1,936 guests, and 29 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
My experience with Seafoam #4551921
10/23/17 12:03 PM
10/23/17 12:03 PM
California
Kool1 Offline OP
Kool1  Offline OP
California
With 206,000 miles on my 03 CRV, I am using about 1 quart of oil every 2,000 miles. I read a lot about people using Seafoam to free up stuck rings and clean out carbon from the combustion chambers. I figured, "what the heck, for a few dollars I'll try it". Yesterday I poured about 1/3 a bottle of Seafoam into my power brake vacuum port with the engine at about 1,200 rpm. I poured it in slowly as the engine almost died a couple times. It took me a few minutes to pour in 1/3 of the bottle as white smoke filled the parking lot. I did this in the O'Reilly Auto Parts parking lot and nobody even gave me a second look. I waited 15 minutes and drove off leaving the whole neighborhood clouded in white smoke.
When I got home I changed the oil and could smell the Seafoam odor from the valve cover when I took off the oil fill cap so obviously Seafoam worked its way into the crankcase.
This morning I drove the CRV around and could tell by my seat of the pants dyno that I don't press so deep into the gas pedal to move the vehicle. I would say I have less of a lag in acceleration. I believe this means I cleaned carbon from stuck rings and the rings are now doing a better job at sealing compression in the combustion chamber. Hopefully the oil control rings will seal better whereby they will prevent oil from entering the combustion chamber. I'll keep an eye on the oil level and keep my fingers crossed.
Re: My experience with Seafoam [Re: Kool1] #4551947
10/23/17 12:37 PM
10/23/17 12:37 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
You may want to ask to have this thread moved, as you put it in the cooling system section.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: My experience with Seafoam [Re: Kool1] #4551949
10/23/17 12:39 PM
10/23/17 12:39 PM
California
Kool1 Offline OP
Kool1  Offline OP
California
Oops, you're right. I'll ask the moderators to move it. Thanks.
Re: My experience with Seafoam [Re: Kool1] #4552016
10/23/17 02:00 PM
10/23/17 02:00 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
I use Seafoam in my Toyota about every other OCI. I can't say it really helps but it hasn't hurt and the Corolla is very stingy on oil.
2004 Corolla 130880
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: My experience with Seafoam [Re: Kool1] #4552028
10/23/17 02:14 PM
10/23/17 02:14 PM
America
Alfred_B Offline
Alfred_B  Offline
America
Re: My experience with Seafoam [Re: Kool1] #4552052
10/23/17 02:38 PM
10/23/17 02:38 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I have a car in a similar situation and I am very sceptical of any "cure in a bottle" but I just recently used seafoam to soak the pistons. Makes sense it could work if the problem is stuck rings but I'll have to wait and see if the oil consumption drops. There's a sucker born every minute.
Re: My experience with Seafoam [Re: Kool1] #4552192
10/23/17 05:10 PM
10/23/17 05:10 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
There was a post yesterday about pouring a gallon of general purpose degreaser into the oil, run for a short period and then follow it with a Quart of M1 and a whole bottle of MMO to polish the engine internals.
You should try this and post a video, I hear it works wonders. LOL
J/K. Thanks for posting your experience with Seafoam, I would be interested to hear if it helped with your oil consumption. thumbsup
'18 Caravan - 30k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: My experience with Seafoam [Re: Kool1] #4552257
10/23/17 06:04 PM
10/23/17 06:04 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
I've used it once in my oil letting the engine idle for a half hour, then changing it all out...looking at the oil afterwards It definitely cleans an engine...just not sure if it can do more harm then good, what does it do for the seals and gaskets, bearings ect... shrug
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PP, PPHM 50/50 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: My experience with Seafoam [Re: Alfred_B] #4552562
10/24/17 04:07 AM
10/24/17 04:07 AM
New York/USA
Joeescape63 Offline
Joeescape63  Offline
New York/USA
Well played sir.
2018 Subaru Forester Touring
2.5L engine/CVT
Subaru Filters/Castrol Edge 0W20
Re: My experience with Seafoam [Re: Kool1] #4552568
10/24/17 04:16 AM
10/24/17 04:16 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Water seems to work.
Brake fluid might work too, but might be best used before an oil change, in case it gets into the sump.
Re: My experience with Seafoam [Re: Kool1] #4552645
10/24/17 07:20 AM
10/24/17 07:20 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Seafoam and B12 seem to work well for OPE for me. I have three chainsaws two of which came my way free. I used Seafoam this time to clean up the carbs and was able to get the two non-running machines going. I've also used Amsoil Powerfoam with good results for cleaning OPE carbs and piston tops up.
God Bless Our Troops
Re: My experience with Seafoam [Re: Kool1] #4554734
10/26/17 12:08 AM
10/26/17 12:08 AM
California
jj51702 Offline
jj51702  Offline
California
Id probably look at having the pcv valve replaced first (if serviceable) before I went the seafoam route to decrease oil consumption. This seems to have worked for many in the past including myself.
Re: My experience with Seafoam [Re: Kool1] #4555384
10/26/17 05:50 PM
10/26/17 05:50 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
KREEN!
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: My experience with Seafoam [Re: Kool1] #4562078
11/02/17 01:25 PM
11/02/17 01:25 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
02-03 CRV's with the K24 were infamous for oil consumption. My 03 had 180k on it and ate a quart of oil ever 500 miles. It ran great and didn't smoke at all but eventually the CAT began clogging and the 02 sensor failed leaving a constant CEL on. The oil control rings were the culprit in these and nothing you do will help it, trust me I tried!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
