A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
17 minutes 10 seconds ago
2003 Honda power steering problem
by hogpops
23 minutes 59 seconds ago
Public Service Announcement: Flush Your HW Heater
by gathermewool
28 minutes 5 seconds ago
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
31 minutes 47 seconds ago
Castrol 0W40 vs 5W40??
by Realfine69
50 minutes 54 seconds ago
Paint impurities on a new car
by Quattro Pete
Today at 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
Today at 02:41 PM
Do people buy from telemarketers?
by Chris142
Today at 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
Today at 01:54 PM
Sonoma Raceway
by Warstud
Today at 01:51 PM
Zipcode error
by aquariuscsm
Today at 01:36 PM
NHRA drag racing Racing question??
by daddi
Today at 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
Today at 01:20 PM
Removing Broken Bathtub Drain
by Warstud
Today at 01:15 PM
Buffer Pads
by TheLawnRanger
Today at 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
Today at 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
Today at 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
Today at 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
Today at 12:34 PM
Grit guard wash board
by JC1
Today at 12:22 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
96 registered (87sammy, aquariuscsm, BAJA_05, 1JZ_E46, Artem, Astro14, 6 invisible), 1544 Guests and 34 Spiders online.
65312 Members
67 Forums
285926 Topics
Page 1 of 2 1 2 >
#4551910 - 10/23/17 11:56 AM Acura Legend ATF recommendation
glmtd Offline
Loc: Seattle
Hello, I am looking for ATF recommendation for 1994 Acura Legend L Sedan with 75k miles. Thanks!
#4551915 - 10/23/17 12:01 PM Re: Acura Legend ATF recommendation [Re: glmtd]
ThirdeYe Offline
Loc: Grand Rapids, MI
Im assuming they called for Z1 when new... I like sticking with Honda OEM z1 or dw1, but ive also had good success with Amsoil universal atf in my old 95 Acura Integra. Shifted like new when I sold it at 20 years old with 217k on it.
P.s. a 94 legend with only 75k? That would be awesome to find. I test drove a 93 with about 100k on it back in 04 and loved it.
07 Honda Accord - 598k - Valvoline 5W-20/Purolator Synthetic PSL14610
#4551928 - 10/23/17 12:09 PM Re: Acura Legend ATF recommendation [Re: ThirdeYe]
glmtd Offline
Loc: Seattle
Thank you for your recommendation. Yes, I am pretty excited about the car, a family friend had it, over the last 10 she maybe put 5k miles on it.
#4551929 - 10/23/17 12:09 PM Re: Acura Legend ATF recommendation [Re: glmtd]
pbm Offline
Loc: New York
When I had my 2001 Accord I found that Castrol IMV worked very well as did VML ATF......I didn't find the Honda Z-1 to be anything special.
'Journalism is Dead'
#4551950 - 10/23/17 12:40 PM Re: Acura Legend ATF recommendation [Re: glmtd]
thrace Offline
Loc: USA
You can still find Owners Manual online. It says Dexron II. Maybe 1994 is before infamously bad Z-1 was introduced. Since you cannot buy newly made Dexron II or Z-1, might have to try Dexron III or a multi vehicle ATF.
http://owners.acura.com/vehicles/information/1994/Legend/manuals
http://techinfo.honda.com/rjanisis/pubs/OM/LG9494/LG9494O00158A.pdf
Preferred engine oil is 5W30
http://techinfo.honda.com/rjanisis/pubs/OM/LG9494/LG9494O00149A.pdf
If it misfires, look for oil in the distributor.
Edited by thrace (10/23/17 12:41 PM)
#4551972 - 10/23/17 12:57 PM Re: Acura Legend ATF recommendation [Re: glmtd]
86cutlass307 Offline
Loc: Wichita Falls, TX
Redline D4 will make your Honda/Acura very happy and unless you drive it extremely hard, allow you to push the drain and fill intervals. Redline is a little more expensive...especially in the case of a 3x drain and fill conversion, but worth it in my opinion. We had a 2004 Accord V6 sedan that we were able to get 188K out of the auto trans before failure of 2nd gear; even with their design flaws. I have no affiliation with Redline but have been a user in various forms since the early 90's and have no complaints.
2014 Honda Accord EX-L, CVT 4 cyl.
2009 Toyota Tacoma TRD Sport 4.0L
1986 Olds Cutlass Supreme Brougham-2nd owner (rust free)
#4552056 - 10/23/17 02:41 PM Re: Acura Legend ATF recommendation [Re: glmtd]
69GTX Offline
Loc: Connecticut
How long your transmission lasts will be a combination of
How reliable the transmission is straight from the factory (the typical trans)..some are much better than others.
The odds that you got a transmission built a lot better or a lot worse than a "typical" one.
Using the proper fluid
Changing the fluid as recommended
How the car gets driven - driving styles - short trips/long trips/heavy pedal or light pedal.
Environment/ambient temps typically seen
No one thing guarantees a long transmission life. But if there was one better than the others, it's probably changing the fluid and filter frequently enough. And sometimes that's more often than what the OEM recommends.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4552110 - 10/23/17 03:37 PM Re: Acura Legend ATF recommendation [Re: 69GTX]
JC1 Offline
Loc: Oshawa, Ontario Canada
Valvoline Max life would be my choice.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4552113 - 10/23/17 03:42 PM Re: Acura Legend ATF recommendation [Re: thrace]
mightymousetech Offline
Loc: Ontario, Canada
Honda says to use DW-1 now.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4552175 - 10/23/17 04:55 PM Re: Acura Legend ATF recommendation [Re: glmtd]
thorromig Offline
Loc: BerksCounty/Pa.
Throw in the DW-1 and a bottle of Lube Guard Red. Best wishes with the Acura & luv the low mileage on yours!!
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
#4552186 - 10/23/17 05:01 PM Re: Acura Legend ATF recommendation [Re: ThirdeYe]
slacktide_bitog Online   content
Loc: USA
Maxlife ATF is good stuff. Full synthetic and at a great price by the gallon at Walmart or Autozone. It will give you years of trouble-free miles smile
AAP has Castrol Full Synthetic ATF on sale 2 quarts for $11 (must buy in multiples of two). Sale ends 10/28
Z1 did not exist until 2000. Before that, they just used Dexron II/III smile
#4552391 - 10/23/17 08:12 PM Re: Acura Legend ATF recommendation [Re: glmtd]
glmtd Offline
Loc: Seattle
Great, thank you for your recommendations. Maxlife ATF seems like the best choice. Before this thread I was thinking about Castrol Transmax Import ATF.
#4552413 - 10/23/17 08:26 PM Re: Acura Legend ATF recommendation [Re: glmtd]
hallstevenson Offline
Loc: Ohio
I've read many good things about Castrol's ATF. People like Valvoline because it works well and is real inexpensive. I wouldn't hesitate to go with either.
#4552416 - 10/23/17 08:28 PM Re: Acura Legend ATF recommendation [Re: slacktide_bitog]
Loc: Ohio
I believe it existed before 2000. I have a '99 Accord that specs Z1. That suggests it existed in '96-98 when this generation was being developed.
#4552446 - 10/23/17 09:12 PM Re: Acura Legend ATF recommendation [Re: glmtd]
Sayjac Offline
Loc: The Old North State
Another vote for MaxLife Synthetic ATF. Valued priced in gallon size (~$18 WM online order). Anecdotally have over 150k miles between two Hondas specing Z1. IMO, should work well in your application.
75k miles on a 94 legend, wow that's low miles. Good for you.
Page 1 of 2 1 2 >
