Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
106 registered members (77GrandPrix, 4WD, 1.8Tango, 18 invisible), 2,375 guests, and 33 spiders.
Topics296,880
Posts4,960,779
Members66,987
Most Online2,688
Jan 19th, 2019
adjusting unloader on a pressure washer? #4551843
10/23/17 09:56 AM
10/23/17 09:56 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I called that hotsy place that another member on here suggested and talked to two different people. One guy said one thing, the other said something else. I want to run a surface cleaner and off my 3.5gpm 4000psi pressure washer and most cleaners are only rated at like 3500psi. I asked if they make a fitting that lowers the pressure similar to how they make bigger nozzles to put out a lower pressure through the wand. It seems they don't make anything like that to hookup a lower rated pressure surface cleaner.
Now to my question: They both say that running a surface cleaner that's rated at a max psi of 3400 would damage the pump since it puts out 4000psi due to too much back pressure. Sounds right to me, but one guy says that since you bought a gauge to hookup to the wand that I can just reduce the pressure with the unloader, but the other guy I talked to says doing that would still create excess backpressure in the pump. So who is right? The first guy said most people say not to mess with the unloader because they do it without a gauge and end up over adjusting it, but he said since I have a gauge and I'm lowering the pressure, it won't hurt anything. Opinions? Will the unloader still work at a lower psi?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: adjusting unloader on a pressure washer? [Re: motor_oil_madman] #4551935
10/23/17 11:23 AM
10/23/17 11:23 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
You are missing a key point.
Pressure is related to flow.
That is why my [email protected] pressure washer puts out 1600psi with the delicate nozzle that flows around 3gpm.
You need a surface washer that will flow enough.
and the pressure will take care of itself.
That being said having a commercial pressure washer you probably need a commercial surface washer.
something like this
http://www.homedepot.com/p/RIDGID-Profes...31018/205581981
would probably work.. it has bigger jets on it and 18" so its made to flow more water.. than most.
