Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
115 registered members (1978elcamino, addyguy, alphadog, Alfred_B, 69Torino, 11 invisible), 2,410 guests, and 55 spiders.
Topics286,019
Posts4,900,869
Members67,548
Most Online2,967
Mar 10th, 2019
No TBN requirements for API but yes for ACEA PCMOs #4551526
10/22/17 10:43 PM
10/22/17 10:43 PM
Malaysia
zeng Offline OP
zeng  Offline OP
Malaysia
Why is that so ?
How low a TBN can a weak SN/SM/SL go ?
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: zeng] #4551561
10/22/17 11:53 PM
10/22/17 11:53 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Maybe the extended oil change interval?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: zeng] #4551568
10/23/17 12:24 AM
10/23/17 12:24 AM
Malaysia
zeng Offline OP
zeng  Offline OP
Malaysia
Good point.
An ACEA would provide an 'assured' minimum OCI with this logic.
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: zeng] #4551582
10/23/17 02:01 AM
10/23/17 02:01 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
There's an interesting story here...
Up until a few years ago, there were no minimum TBN limits on either API PCMO or ACEA Conventional (ie not Low SAPS) PCMO.
Regarding API, although TBN has never been specified, there is an implicit 5 minimum TBN limit. This is what you typically need to pass the Ball Rust Test. This usually gets upped to around 8-ish with the extra 3 TBN being a highly cost-effective contribution to controlling oxidation in the early stages of the Sequence IIIF/IIIG test.
Regarding ACEA oils, you have to understand that stuff like A3/B3/B4 usually evolves as a secondary, not a primary oil spec. Ten years ago, if you picked up any can of oil in Europe, you would see it carried BOTH API & ACEA credentials (eg SL/CF/A3/B4). Indeed, the ACEA oil specs used to contain some US tests as well as European ones (don't ask me why, is just is!)
Anyway, because of this, in developing a Euro oil, you might typically start out developing a US oil (possibly with a boosted, more seal friendly DI). Once you had the relatively easy (primary) US tests in the bag, you might start in earnest on the (secondary) ACEA tests.
If you do things this way, you might expect to start your ACEA testing with an 8 TBN oil as it simply carries over from the US tests. As often as not, you could finish your ACEA program without upping the TBN.
However there was a 'political' problem with this. The whole Low SAPs thing kicked off in Europe with massive OEM support behind it, as they were all worried (with good reason as it turned out) about Diesel Particulate Filters ( DPFs) blocking. Low SAPs oils sort of evolved to be around 6 TBN. The powers that be in ACEA were concerned that (cheap) conventional PCMOs were 'too close' to the (expensive!) Low SAPs oils. As a result, the ACEA 2010 spec, for the first time ever imposed minimum TBN specs (8 min for A1/B1, A3/B3 & A5/B5 and 10 min on A3/B4). This overturned years of a guiding philosophy which insisted on oil performance being defined by engine tests and not by artificial chemical limits.
So there you have it. ACEA oils like A3/B4 will have a specified high TBN and you might think that automatically makes them better than than an API PCMO with no specified TBN. It does not...
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: SonofJoe] #4551595
10/23/17 03:07 AM
10/23/17 03:07 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
But they are better....because of higher HTHS limit...wich makes them imposible to be made out as what yenks know as "conventional" 5w30 & 5w20...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: zeng] #4551658
10/23/17 06:32 AM
10/23/17 06:32 AM
Malaysia
zeng Offline OP
zeng  Offline OP
Malaysia
a )ACEA 2004 :-
All A1B1-04;A3B3;A3B4;A5B5 = TBN, no minimum being set;
C1-04 and C2 = TBN, no minimum set;
C3-04 = TBN, minimum 6.0.
b )ACEA 2007 : No data available.
c )ACEA 2008 :-
All A1B1-08; A3B3; A3B4 and A5B5 = TBN, minimum 8.0.
C1-08 and C2-08 = TBN, no minimum set;
C3-08 and C4-08 = TBN, minimum 6.0.
Re: No TBN requirements for API but yes for ACEA PCMOs [Re: Kamele0N] #4551704
10/23/17 07:40 AM
10/23/17 07:40 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
I intended for my words to interpreted narrowly to answer the OPs question, that's to say ACEA oils aren't necessarily better that API oils simply because ACEA oils are specced to a minimum TBN and API ones aren't.
To say ACEA oils are definitively 'better' or 'worse' than US oils depends on your point of view. I think it's easier simply to think of them as 'different'. For any given viscosity grade (say a 5W30 for example), the ACEA oil will be way better in diesel engines, it will have a higher HTHS, it will be less prone to shear and more seal compatible. On the other hand, the API (or more accurately ILSAC) oil will be seriously cheaper, give better fuel economy and be better suited to short oil drains.
