Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
91 registered members (Al, 28oz, andyd, ABomb369, 2009Edge, 2004tdigls, 11 invisible), 1,705 guests, and 49 spiders.
Topics290,666
Posts4,847,917
Members66,011
Most Online3,590
Jan 24th, 2017
Vertical filters putting sludge right under bypass #4551188
10/22/17 04:55 PM
10/22/17 04:55 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
With most filters seemingly having the bypass at the end of the filter media, could it theoretically intake sludge that collects in the base of a vertically or relatively vertically mounted filter?
I realize clean engines probably don't collect an appreciable amount of sludge, but filters like this one posted recently show what is possible.
Cheers
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551210
10/22/17 05:17 PM
10/22/17 05:17 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
What motor is that filter mounted on?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551219
10/22/17 05:28 PM
10/22/17 05:28 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Yes, that is a concern, Motorcraft filters advertise that (or at least used to) as a benefit of thread end bypass valves.
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: Vertical filters putting sludge right under bypass [Re: JC1] #4551220
10/22/17 05:32 PM
10/22/17 05:32 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
It was on a Hyundai engine
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551228
10/22/17 05:39 PM
10/22/17 05:39 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
It was still there when you took the filter off so obviously it's not an issue. smile
Next oil change, race the engine when cold, turn it off and drain the oil. It'll still collect there.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551250
10/22/17 05:56 PM
10/22/17 05:56 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Yeah, that anecdote is one the uglier ones I've seen posted here. That said, best information including the pinned Jim Allen thread at the top, say bypass events are rare and when they do occur of short duration.
Some say thread end bypass in vertical dome end up filters not the best. And vice versa, dome end bypass in vertical dome end down, same. Outside of Ford many OEM have the latter design, Honda and many GM models come to mind off top of my head.
'IMO', not a huge deal either way especially in light of noted knowledge of bypass events.
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551414
10/22/17 08:25 PM
10/22/17 08:25 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Yes, this is a recent cut and post from a Hyundai engine.
Interestingly enough, a motorcraft filter is the only filter I have cut open to find no bypass valve on the bottom.
I once thought Napa Gold (a fine fine filter by all accounts) had a thread side bypass setup, but the last one I bothered to cut open had the valve on the bottom?
Has BITOG created a list of which filters have what bypass? Thanks!
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551627
10/23/17 05:44 AM
10/23/17 05:44 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
In theory, it could.
In practical application, I doubt little, if any, ever makes the trip as you inquire.
The BP valve RARELY opens in the first place, and when it does, it's for a very short duration (anywhere from a fraction of a second to only a few seconds under obscene conditions). (See Jim Allens test results).
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Vertical filters putting sludge right under bypass [Re: SOHCman] #4551632
10/23/17 05:55 AM
10/23/17 05:55 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Regardless of where you put the bypass, there will be some accumulation of junk in the quiescent area that will be mobilised when it opens.
Filter bypass in block even has dead headed areas.
