Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
33 registered members (Bailes1992, 10ecfarmer, Brigadier, aquariuscsm, BlakeB, 2 invisible), 996 guests, and 39 spiders.
Topics290,865
Posts4,851,547
Members66,044
Most Online3,590
Jan 24th, 2017
Well Water Quality Question.... #4551033
10/22/17 01:07 PM
10/22/17 01:07 PM
Madison, Wisconsin
TWG1572 Offline OP
TWG1572  Offline OP
Madison, Wisconsin
We've owned this house 6 years, and we've always had some reddish substance that appears. When I change out the whole house filter, it's all over the outside and the filter is red. I'd describe it as slimy and smooth - not grainy at all. I just changed a leaking shower valve this weekend (attached picture) and it was covered in it too. It's not a stain, because it will wipe off easily with my fingertips. I'm almost wondering if it is clay or silt?
I've previously sent in water tests. They've not indicated any excess iron or manganese. However, I can't find them anymore so don't know the levels.
I'm trying to figure out what this stuff is, to see if I need to add a different/additional whole house filter. Any suggestions? Another water test? If so, is there something I should have them specifically look for? Thanks!
Re: Well Water Quality Question.... [Re: TWG1572] #4551037
10/22/17 01:15 PM
10/22/17 01:15 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
That is Iron.. aka Rusty Water. Do you have a soft water tank?
Re: Well Water Quality Question.... [Re: TWG1572] #4551039
10/22/17 01:20 PM
10/22/17 01:20 PM
Madison, Wisconsin
TWG1572 Offline OP
TWG1572  Offline OP
Madison, Wisconsin
We do. I'm wondering if it's time to have the softener looked at then? I do use the rust buster salt, just because I've wondered about iron even though the water tests didn't show it.
Does iron typically dry as a powder? I've not dealt with it before.
Re: Well Water Quality Question.... [Re: TWG1572] #4551048
10/22/17 01:30 PM
10/22/17 01:30 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
It may depend on the surface. It collects on my tub and toilet and it's hard to get off. Bar Keepers friend does a good job of cleaning it off. Iron Out also works.
Re: Well Water Quality Question.... [Re: TWG1572] #4551066
10/22/17 02:00 PM
10/22/17 02:00 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Iron bacteria are small living organisms which naturally occur in soil, shallow groundwater, and surface waters. These nuisance bacteria combine iron (or manganese) and oxygen to form deposits of "rust," bacterial cells, and a slimy material that sticks the bacteria to well pipes, pumps, and plumbing fixtures.
If it is Iron bacteria a sanitation of the well may be appropriate.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: Well Water Quality Question.... [Re: TWG1572] #4551069
10/22/17 02:12 PM
10/22/17 02:12 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
From a practical standpoint, water softeners can remove some iron from the well water. The resin beads inside the softener can foul with iron rather rapidly and this can reduce softener effectiveness. Some companies sell a fine mesh resin bead (smaller) to help deal with iron.
To clean a softener that is tasked with minor iron removal, use citric acid along with the brine solution in the regeneration cycle and regenerate more often.
Another method is to use a specific iron filter prior to the softener. Not necessarily a great solution.
Hydrogen peroxide injection is a viable method, and results in complete oxidation of the iron. It's reasonably inexpensive and very effective. There are other oxidation methods such as air injection and ozone
Re: Well Water Quality Question.... [Re: TWG1572] #4551094
10/22/17 02:46 PM
10/22/17 02:46 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
With out chlorine to stop Algae, Bacteria etc grows in the water.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Well Water Quality Question.... [Re: TWG1572] #4551109
10/22/17 03:00 PM
10/22/17 03:00 PM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
Reverse Osmosis system for the win !!
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Well Water Quality Question.... [Re: TWG1572] #4551203
10/22/17 05:11 PM
10/22/17 05:11 PM
michigan
dirtymudder Offline
dirtymudder  Offline
michigan
What Bobsarmory said,
Re: Well Water Quality Question.... [Re: TWG1572] #4551215
10/22/17 05:23 PM
10/22/17 05:23 PM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
We have well water and have this filter from Menards. It collects a ton of iron but never have any problems with iron anywhere past the filter. Our tap water is crystal clear and tastes great, never any iron stains on anything. We do have a water softener as well.
https://www.menards.com/main/plumbing/wa...221&ipos=30
Re: Well Water Quality Question.... [Re: TWG1572] #4551263
10/22/17 06:07 PM
10/22/17 06:07 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
My parents have a well that does the same thing. They have a sediment pre-filter (20"), then it goes to the Iron Master (Iron Remover), Water Softener, 20" Carbon Block Filter, U.V. Light, then to the house fixtures. For drinking it goes through a Reverse Osmosis system and then a re-mineralization cartridge afterward.
Culligan setup the system initially 15 years ago but we have since maintained it ourselves.
Pre-filter the water is full of bacteria and rust, post filters but before the R.O. unit the water is fit to drink. The R.O. unit is really for taste preference in their case.
Hope that helps. thumbsup
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Well Water Quality Question.... [Re: TWG1572] #4551345
10/22/17 07:21 PM
10/22/17 07:21 PM
WV
loneryder Offline
loneryder  Offline
WV
Order some chlorine pellets made for treating water and drop a palm full of them down your well. Run the taps until you can detect the chlorine. It will be similar to city tap water. You can continue to use the water. It will kill the bacteria in your pipes. If this doesn't work you can sanitize your system with a stronger amount of those chlorine pellets but this requires a lot of flushing. Also clean your water softener as stated above. I have to do this about once a month here in WV where there is a lot of iron in the water.
Re: Well Water Quality Question.... [Re: TWG1572] #4551354
10/22/17 07:31 PM
10/22/17 07:31 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would try the citric acid mixed with brine in the regeneration cycle.
2015 Ford F250 w/Powerstroke
Re: Well Water Quality Question.... [Re: loneryder] #4551523
10/22/17 10:38 PM
10/22/17 10:38 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
You can do this. I do this at times. But you must be aware that without enough dwell time, chlorine tablets dropped down the well pipe will produce trihalomethanes, a carcinogenic group of gases that are particularly dangerous at very very low levels.
http://www.water-research.net/index.php/trihalomethanes-disinfection
The dwell time needs to be about 30 minutes. Unless the water flowing in the well takes a full 30 minutes to travel from the chlorine pellets in the well to the showerhead, you will be inhaling orderless toxic gases.
Re: Well Water Quality Question.... [Re: Cujet] #4552513
10/23/17 11:12 PM
10/23/17 11:12 PM
WV
loneryder Offline
loneryder  Offline
WV
Interesting read. I'm using enough chlorine to barely detect with your nose. It tastes like municipal tap water. It's probably just enough to knock down the iron sulfur bacteria and reduce the smell. My drinking water goes thru some type of carbon filter. Also this:
Note: THM's are not a major concern for treating groundwater wells with low organic matter content, but it may be a problem after a shock disinfection.
I'm not even close to shocking it.
