Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
67 registered members (2002Bigride, Anduril, bdcardinal, A310, Astro14, Blaze, 5 invisible), 1,842 guests, and 49 spiders.
Topics290,821
Posts4,850,994
Members66,040
Most Online3,590
Jan 24th, 2017
Ethanol/gasoline fuel dilution #4550928
10/22/17 10:35 AM
10/22/17 10:35 AM
Douglas County, Colorado
bigj_16 Offline OP
bigj_16  Offline OP
Here's an interesting paper on the subject.
Two caveats:
A little may be lost in translation smile
Considering the source, there may be an agenda against using ethanol smile
http://pubs.rsc.org/en/content/articlehtml/2017/ra/c7ra00357a
Re: Ethanol/gasoline fuel dilution [Re: bigj_16] #4550971
10/22/17 11:38 AM
10/22/17 11:38 AM
Chicago
danielLD Offline
danielLD  Offline
Chicago
I will read it a bit later, thanks for posting for everyone here!
Re: Ethanol/gasoline fuel dilution [Re: bigj_16] #4551091
10/22/17 02:43 PM
10/22/17 02:43 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
Primary testing is done using ASTM D4172... aka the Four Ball Wear Test, who's applicability to testing engine oil has been forever been called into question.
Looking at the overall conclusion:
Quote:
Overall, it can be concluded that 6% of bioethanol fuel dilution can degrade properties performance (viscosity and alkalinity) and tribological behaviors of the synthetic oil. Ethanol fuel dilution may reduce friction, compared to pure gasoline due to its polarity and acidity. However, high acid in the oil causes high wear due to its corrosion on the surface, suggesting that ethanol-resistant engine oil should be produced in order to avoid serious wear from bioethanol.
I don't like the fist sentence. The sentence specifically identifies the "6% bioethanol fuel dilution" as degrading the performance properties. Going back through the results though, the E0-SO simple ALSO degrading the performance properties. In most cases, E10-SO had nearly identical performance as E0-SO. Yes, it was worse than the virgin synthetic oil, but they were both worse. The conclusion only discusses the ethanol blends as affecting performance, when the reality is that any fuel dilution affects performance.
The rest of the conclusion seems pretty straight though. The more ethanol in the dilution, the worse the performance properties.
Of course, all this is dependent on whether you believe the four ball wear test is even applicable to the engine environment.
