Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
115 registered members (AMC, aquariuscsm, 77GrandPrix, 28oz, 17 invisible), 1,866 guests, and 36 spiders.
Topics294,986
Posts4,925,432
Members66,660
Most Online2,553
Oct 27th, 2018
PPD and VII interactions in presence of biodiesel #4550692
10/22/17 01:53 AM
10/22/17 01:53 AM
'Stralia
Shannow Online content OP
Shannow  Online Content OP
'Stralia
biodiesel fuel dilution...
Evonik pesentation for STLE
Have posted before on the interaction between VII and PPDs, and some of the unhappy things that result.
This has some interesting charts, not just related to the topic of biodisel fuel dilution (some people in Oz have had sumps full of rubber from home brew biodiesel).
This chart is cool...a number of blends that contain different VIIs and DI packs (the couple of slides before this one list them and the oil properties.
An oil that's "in grade" with no PPDs, can end up out of grade with VII PPD interaction.
There's aged charts as well.
Have copped flack in the past for suggesting that cold temperature performance is the most likely to suffer with mixing fully finshed engine oils of different "design", but yet again, nasty things can happen iff the VIIs and PPDs do't play well.
That "yield stress" is part of the "W" requirements...it basically means that the oil is behaving as a semi solid "gel", that has to achieve the yield stress before (for example) falling into the void that's produced as the oil pump shifts the oil on a cold start. That's called "air binding" in the literature.
Re: PPD and VII interactions in presence of biodiesel [Re: Shannow] #4550885
10/22/17 08:52 AM
10/22/17 08:52 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
There must be reasons why the oil change intervals are shortened when running biodiesel
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: PPD and VII interactions in presence of biodiesel [Re: Shannow] #4550898
10/22/17 09:01 AM
10/22/17 09:01 AM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
We see the same thing here in the states. Those guys burning veggie based bio diesel often get polymerization of the oil. One guy documented his engine failure. It seems that long engine life requires good management and more than just a cursory understanding of what is actually happening.
Re: PPD and VII interactions in presence of biodiesel [Re: Shannow] #4550983
10/22/17 10:55 AM
10/22/17 10:55 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
I agree that the presentation is interesting but at the same time, you have to take it's overriding message with a huge pinch of salt.
Evonik are the biggest supplier of PMA PPDs for engine oils. To (ex) people like me, most PPDs are an easily manufactured commodity and you go for the one that does the necessary at the lowest cost. This is anathema to the folks at Evonik who have a vested interest in making the process of selecting PPDs as complicated as conceivably possible. I'm sure Evonik don't outright lie but they do tend to overemphasise VII/PPD incompatibility issues simply because they also supply PMA VIIs which provide both Viscosity Index improvement and MRV response (so no need to add a separate PPD). Whilst these sound great, the reality is that PMA-based VIIs are terribly inefficient and not a lot of folks use them.
It's well known in the industry that with high ethylene, crystalline OCP VIIs you need to take special care when selecting your PPD to avoid problems with MRV yield stress. Very waxy Group I base oils can also play havoc with PPD response but these days these are very rare beasts.
Finally, whilst this paper is all very technical interesting, it misses the essential point which is that the great bulk of PPDs that are put into engine oils are never ever called upon to actually DO anything! The engine oil market has moved to thinner and thinner engine oils, not only with lower KV100s but also with lower W-ratings. However the world hasn't gotten correspondingly colder! My own car specifies a 0W20. This oil contains a PPD but it would only ever be needed if the world entered another Ice Age!
Re: PPD and VII interactions in presence of biodiesel [Re: Cujet] #4554761
10/25/17 11:30 PM
10/25/17 11:30 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Some people fail to distinguish between biodiesel and WVO, and "home brewed" biodiesel Shannow mentions above might be contaminated with unmodified waste oil which is a lot more unstable than biodiesel.
The presentation does seem to be talking about properly produced biodiesel though.
Re: PPD and VII interactions in presence of biodiesel [Re: Shannow] #4564466
11/05/17 04:24 AM
11/05/17 04:24 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
I'm more concerned that the used ppd in engine oils isn't effective on diesel or biodiesel, and as such fuel contamination which is seen as thinning engine oil, actually thickens it considerably below 30F... to the point that you ycant pump the oil if theres enough fuel present and the temperature ets low enough, regardless of using an appropriate W grade.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
