S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
118 registered members (anndel, 2015_PSD, AndyB, 2010Civic, ARB1977, agpatel, 14 invisible), 2,053 guests, and 66 spiders.
Topics286,429
Posts4,908,099
Members67,622
Most Online2,967
Mar 10th, 2019
what causes a spark plug to wear out? #4550479
10/21/17 08:19 PM
10/21/17 08:19 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
My trimmer started misfiring at idle yesterday and almost got to the point where you couldn't let off the throttle. I put a new plug in it today and it runs like new again. I really didn't see anything wrong with the plug. Usually if it does what I described it's because a piece of carbon is causing it to ground out, but this wasn't the case. Another time on a piece of equipment I was having trouble getting it to restart when hot and that's what happened. Also the electrode had worn down to the point where that little v groove was worn and the gap was probably .050 instead of .030"
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550481
10/21/17 08:21 PM
10/21/17 08:21 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Every time it sparks it loses a tiny amound of metal from the electrodes. Figure it sparks 8000 times or more a minute.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550488
10/21/17 08:29 PM
10/21/17 08:29 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
It's the erosion of the electrodes. Center electrode and ground electrode.
I pull mine out every so often to clean them and re-gap them.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550537
10/21/17 09:01 PM
10/21/17 09:01 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
many times that center electrode has a crack in it, and the crack can expand/contract with temp too.
almost always a spark plug issue on a two stroke is jetting, unless theres TONS of runtime on it. if thats the case smile and toss a new ngk in there and enjoy the cheap easy maintenance of a smoker.
my dirtbikes often go several years on a plug, which can be 60 or more hours of runtime easy.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550575
10/21/17 09:33 PM
10/21/17 09:33 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Also Manganese in the gas will contribute to electrode wear on the spark plug. There is a lot of this in our fuel up here at certain times of the year and it will eat the electrodes good on non-iridium electrodes.
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550634
10/21/17 11:38 PM
10/21/17 11:38 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3090959/Physic_of_the_Gap_%E2%80%93_Spark_Plug#Post3090959
Your magneto system only has so much high voltage available to cause a spark across a specific gap and the fuel.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3092014/Physic_of_the_Gap_%E2%80%93_Spark_Plug#Post3092014
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550698
10/22/17 03:57 AM
10/22/17 03:57 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
If you've ever opened one of these things up you can see how simple they are and how failure can happen. There's much more to spark plug wear than just tip erosion. This center electrode carries the voltage to the tip where it jumps across the air gap to ground. These things run hot, are shaken like a James Bond martini, and usually run for years without so much as a hiccup. For OPE it's a wise idea to replace these simple items every few years regardless of tip wear. These pictures are of a Champion RCJ6Y that was only a year old. The center carbon conductor has failed and the plug is now used as a training aid. The poor guy that owns the blower spent his entire weekend fooling with the carburetor on this thing and he never checked his spark.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550790
10/22/17 08:21 AM
10/22/17 08:21 AM
Margate England
Claud Offline
Claud  Offline
Margate England
Spark plugs in modern engines last for an amazingly long time considering the environment they have to live in. In the days of leaded gas the build up of lead oxide on the ceramic insulator meant that mostly they wouldn't survive much over 15-20k miles. 12.000 mile change intervals were the norm on most cars back in the day.
Detonation, bad fuel, oil contamination, or water contamination are all things that can shorten a plug's life. Mostly a change interval of 50-100k miles is quite normal, but it wouldn't be the case if many other factors hadn't advanced along with plug technology, particularly engines consistently kept in near perfect tune thanks to computer controlled fuel injection and ignition timing.
Claud.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4550951
10/22/17 11:11 AM
10/22/17 11:11 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
I believe the standard industry service life is 30,000 miles for regular plugs, 60,000 for platinum tipped plugs and 100,000+ for the iridium type.
I have seen completely eroded tips at 30,000 miles and I've changed iridium OEM plugs at 150,000 that looked fine. My personal recommendation to people is to use what it came from the factory with and change them when it is recommended.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4551030
10/22/17 01:06 PM
10/22/17 01:06 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Generally speaking, spark plugs seldom fail and when they do, there's usually no physical evidence to explain why. Any plugs that I've had fail looked perfectly fine. The last one to do so was early this year in on of my ATVs. It was an NKG plug with fewer than 3000 miles on it and it looked virtually brand new. Nonetheless, it failed.
Spark plugs can be tricky. I've had two of them spark outside the cylinder but would not fire inside. That, it very frustrating. I chased that problem for over an hour before trying a different plug. Since then, I always keep a known working spark plug on hand.
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4551124
10/22/17 03:08 PM
10/22/17 03:08 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
It's not unusual for two stroke spark plugs to develop a very thin conductive coating on the insulator. Leading to erratic operation or worse. Plugs are cheap, I simply throw them out.
Re: what causes a spark plug to wear out? [Re: FowVay] #4551164
10/22/17 04:04 PM
10/22/17 04:04 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Fantastic FowVay! I never knew there was a carbon center conductor. Is that other piece a spring ?
Re: what causes a spark plug to wear out? [Re: motor_oil_madman] #4551166
10/22/17 04:11 PM
10/22/17 04:11 PM
out there
spasm3 Online content
spasm3  Online Content
out there
Two strokes fire every rotation. I replace my ope 4 stroke plugs at 100hrs, 50hrs for 2 stroke.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: what causes a spark plug to wear out? [Re: spasm3] #4551337
10/22/17 07:08 PM
10/22/17 07:08 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Many 4 strokes do too. It's not like small engines have a distributor that runs off a cam shaft. They have a magneto ignition that runs off the flywheel. The flywheel is driven by the crank, so it fires every time around, IIRC.
Many cars did something similar with a waste spark ignition. Each coil fired a pair of plugs. One on plug was in the compression stroke, the other in the exhaust stroke (360 degrees apart.) So the plug fired on every revolution in such systems.
network down, IP packets delivered via UPS -BOFH
Re: what causes a spark plug to wear out? [Re: javacontour] #4551346
10/22/17 07:24 PM
10/22/17 07:24 PM
out there
out there
Right you are! My olds is waste spark, copper plugs every 25k or double platinum every 50k.
