Mid-OCI oil sample of RT6 CK-4.
From Polaris:
Truck Odometer: 388000 mi
Miles on oil: 36000
10 quarts of makeup oil added. That is 9 quarts burned, and 1 quart fresh when the filter was changed mid-OCI.
Fram Ultra filter for first 18k, Purolator Boss for 18k.
Wear Metals:
(Element (ppm); 235k, 322k, 338k, 352k, 370k, 388k)
Iron; 42, 52, 30, 50, 38, 72
Chromium; 3, 3, 1, 2, 1, 2
Al; 4, 5, 3, 4, 3, 4
Cu; 3, 4, 1, 2, 1, 3
Lead; 9, 31, 4, 7, 2, 13
Contaminants:
Silicon; 6, 13, 7, 9, 7, 8
Sodium; 8, 6, 5, 4, 7, 9
Potassium; 62, 0, 1, 1, 4, 1
Multi-source metals:
Moly; 75, 76, 5, 4, 0, 2
Boron; 83, 38, 112, 69, 106, 62
Additive metals:
Mag; 1333, 1198, 179, 163, 94, 105
Calcium; 960, 1111, 2174, 2198, 2053, 2179
Phos; 1138, 1104, 1012, 1048, 924, 959
Zinc; 1439, 1471, 1277, 1271, 1143, 1211
Fuel Dilution; Soot; Water;
KV100 (cSt); 15.1, 15.1, 15.3, 15.3, 15.4, 15.4
TBN; 6.54, 6.99, 5.69, 4.27, 4.96, 4.13
Oxidation; 15, 16, 14, 14, 13, 15
Nitration; 10, 10, 9, 9, 8, 9
Polaris Comments:
Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor
equipment and fluid conditions. LEAD is at a MODERATE LEVEL and may be OVERLAY METAL from MAIN/ROD BEARINGS; Iron is
at a MINOR LEVEL. IRON SOURCES in engines can be cylinder liners, iron pistons, hardened steel camshafts, crankshafts, gears,
hardened rocker arms, valve bridges, alloyed steel cam follower rollers, etc. Lubricant and filter change acknowledged. Sample
information has been added or tests have been rerun or additional testing was added and the report has been regenerated.
Another Lead spike, and for no apparent reason, which Polaris has flagged at a moderate level. And the Iron of 72 ppm was flagged as minor. Soot continues to increase, although Polaris didn't flag it as a concern.
Corrected Iron concentration is 137 ppm due to the 10 quarts of makeup oil, yielding a wear rate of 3.6 ppm per kmile. This is significantly higher than the 3.1 of the last sample. Based on one data point, it seems that the wear rate increased by 18% over the 2nd 18k miles. I think I will shorten the interval of the new oil fill to 30k.
From Polaris:
Miles on oil: 36000
Wear Metals:
Contaminants:
Additive metals:
Polaris Comments:
