Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
70 registered members (2002Bigride, Anduril, bdcardinal, A310, Astro14, 2010Civic, 5 invisible), 1,828 guests, and 50 spiders.
Topics290,821
Posts4,850,994
Members66,040
Most Online3,590
Jan 24th, 2017
Friction Modifier #4550215
10/21/17 01:41 PM
10/21/17 01:41 PM
Arizona
TalNum Offline OP
TalNum  Offline OP
Arizona
Hi All,
Looking for some input from other users here. A while ago I did a full differential fluid change. I filled it with the recommended type (75W-140 Motorcraft, no modifiers in oil) and amount and added the recommended 4oz of Ford XL-3 friction modifier.
Everything seemed alright but I have noticed that the chatter in the rear end is back somewhat. I find that particularly on hard launches (even on straights), making even an average launch while going uphill from a standstill, and making a quick right hand turn from a stand still there is a decent amount of stuttering/chatter.
At first I thought it was the drive shaft as I had to remove it to put a new gasket on the output shaft of my transmission, and it felt as though the chatter was originating from there, but everything appears to be in order there.
As this seems to be a textbook case of not having enough friction modifier in your differential, would it hurt to add another 4oz of friction modifier? I have read some people having success with this while others are dead set against going above factory recommended specs.
TL;DR: Chatter has developed. Has anyone added above the recommended 4oz of friction modifier to a Ford 8.8, limited-slip differential. Any negative consequences?
Re: Friction Modifier [Re: TalNum] #4550226
10/21/17 01:57 PM
10/21/17 01:57 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
Sometimes you have to add a bit more. The best way to mix it in is to do figure 8's. When we do a fresh build with new clutches we soak them in XL-3 before they go in the center section.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Friction Modifier [Re: TalNum] #4550252
10/21/17 03:02 PM
10/21/17 03:02 PM
Indiana
njohnson Offline
njohnson  Offline
Indiana
Are you open to using a different brand of Limited Slip additive? We have had good results with Lubegard Limited Slip Additive. I used Amsoil Severe Gear and their Slip Loc additive in our SUV. At first, it was fine, but, after towing a 12 foot cargo trailer on Saturdays to the Farmer's Market, it started clunking and banging.
Change it out to Mobil 1 gear lube. I tried the Mobil 1 without any additives first, since it says it has the limited slip additives already. It was fine doing straight acceleration, but, going around turns, it chattered. Added the Lubegard additive, and it has been fine since. Three years later, and it still doesn't chattered around turns.
Our dad's 2006 Tundra had clunking and banging when we tried to use just gear lube with no additive, even though the gear lube said it had additives already and additional additives shouldn't be necessary.
http://lubegard.com/SearchByCategory.asp...lip+Supplement#
Re: Friction Modifier [Re: TalNum] #4550278
10/21/17 03:52 PM
10/21/17 03:52 PM
Arizona
TalNum Offline OP
TalNum  Offline OP
Arizona
Appreciate the replies.
It sounds as though that if I do not get crazy with adding too much modifier, I should be alright. I am definitely open to using other brands, but I think I will first try pumping out 4oz from my differential and adding another bottle in. I figure this should leave me anywhere from around 6-7oz of modifier in total.
If the chatter continues I will definitely give Mobil 1 a look along with some Lubegard. I have seen these recommended by others before, so I figure it would be worth a shot.
Thanks!
Re: Friction Modifier [Re: TalNum] #4550438
10/21/17 07:21 PM
10/21/17 07:21 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It shouldn't chatter while going straight unless one wheel is breaking traction.....Which shouldn't happen with a Posi/Limited Slip with both tires on dry pavement.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: Friction Modifier [Re: TalNum] #4554656
10/25/17 10:10 PM
10/25/17 10:10 PM
pa
benjy Offline
benjy  Offline
pa
like everything else Redline their gear lubricants are the best, check their web or call + TALK to a tech for recommendations !!
