Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
wjamyers, L00btech, Lucase483, Chaucha, UofA
70790 Registered Users
110 registered members (2009Edge, 01VFR, advocate, 2013ecof150, 4WD, AdditiveOCD, 12 invisible), 2,349 guests, and 22 spiders.
Topics301,848
Posts5,203,886
Members70,790
Page 1 of 6 1 2 6
Excessive battery terminal corrosion #4550142 10/21/17 10:51 AM
K
Kestas Offline OP
Global Moderator
Global Moderator
K
My car has developed corrosion on the positive battery terminal. The problem is that it seems excessive and needs cleaning more often than I can remember. I've had this car for 15 years. I normally don't bother with terminal coatings or felt pads, but I may have to with this car. It's a Durolast battery. What could have changed with my car to enhance this corrosion?
Re: Excessive battery terminal corrosion [Re: Kestas] #4550148 10/21/17 11:06 AM
skyactiv Offline
ONE cause could be micro cracks around the battery post in which gas is escaping and causing the issue. Usually caused by improper handling.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Excessive battery terminal corrosion [Re: Kestas] #4550155 10/21/17 11:15 AM
B
bubbatime Online Shocked
Online Shocked
B
These two products are what will fix your ails. WITH a green felt pad under your terminals.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Excessive battery terminal corrosion [Re: Kestas] #4550158 10/21/17 11:20 AM
G
George7941 Offline
G
I used to service a 1998 GM G3500 diesel van with a second frame mounted battery under the van and it always had a lot of corrosion on the positive terminal and I had to clean it every few months. The three other battery terminals on the van were fine. This corrosion persisted over the life of the van, through multiple battery replacements, from multiple battery sources - Delco, Costco etc. The experience seemed to rule out the usual causes - overcharging and cracked case around positive post
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Excessive battery terminal corrosion [Re: Kestas] #4550159 10/21/17 11:22 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
In no particular order:
1) you clamped the battery too hard/right, and compromised the plastic to metal seal slightly.
2) age has worn/removed the protective coatings from the cable.
3) dirty/bad ground, including on the voltage regulator, causing more time at elevated voltages where gassing may occur.
4) bad/failing/intermittent diode that turns the alternator from a six pulse rectifier (terrible dc) to a four pulse (even worse).
5) poor quality battery
6) too cold at too low a charge at some point compromised case slightly
I always put a thin coat of dielectric grease around the metal to plastic junction and on the terminals, and then spread the grease on the top of the terminal to coat the top of the cable clamp.
Re: Excessive battery terminal corrosion [Re: George7941] #4550180 10/21/17 11:55 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If the parallel batteries weren't perfectly matched and replaced in pairs, all sorts of funny stuff could happen.
Re: Excessive battery terminal corrosion [Re: Kestas] #4550184 10/21/17 12:02 PM
Donald Offline
Your battery is a leaker. The seal between the case and post was damaged.
Felt pads may help.
Aside from it being a PIA to keep clean it does does hamper the battery being a battery.
2015 Ford F-250 w/Powerstroke
Re: Excessive battery terminal corrosion [Re: Kestas] #4550189 10/21/17 12:10 PM
Donald Offline
Who mfg the battery? Exide??
Re: Excessive battery terminal corrosion [Re: JHZR2] #4550195 10/21/17 12:18 PM
K
Kestas Offline OP
Global Moderator
Global Moderator
K
This is on my 1995 Mercedes E320. The terminal head is brass, same shape as the thick lead ones. I can't remember if it ever had a coating. After two months, the corrosion was so thick the battery brushes couldn't remove it, and I had to scrape it off like a dental hygenist.
Re: Excessive battery terminal corrosion [Re: Kestas] #4550209 10/21/17 12:35 PM
K
Kuato Offline
K
All good info above....add short tripping to the list of things that can cause the condition.
If the integrity of the battery case is good then gluing a penny next to the positive terminal will get the corrosion on the penny instead of anywhere else.
Thick vs Thin test: 15k / 43k miles complete
Re: Excessive battery terminal corrosion [Re: Kestas] #4550242 10/21/17 01:42 PM
K
Kestas Offline OP
Global Moderator
Global Moderator
K
I just checked how old my battery is... over 8 years old! I'm going on a long trip in a couple weeks. I'm glad I caught this. This explains why it recently takes just a bit longer to crank the engine before it starts. Hopefully a new battery will cure this ill.
Re: Excessive battery terminal corrosion [Re: Donald] #4550266 10/21/17 02:27 PM
B
bullwinkle Offline
B
No, it's the awesome Johnson Controls leak fest! I had one that leaked from DAY ONE with never having a clamp put on it (dual terminal battery).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Excessive battery terminal corrosion [Re: Kestas] #4550298 10/21/17 03:13 PM
H
HorseThief Offline
H
Most batteries made by East Penn (Sam's club Duracell, Napa, Meijer powercell, or Deka) have sealed tops and side vents that severely cut back on gassing and build up on terminals. Use plenty of cleaner and neutralizer and follow up with neutralizer coating or dielectric grease. If possible, a nice bath in some hot water and baking soda will help to clean and neutralize most of the acid. Make sure you really cover any exposed copper to cut back on green/blue copper sulfur corrosion.
I saw a brown dog
Re: Excessive battery terminal corrosion [Re: Kuato] #4550315 10/21/17 03:36 PM
M
motor_oil_madman Offline
M
Does the penny have to make contact with the post?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Excessive battery terminal corrosion [Re: Kestas] #4550318 10/21/17 03:43 PM
H
HangFire Online Content
Online Content
H
This.
Yes.
I've seen this multiple times. When the green fuzz grows crazy fast, the problem is a leaky battery, and a new battery is the real fix.
Various musings: http://hangfire.net
Page 1 of 6 1 2 6
