Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
131 registered members (928, 92saturnsl2, 4WD, albenjoseph, 77GrandPrix, 01rangerxl, 11 invisible), 2,010 guests, and 54 spiders.
Topics286,086
Posts4,902,290
Members67,560
Most Online2,967
Mar 10th, 2019
Schaeffer Application Question #4549985
10/21/17 09:10 AM
10/21/17 09:10 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
This involves 2 types of Schaffer Motor Oils. Their normal gasoline engine oils (701, 703, 9003D, 9004, 9005) and their European engine oils (8007 and 8008). When I go to their chart and go by API certification codes, e.g., SJ, SL, SM, SN, I see things I don't understand but want to understand.
For example, the European oils are good for SL and SN but not SJ and SM. I'm just trying to understand as I want to use the European in my GS300 (SJ) and LS400 (SJ). My 4Runner and LS430 are SL so it is no problem. Would it be a problem in my older Lexus? I've emailed Schaeffer Corp this morning.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Schaeffer Application Question [Re: Gebo] #4550283
10/21/17 04:00 PM
10/21/17 04:00 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yeah that chart is a bit crazy, the 9004 is listed as SH, SJ, SM and SN but NOT SL ?!
Then you have the 8008, it's listed as SH, SL and SN, but NOT SJ or SM. Only every second API spec for that oil, it's on half rations.
Obviously the work experience kid was in a rush to get home that day and skipped a few letters and numbers. After all, "who reads this stuff anyway?" they thought to themselves.
My advice, ignore the list, if you need SJ then that or above (SL, SM, SN) will be fine. Any one will do.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Schaeffer Application Question [Re: Gebo] #4550323
10/21/17 04:47 PM
10/21/17 04:47 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Here's my chart:
SN = Current
SM = Obsolete
SL = Obsolete
SJ = Obsolete
Re: Schaeffer Application Question [Re: Merkava_4] #4550338
10/21/17 05:04 PM
10/21/17 05:04 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Here's my chart:
SN = Current
SM = Obsolete
SL = Obsolete
SJ = Obsolete
Here is my chart
SN = Current
SM = what's the point ?
SL = Last of the good stuff that allows real zinc levels
SJ = Obsolete
Re: Schaeffer Application Question [Re: SR5] #4550445
10/21/17 07:37 PM
10/21/17 07:37 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: SR5
Here is my chart
SN = Current
SJ = Obsolete
OK ... We'll go by your chart. smile
Re: Schaeffer Application Question [Re: Merkava_4] #4550716
10/22/17 05:24 AM
10/22/17 05:24 AM
MICHIGAN USA
LEADED Online content
LEADED  Online Content
MICHIGAN USA
What do you mean by absolete . I will take an ACEA SL 10W 30 over any API SN spec PCMO .I use to get Scheaffers 703 SL for about 15 years . Pretty hard to make blank statements.
Re: Schaeffer Application Question [Re: Gebo] #4550751
10/22/17 07:11 AM
10/22/17 07:11 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I agree. I prefer the earlier oils. See my old cars? LOL
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Schaeffer Application Question [Re: Gebo] #4550810
10/22/17 08:57 AM
10/22/17 08:57 AM
MICHIGAN USA
MICHIGAN USA
What get my goat is take EOM HI MILAGE PCMO are all rated SL. Then you tell me SL oil is absolete . API weight standards were incorporated in 1905 . Its about time to upgrade . If I purchase an 11 Cts oil I expect it to stay in grade for the duration . Not shear down to 9 Cts & loose 10% oil pressure
