Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
103 registered members (1978elcamino, 2004tdigls, 10ecfarmer, 55hambone, 007, 4WD, 11 invisible), 1,319 guests, and 17 spiders.
Topics303,499
Posts5,235,272
Members71,063
3M Foaming Salt Remover #4549217 10/20/17 12:11 PM
SatinSilver Offline OP
Should help get rid of those pesky salt stains on carpeted mats. Only $5.55 at Napa. I remember a thread where someone was asking the best way to get rid of the stains. Regular carpet cleaner doesn't seem to do that much to help. I haven't used it yet but will pick some up.
https://www.napaonline.com/en/p/MMM39146
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4549221 10/20/17 12:13 PM
SVTCobra Offline
Vinegar/water solution works pretty good.
Think twice, speak once.
Re: 3M Foaming Salt Remover [Re: SVTCobra] #4549303 10/20/17 02:08 PM
B
Bgallagher Offline
B
I am surprised as they are both acidic in nature. I would have figured more base like baking soda. Either way 3M is an excellent brand of products and though I have not used it personally, I feel that it can probably do the job. I would recommend rinsing them with water afterwards and vacuum or something to suck out the moisture
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4549344 10/20/17 02:59 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I can't understand why you would need anything more than water to remove salt. All you need is a polar solution.
Why would you need vinegar? It's not as though salt needs to be neutralized. It's already neutral.
Re: 3M Foaming Salt Remover [Re: Kestas] #4549358 10/20/17 03:31 PM
Because usually wetting and removing the stain is only temporary. It then returns when it dries. Here's another link on the topic by one of the best detailers out there:
http://www.esotericcarcare.com/whips-wax-salt-remover-16-oz/
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4549368 10/20/17 03:52 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
You've only parroted what the web site says. How does it keep the stain from returning? What does it do that simple dilution with water doesn't? What is the active ingredient?
BTW, I looked up the data sheet for the Napa product. It contains EDTA, which binds lime products so it can be removed. This suggests it is the lime, and not salt that stains the carpet white. That would also explain why dilute vinegar works.
Re: 3M Foaming Salt Remover [Re: Kestas] #4549629 10/20/17 08:17 PM
Which was my experience as well. Too bad for you if the site says the same thing.
First you question vinegar, then change your tune.
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4549654 10/20/17 08:48 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
My first comment addressed salt. The second comment addressed lime.
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4552532 10/24/17 12:20 AM
R
raytseng Offline
R
when they say "salt" that's typically a colloquialism for road salt which although NaCl is the primary ingredient, has de-icer chlorides in the mix.
Also road salt is typically the unrefined rocks, so contains a high amount of other minerals that are naturally occurring.
Re: 3M Foaming Salt Remover [Re: SatinSilver] #4554297 10/25/17 03:40 PM
P
Piston_slap Offline
P
Until you mentioned "road salt" I was wondering how so much salt was being tracked in on the carpet. I'd try the NAPA product since it has a focused application.
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, WIX Gold
Isotope U235
Re: 3M Foaming Salt Remover [Re: Piston_slap] #4554998 10/26/17 10:23 AM
Duffyjr Offline
This is why I have a set of rubber WeatherTech matts for the winter. Plus they stay pliable when it freezes and stay put. Winter is just to hard on carpet around here.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
