Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
111 registered members (acme, allgm59, 928, Ag76, Alfred_B, Aero540T, 6 invisible), 2,053 guests, and 63 spiders.
Topics286,236
Posts4,904,909
Members67,582
Most Online2,967
Mar 10th, 2019
Oil Temps Too Low with New Oil Cooler? #4548436
10/19/17 03:45 PM
10/19/17 03:45 PM
Toronto, Canada
LaszloToth Offline OP
Toronto, Canada
Replaced the CSF Racing rad with a CSF oil cooler combo rad in my '11 STi sedan and although this will work brilliantly at the track I am concerned that the oil temps are too cold for street use. Car is stock with oil temp monitoring, AOS and this big rad with an integrated oil cooler. Objective is reliability at the track.
Measured at the sandwich plate with an Auto Meter electric gauge, oil temps were 225F max with the CSF Racing rad at the track. This is good.
The CSF oil cooler combo rad has a thermostat sandwich plate set at 75 - 82C +/- 2C. Converted to imperial this is 167 - 180F, which is basically coolant temps.
Now highway temps are 167F in (13C ambient) and 180c in city driving, and I'm concerned that this is too cold for winter driving.
It looks like the industry standard thermostat setting for external oil coolers is 185F but I'm learning that the target temp for oil in a street driven car should be between 215 and 240F.
Should I be concerned about these oil temperatures for the winter in Canada?
White '11 STi
Buckle up. The new Subaru WRX STi is here.
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4548455
10/19/17 04:03 PM
10/19/17 04:03 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
It's "possible" anything under approx 170-180 deg F oil temp might mean less than full activation of your oil's additive package. You could always block some of your radiator's front opening in the winter. I used to routinely do that with some of my performance cars years ago that would run too cool in winter otherwise. With a 167 deg F coolant temp, your oil temps could be 10-30 deg higher.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Oil Temps Too Low with New Oil Cooler? [Re: 69GTX] #4548503
10/19/17 05:05 PM
10/19/17 05:05 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
You see large trucks with the grille covers all the time here, you should identify where the oil cooler is located in the radiator and block that part off if that is possible. You might even consider removing whatever blocking you devise only for track use, idk what your tune or driving style is though. I would be wary about anything strapped to the radiator due to vibration. I think the best solution would be some type of thermostat, I've seen them mentioned for use with auto trans coolers. I guess the application is for a tow vehicle that needs the cooling, but not all the time. That sounds pretty similar to your application.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4548615
10/19/17 07:36 PM
10/19/17 07:36 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
You can try installing a different temperature valve; Mocal sells them in an optional high temperature version (95C / 205F). That would still open at your track oil temperatures, it might even help since rapid warmup to operating temps is an advantage in any engine.
http://mocalusa.com/thermos.htm
Another option would be to install a water / oil intercooler as fitted on some OEM vehicles (my Miata uses one, VW uses them a lot, etc). These warm up the oil temperature to coolant temperature rapidly to assist in vehicle warmup. The warming action is greater than the cooling action, although there is some cooling action (temperatures of oil and coolant are closer to each other than without the intercooler). Maybe "intercooler" isn't the correct term as used by manufacturers, but if not you can probably figure it out.
It's fairly common here to block off air into the cooling system in winter; in my Miata if I don't cover the radiator with cardboard it only reaches operating temps in stop-and-go traffic; as soon as I get onto expressway speeds the temps fall rapidly below proper coolant temperature (the gauge drops to below 180F in about five minutes). But Toronto is much warmer than here, I am not convinced it would be a good idea with your typical ambient temperatures. You could try a partial block if you want, but I personally would explore the other options I mentioned. You don't want to over-heat with a blocking mechanism.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4548704
10/19/17 08:58 PM
10/19/17 08:58 PM
Toronto, Canada
Toronto, Canada
That's a great suggestion, Johnny. Wish I could just change the t-stat that's part of the oil cooler circuit in the CSF combo rad to a 205 or 215 F item instead though.
White '11 STi
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4549695
10/20/17 09:34 PM
10/20/17 09:34 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
My 335 lives around 235F, and the t-stat to the external cooler doesn't doesn't open until like 250F, which it's done maybe twice in the last 80,000 miles. I'd go hot.
Re: Oil Temps Too Low with New Oil Cooler? [Re: antonmnster] #4549730
10/20/17 10:29 PM
10/20/17 10:29 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Are you referring to oil temperature or coolant temperature ?
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4550091
10/21/17 10:41 AM
10/21/17 10:41 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I had a cooler/heater attached to the oil filter mount for a while. It did cut in half the warm up time. It also used the hottest coolant in the motor (coming out of the turbo after the head)
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Oil Temps Too Low with New Oil Cooler? [Re: Merkava_4] #4550638
10/21/17 11:45 PM
10/21/17 11:45 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
Oil. There is no coolant temp gauge since the ECU varies it between 205-225F.
Re: Oil Temps Too Low with New Oil Cooler? [Re: antonmnster] #4550711
10/22/17 05:16 AM
10/22/17 05:16 AM
MICHIGAN USA
LEADED Offline
LEADED  Offline
MICHIGAN USA
Do you mean a heat exchanger like on Ford Ecoboost blocks .
Re: Oil Temps Too Low with New Oil Cooler? [Re: LaszloToth] #4551807
10/23/17 10:15 AM
10/23/17 10:15 AM
Toronto, Canada
Toronto, Canada
Subaru's have an OE oil cooler at the filter housing, which is liquid to liquid. Pictures of OE item below. This helps heat the oil upon startup as well.
The CSF Combo rad is also a liquid to liquid type as it's integral in the bottom of the radiator, but this rad oil cooler loop has a thermostat in it. Effectively, the CSF Combo rad will keep oil at coolant temps unless the oil cooler thermostat has a higher-than-coolant set point.
I'd like the oil to run above 212 F, so that's why they oil cooler's 170 F set point seems too low. It's likely a design for off road only (race), and not street.
White '11 STi
