Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
103 registered members (Astro14, askani79705, aquariuscsm, AMC, Asterix, 15 invisible), 1,926 guests, and 35 spiders.
Topics294,986
Posts4,925,442
Members66,660
Most Online2,553
Oct 27th, 2018
Did I buy the right grease for sway bar end links? #4548316
10/19/17 12:20 PM
10/19/17 12:20 PM
Canada
OCDriver Offline OP
OCDriver  Offline OP
Canada
I bought a set of Moog sway bar end links, which have a zerk grease fitting. I don't know much about grease, I bought this tube based on a review for the end links. It's NLGI GC-LB #2 spec and says it works for ball joints (which is basically what end links are, right?)
Re: Did I buy the right grease for sway bar end links? [Re: OCDriver] #4548335
10/19/17 12:37 PM
10/19/17 12:37 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
That will be fine. I am not a fan of M1 grease. Seems to break apart and get runny. But for sway bar end links it will be fine.
I prefer a moly fortified grease for ball joints, end links, tie rods, etc... type joints.
yup
Re: Did I buy the right grease for sway bar end links? [Re: OCDriver] #4548346
10/19/17 12:50 PM
10/19/17 12:50 PM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
I like the Valvoline synthetic grease. has Moly and from what I've read on this forum, it doesn't run or separate nearly as much as M1.
2004 Toyota Solara SE 2.4 2AZFE
182,000 miles
Castrol Magnatec Semi-Syn 5W30
Royal Purple 20-400 oversize 2nd run
Re: Did I buy the right grease for sway bar end links? [Re: OCDriver] #4548351
10/19/17 12:59 PM
10/19/17 12:59 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Yup that works. I have that in my grease gun at the moment.
Generally, the only concern you need when it comes to grease is using a high moly fortified grease in a roller/ball bearing application. Moly can cause the bearings to slide, instead of roll. So stick with non-moly grease for these places.
Re: Did I buy the right grease for sway bar end links? [Re: OCDriver] #4548414
10/19/17 02:11 PM
10/19/17 02:11 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I used Napa Sil-Glyde for my sway bar links. So far so good for me.
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Did I buy the right grease for sway bar end links? [Re: OCDriver] #4551612
10/23/17 03:30 AM
10/23/17 03:30 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Like Jimzz and THafeez said, fine grease and application appropriate. I also prefer Valvoline Synpower for the extra moly. Unlike many, I've never had a problem with M1 grease; had a tub of it sitting in the garage for a couple years without any separation and it always worked great when I was packing a bearing by hand.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
